    FLIR LEPTON 3.5 Thermal camera with VOXL 2
    1.3k
    • J
      Jetson Nano
      Hello @Alex-Kushleyev @modaltb @Eric-Katzfey
      I would like to know whether I could connect a Flir Lepton 3.5 camera to VOXL 2 board. Using the Starling 2 Image Sensor Micro-coax Front-end Adapter board link.
      I want to stream the video from the camera through RTSP protocol, is it possible.
      VOXL 2 - D0014 Architecture (Starling 2)
      here it is mentioned about the flir lepton , I would like to know whether I can stream the lepton Thermal camera data as RTSP stream from this connection.
      • J
        Jetson Nano
        Hello @modaltb @Alex-Kushleyev @Vinny @Eric-Katzfey
        I am using VOXL2, with m0173-1-04 camera board, which has port for lepton thermal camera. there is no documentation available for the m0173-1-04 board , is there any pinout difference
        voxl-configure-camera is 29
        Flir Lepton 3.5
        while I run the voxl-lepton-server command I am getting the following error. can anyone help me with the process. I tried with different configurations, but the error is the same, I2C connection issue. can anyone guide me in the right direction.
        voxl2:/$ voxl-lepton-server
        spi_bus:         0
        spi_speed:       16000000
        en_i2c:          1
        i2c_bus:         4
        shutter_mode:    auto
        flow_shutter_s:  20
        closePeriodInFramesInAir:         1
        openPeriodInFramesInAir:          0
        desiredFfcPeriodMsInAir:          360000
        desiredFfcTempDeltaCentiDegInAir: 600
        en_rotate:       0
        attempting to open I2C CCI
        trying address 0x2a
        unable to read status reg at either lepton i2c address
        failed to open I2C port 4, disabling CCI ret=-108
        WARNING, FAILED TO START I2C CCI
        Starting in SPI-ONLY mode
        waiting for first frame from lepton to create MPA pipes
        A 1 Reply Last reply 9 Apr 2025, 02:16 Reply Quote 0
        • A
          Alex Kushleyev ModalAI Team @Jetson Nano
          @Jetson-Nano , I just tested this and it's working. You may have an issue with pinout, please check https://docs.modalai.com/M0173/#j6---sm08b-srss-tb
          voxl-lepton-server
          spi_bus:         0
          spi_speed:       16000000
          en_i2c:          1
          i2c_bus:         4
          shutter_mode:    auto
          flow_shutter_s:  20
          assign_cpu_num:  7
          en_timing_msg:   0
          en_rotate:       0
          thread is now locked to the following cores: 7
          attempting to init the io expander
          Attempting intitialization for M0188 (TCA9543A)
          ERROR: in voxl_i2c_read_bytes, failed to write to bus
          io_expander_init, failed to read TCA9543APWR control register
          If you are not using an M0188 lepton board then this is expected
          Attempting intitialization for M0187 (PI4IO)
          io_expander_init, failed to read from io expander
          If you are not using an M0187 lepton board then this is expected
          trying address 0x2a
          successfully opened I2C port
          Successfully connected to I2C CCI
          id number out of range, cnt: 156, 100
          segment number OOB: 12
          id number out of range, cnt: 98, 200
          WARNING Expected segment 0, received segment 4
          id number out of range, cnt: 136, 300
          id number out of range, cnt: 177, 400
          id number out of range, cnt: 92, 500
          bad id limit reached so syncing lepton, sync_count: 2
          creating MPA server pipes
          enabling MPA control interface
          (success)
          J 4 Replies Last reply 9 Apr 2025, 04:14 Reply Quote 0
          • J
            Jetson Nano @Alex Kushleyev
            @Alex-Kushleyev Thank you for reverting back.
            I am using custom Board for the Lepton, with MCBL-00105-02 cable for the connection. I will verify the pinouts.
            I checked the camera with different board and it is working now.
            • J
              • J
                Hi @Alex-Kushleyev @modaltb @Eric-Katzfey
                I still have the same error when i use my custom board. Could you verify my board pinouts.
                • J
                  @Alex-Kushleyev hey , I just had query , when i am using the groupgets thermal breakout board , the video is delay in the video feed. it is not ideal. it is a parameter error or the thermal board issue. is there any thermal camera board which will give me good and clear video stream
                  J 1 Reply Last reply 25 Jun 2025, 13:50 Reply Quote 0
                  • J
                    Jetson Nano @Jetson Nano
                    @Alex-Kushleyev @Eric-Katzfey @modaltb
                    guys any help with solving this issue.
                    this the video feed I am getting.
                    589968ed-ccc6-443d-a925-a6f7f0aa41f8-Screenshot from 2025-06-25 19-11-15.png
                    voxl2:~$ voxl-lepton-server
                    spi_bus:         0
                    spi_speed:       16000000
                    en_i2c:          1
                    i2c_bus:         4
                    shutter_mode:    manual
                    flow_shutter_s:  20
                    closePeriodInFramesInAir:         0
                    openPeriodInFramesInAir:          1
                    assign_cpu_num:  7
                    en_timing_msg:   0
                    en_rotate:       1
                    existing instance of voxl-lepton-server found, attempting to stop it
                    trying address 0x2a
                    client "voxl-portal78592109" connected to channel 0  with client id 0
                    client "voxl-portal64940239" connected to channel 1  with client id 0
                    A J 2 Replies Last reply 1 Jul 2025, 04:54 Reply Quote 0
                    • A
                      @Jetson-Nano , this looks like a sensor issue. VOXL2 does not do any configuration of the sensor's parameters, other than it can change the calibration interval based on config file, I believe.
                      What you are seeing appears to be artifacts in the sensor itself, maybe due to noise on power rail(s). This is not an expected behavior, but it should not be caused by a SW configuration from the VOXL2 side.
                      J 1 Reply Last reply 1 Jul 2025, 13:41 Reply Quote 0
                      • J
                        @Alex-Kushleyev @Vinny @Eric-Katzfey @modaltb
                        I am currently in the process of designing a custom thermal breakout board intended for integration with the M0173 Coax Board.
                        As part of this configuration, I have already had the board manufactured. However, during testing, I observed that the VOXL2 Board is not recognizing the camera, and it throws the error message pinned at the top of this thread.
                        To ensure the design is moving in the right direction, I would like to request your feedback on the following:
                        -Whether the overall design approach is technically sound and compatible with the M0173 and VOXL2 systems.
                        -If there are any missing components or critical connections that may be causing communication or recognition issues.
                        I would greatly appreciate your time and expertise in reviewing the attached schematic of my breakout board.
                        Thanks.
                        VinnyV 1 Reply Last reply 1 Jul 2025, 14:23 Reply Quote 0
                        • VinnyV
                          Vinny ModalAI Team @Jetson Nano
                          Hi @Jetson-Nano
                          I do not see anything obviously wrong with your design, so we may be dealing with nuances that even we had to update our design for.
                          1. FLIR suggest to connect MOSI (pin 11) to GND, per page 45 of their spec
                          2a) There is a chance you have too much capacitance on the 2.8V rail. Our PMICs have limitations on the inrush specs and a 4.7uF I think puts that limit over the suggested amount by Qualcomm. I suggest lowering that to 2.2uF (what we use on our LDO) or even better 1uF. The 1.2V rail per specs (that I have which are a few years old) suggest the 1.2V rail only needs ~110mA
                          2b) We use a small LDO, not a DC/DC. Not sure if the Lepton is happy with the noise of a DC/DC compared to an LDO and having issues or not. For reference we use a 500mA LDO from TI (TPS7A11xx family)
                          2c) in relation to 2a above, what are the values of C3 and C2? If they are large (>=4.7uF) I suggest try lowering them to 2.2uF or 1uF's.
                          1. For reset, this is where we found the biggest issue with the Leptons. We actually have a I2C GPIO expander on our design to issue SW controlled resets of the Lepton. It is not the most stable sensor and frequent resets are required for good operation. Here is our circuit if you want to try it yourself: 12577500-c2f8-4b82-8fda-b409be323a48-image.png
                          For debugging your exact setup, one thing we do is validate if we hear the shutter click (or see the micro actuator move) on power up. Does your HW give that noticeable clicking when you try to power on? If not, you have a more serious issue such as a wrong PCB symbol or incorrect assembly.
                          Hope that helped.
                          Last resort, just use our M0187 design that we have for this. I'm not seeing it online for sale, but I can inquire with the team if we plan to make that available for individual use (it is embedded in Starling 2's now).
                          A J 2 Replies Last reply 1 Jul 2025, 14:27 Reply Quote 0
                          • A
                            Alex Kushleyev ModalAI Team @Vinny
                            I also double checked the schematic and did not notice anything wrong. Please follow Vinny’s suggestions 🙂 and definitely check if the Lepton is making the clicking sound, which would mean it is powered on, it should be clicking periodically in default mode after power on.
                            • J
                              Jetson Nano @Vinny
                              @Vinny @Alex-Kushleyev
                              Thank you for your invaluable feedback on the previous design. I have thoroughly reviewed your input and subsequently updated the schematic to incorporate the suggestions, specifically regarding the integration of an I2C GPIO expander. The updated schematic is attached for your review.
                              During recent debugging, I observed a critical issue: the Lepton module is not powering up, and no shutter sound is audible. This suggests a fundamental problem with power delivery or clocking to the module, which is currently preventing any functionality.
                              Concurrent to addressing this critical power-up issue, I would appreciate your expert insights on a few points concerning the updated design of the I2C GPIO expander and Lepton module interfacing:
                              • I2C Bus Configuration: Regarding the I2C bus, should the I2C lines be connected in parallel to both the Lepton Module and the I2C GPIO expander?
                              • Lepton Reset/Power Down Pins: Concerning the Lepton Module's RESET_N and POWER_DOWN_N pins, should the existing resistor-capacitor (RC) network connected to the RESET_N pin be retained, or can it be omitted?
                              • I2C GPIO Expander INT Pin: For the I2C GPIO expander, is it permissible to leave the INT (Interrupt) pin unconnected, or does it require termination?
                              • I2C GPIO Expander Software Configuration: From a software perspective, is the I2C GPIO expander a plug-and-play component, or does it require specific configuration?
                              Your guidance on both the immediate power-up challenge and the schematic queries would be greatly appreciated.
                              Thanks.
                              VinnyV 1 Reply Last reply 2 Jul 2025, 17:04 Reply Quote 0
                              • VinnyV
                                Hi @Jetson-Nano
                                Happy to continue helping.
                                Regarding your updated design first:
                                "I2C Bus Configuration: Regarding the I2C bus, should the I2C lines be connected in parallel to both the Lepton Module and the I2C GPIO expander?"
                                -- Yes.
                                "Lepton Reset/Power Down Pins: Concerning the Lepton Module's RESET_N and POWER_DOWN_N pins, should the existing resistor-capacitor (RC) network connected to the RESET_N pin be retained, or can it be omitted?"
                                -- We do not have any RC delay on the reset line since it is all GPIO controlled.
                                "I2C GPIO Expander INT Pin: For the I2C GPIO expander, is it permissible to leave the INT (Interrupt) pin unconnected, or does it require termination?"
                                -- It is an output and we do not use it, so N.C. is fine
                                -- It is supported at that HW address by default with voxl-lepton-server (I think that it what is called, Alex can correct me if I'm mistaken)
                                However, your updated SCH has a couple errors:
                                • Your LDO input and output caps are not correctly done. They are in series, not shunts to GND as required:0f7551cf-b798-4665-9673-a4df6182c21b-image.png
                                • The Pull-down R on the GPIO expander is not correct. The ADDR pin will always be HIGH due to the direct connection to 2.8V, but our default is LOW (see the snippet from above): f6ee80a1-e5fa-4635-b3dd-93c5ca85e501-image.png
                                • Also, the GPIO expander is meant to drive the RESET input of the Lepton, not the PWR_DWN input: eb4012fd-2528-4879-a1f6-d235568faa6e-image.png
                                Now, as to your existing board not powering on, I have a clue for you...
                                Our very first lepton board we failed to notice the pin 1 hole in the Molex socket, and that is important since it sets a keying for the Lepton module. If the module is inserted incorrectly (90 or 180 off) it will clearly not power up. Pay close attention to the hole in the socket for pin 1 and two vs one slots in the socket which set the orientation.
                                Keep us posted and hope this helped.
                                J 1 Reply Last reply 3 Jul 2025, 14:46 Reply Quote 0
                                • J
                                  Jetson Nano @Vinny
                                  Thank you for your valuable feedback on the previous version of the schematic. Based on your recommendations, I have revised the design accordingly.
                                  Please find the updated schematic attached below for your review
                                  In addition to the design changes, I have also revisited the hardware setup to verify the power delivery, the Lepton module is still not powering up—there is no shutter sound or I²C response. At this point, I have exhausted the immediate troubleshooting steps and would greatly appreciate your guidance on further debugging strategies.
                                  Could you please review the updated schematic and suggest any additional tests or possible points of failure that may have been overlooked?
                                  Thank you again for your support and expertise.
                                  VinnyV 1 Reply Last reply 3 Jul 2025, 16:36 Reply Quote 0
                                  • VinnyV
                                    Hi @Jetson-Nano
                                    Sch updates look correct. I'd still add a pull-up on the Lepton Reset to help control it during initial power-ON before the IO expander is configured.
                                    To help further debug your existing setup, I'd need more tangible info such as pictures with all your cables, etc. Do you have a DMM handy showing the voltages of 1.2V and 2.8V, and an O-scope for the 25MHz?
                                    Can you also post a pic of your board without components installed (so I can review the layout as best as possible)?
                                    It's hard to give much further guidance without actual hardware in my hands.
                                    J 1 Reply Last reply 13 days ago Reply Quote 0
                                    • J
                                      jared @Jetson Nano
                                      @Jetson-Nano did you ever figure out a solution to this? I'm getting similar imagery. Is this an FFC issue? Running the same breakout board on a raspberry pi produces completely normal imagery.
                                      K 1 Reply Last reply 28 days ago Reply Quote 0
                                      • K
                                        KLindgren @jared
                                        To close the loop here: we solved our issue of seeing lines by providing power to the lepton via one of the 3.3V pins on the voxl2 mini instead of relying on the power pin of J10 on the sparrow board.
                                        VinnyV 1 Reply Last reply 28 days ago Reply Quote 0
                                        • VinnyV
                                          Vinny ModalAI Team @KLindgren
                                          Hi @KLindgren
                                          You raise a concern and something I will run by the team, but if you are powering the M0187 at 3.3V directly, you are violating the FLIR specs for the Lepton and our system design constraints.
                                          How are you connecting M0187 to M0188? Maybe your cable is introducing some extra losses giving you a lower than 2.8V supply?
                                          • K
                                            KLindgren @Vinny
                                            @Vinny apologies, I should have clarified we're using this PureThermal breakout board which regulates VIN from 3.3-5V
                                            VinnyV J 2 Replies Last reply 28 days ago Reply Quote 0
