  3. ArduPilot on Voxl2
ArduPilot on Voxl2
flight-core-v2
45 Posts 6 Posters 28.6k Views 3 Watching
    @TomP I have updated the documentation at https://docs.modalai.com/voxl-ardupilot/. The VOXL 2 IO board with up to 4 PWM outputs is now supported and has been tested on a quadcopter with 4 PWM ESCs. You should be able to use this for arduplane now. We are putting together our own fixed wing test platform and hope to begin testing soon.
    @Eric-Katzfey I will need to add the support for up to 8 PWM outputs on VOXL 2 IO board. Right now it only supports 4. You should be able to do test flights without the gimbal with 4 PWM outputs.
    • T TomP
      @Eric-Katzfey We use GPS, compass and the IO board for a PWM-controlled ESC and two servos. We also need two more PWM channels for gimbal control. That's it.
      We do not use an RC. The control is purely via MAVLink. Joystick inputs are made via the MAVLink command MANUAL_CONTROL. Data is transmitted via the mobile network.
      @TomP The update to support all 8 PWM outputs from the IO board is now in mainline. You can get it in the latest build posted here: https://firmware.ardupilot.org/Copter/latest/QURT/
      • T Offline
        T Offline
        TomP
        How can I configure the battery monitor for ArduPlane on the VOXL2-Mini?
        Which value do I have to enter for BATT_MONITOR and which values for BATT_I2C_ADDR and BAT_I2C_BUS?
        The "VOXL 2 Mini Power" transmits the current and voltage measurement data via I2C.
        Best regards,
        Tom
        • T TomP
          Best regards,
          Tom
          @TomP It should just scan the available I2C ports and automatically detect the VOXL 2 mini power module if it has been connected. Is it not detecting it?
          T 1 Reply Last reply
            T Offline
            T Offline
            TomP
            @Eric-Katzfey No, this is not detected. The configuration does not seem to be correct either. The parameter list mentions "Analog Voltage and Current" and corresponding pins.
            Here is a screenshot:
            • T Offline
              T Offline
              TomP
              There is another problem. The PWM board does not output PWMs. I have also measured this with an oscilloscope. According to SERVO_OUTPUT_RAW, however, the FC should output PWM values.
              Do I have to set another parameter in Arduplane so that the VOXL 2 I/O Expander Board is controlled correctly?
              I use the VOXL2-Mini J19 connector: GND, pin 7, pin 8 and VREG_3P3V_RC for the power supply.
              Here is my setup:
              • T TomP
                Here is my setup:
                @TomP Okay, yes, sorry, you need to set BATT_MONITOR to 21 for INA2xx and need to set BATT_I2C_BUS to 1 for that power monitor to come up. I'll investigate the PWM issue.
                  T Offline
                  T Offline
                  TomP
                  @Eric-Katzfey The battery monitor works. Thank you very much! I'm sure the PWM will also work and then it's off to the test flight. 🙂
                  • T TomP
                    @TomP What are the settings of all the SERVO(x)_ params?
                    • T TomP
                      @TomP If you set the SERVO(x)_FUNCTION parameters according to this: https://ardupilot.org/plane/docs/servo-functions.html#overview do you get any PWM output?
                        T Offline
                        T Offline
                        TomP
                        wrote on last edited by TomP
                        #25
                        @Eric-Katzfey Here are my settings (no PWM output):
                        SERVO1_FUNCTION,4
                        SERVO1_MAX,1900
                        SERVO1_MIN,1100
                        SERVO1_REVERSED,0
                        SERVO1_TRIM,1500
                        SERVO2_FUNCTION,19
                        SERVO2_MAX,1900
                        SERVO2_MIN,1100
                        SERVO2_REVERSED,0
                        SERVO2_TRIM,1500
                        SERVO3_FUNCTION,70
                        SERVO3_MAX,1900
                        SERVO3_MIN,1100
                        SERVO3_REVERSED,0
                        SERVO3_TRIM,1100
                        SERVO4_FUNCTION,21
                        SERVO4_MAX,1900
                        SERVO4_MIN,1100
                        SERVO4_REVERSED,0
                        SERVO4_TRIM,1500
                        SERVO5_FUNCTION,0
                        SERVO5_MAX,1900
                        SERVO5_MIN,1100
                        SERVO5_REVERSED,0
                        SERVO5_TRIM,1500
                        SERVO6_FUNCTION,0
                        SERVO6_MAX,1900
                        SERVO6_MIN,1100
                        SERVO6_REVERSED,0
                        SERVO6_TRIM,1500
                        SERVO7_FUNCTION,0
                        SERVO7_MAX,1900
                        SERVO7_MIN,1100
                        SERVO7_REVERSED,0
                        SERVO7_TRIM,1500
                        SERVO8_FUNCTION,0
                        SERVO8_MAX,1900
                        SERVO8_MIN,1100
                        SERVO8_REVERSED,0
                        SERVO8_TRIM,1500
                        • T TomP
                          SERVO1_FUNCTION,4
                          SERVO1_MAX,1900
                          SERVO1_MIN,1100
                          SERVO1_REVERSED,0
                          SERVO1_TRIM,1500
                          SERVO2_FUNCTION,19
                          SERVO2_MAX,1900
                          SERVO2_MIN,1100
                          SERVO2_REVERSED,0
                          SERVO2_TRIM,1500
                          SERVO3_FUNCTION,70
                          SERVO3_MAX,1900
                          SERVO3_MIN,1100
                          SERVO3_REVERSED,0
                          SERVO3_TRIM,1100
                          SERVO4_FUNCTION,21
                          SERVO4_MAX,1900
                          SERVO4_MIN,1100
                          SERVO4_REVERSED,0
                          SERVO4_TRIM,1500
                          SERVO5_FUNCTION,0
                          SERVO5_MAX,1900
                          SERVO5_MIN,1100
                          SERVO5_REVERSED,0
                          SERVO5_TRIM,1500
                          SERVO6_FUNCTION,0
                          SERVO6_MAX,1900
                          SERVO6_MIN,1100
                          SERVO6_REVERSED,0
                          SERVO6_TRIM,1500
                          SERVO7_FUNCTION,0
                          SERVO7_MAX,1900
                          SERVO7_MIN,1100
                          SERVO7_REVERSED,0
                          SERVO7_TRIM,1500
                          SERVO8_FUNCTION,0
                          SERVO8_MAX,1900
                          SERVO8_MIN,1100
                          SERVO8_REVERSED,0
                          SERVO8_TRIM,1500
                          @TomP Hmm, that looks correct. On my test setup running ArduPlane with those values I see output values being sent to the M0065 board. I'm wondering if there is a connectivity issue between the VOXL 2 mini and the IO board.
                          • T TomP
                            SERVO1_FUNCTION,4
                            SERVO1_MAX,1900
                            SERVO1_MIN,1100
                            SERVO1_REVERSED,0
                            SERVO1_TRIM,1500
                            SERVO2_FUNCTION,19
                            SERVO2_MAX,1900
                            SERVO2_MIN,1100
                            SERVO2_REVERSED,0
                            SERVO2_TRIM,1500
                            SERVO3_FUNCTION,70
                            SERVO3_MAX,1900
                            SERVO3_MIN,1100
                            SERVO3_REVERSED,0
                            SERVO3_TRIM,1100
                            SERVO4_FUNCTION,21
                            SERVO4_MAX,1900
                            SERVO4_MIN,1100
                            SERVO4_REVERSED,0
                            SERVO4_TRIM,1500
                            SERVO5_FUNCTION,0
                            SERVO5_MAX,1900
                            SERVO5_MIN,1100
                            SERVO5_REVERSED,0
                            SERVO5_TRIM,1500
                            SERVO6_FUNCTION,0
                            SERVO6_MAX,1900
                            SERVO6_MIN,1100
                            SERVO6_REVERSED,0
                            SERVO6_TRIM,1500
                            SERVO7_FUNCTION,0
                            SERVO7_MAX,1900
                            SERVO7_MIN,1100
                            SERVO7_REVERSED,0
                            SERVO7_TRIM,1500
                            SERVO8_FUNCTION,0
                            SERVO8_MAX,1900
                            SERVO8_MIN,1100
                            SERVO8_REVERSED,0
                            SERVO8_TRIM,1500
                            @TomP Can you tell me how you have connected the UART pins on M0065 to the UART pins on VOXL 2 mini? Like the actual pin numbers that are connected?
                              T Offline
                              T Offline
                              TomP
                              @Eric-Katzfey I can rule out connection problems. I checked the contacts on the VOXL2-Mini and the IO board with a continuity tester. Everything is well connected.
                              I know that with ardupilot you can at least control the servos without arming. Is this perhaps implemented differently here? Then I would have to calibrate the sensors etc. to test this.
                                T Offline
                                T Offline
                                TomP
                                #29
                                @Eric-Katzfey Here is the pin configuration (J19 on VOXL2-Mini to J4 on IO Board):
                                VOXL2-Mini-----IO Board
                                9-----------------1
                                8-----------------3
                                7-----------------2
                                6-----------------4
                                (I mistyped the table at the beginning. I have corrected the typo.)
                                • T TomP
                                  9-----------------1
                                  8-----------------3
                                  7-----------------2
                                  6-----------------4
                                  @TomP Yep, that all looks fine. Shoot. I may need to send you a new package with extra debug information to help debug this since by default there really isn't much we can see.
                                  • T TomP
                                    9-----------------1
                                    8-----------------3
                                    7-----------------2
                                    6-----------------4
                                    @TomP Can you stop ardupilot and then run this command on VOXL 2 mini? voxl-2-io detect
                                      T Offline
                                      T Offline
                                      TomP
                                      @Eric-Katzfey said in ArduPilot on Voxl2:
                                      What do you mean by that?
                                      "a new package with extra debug information"
                                      • T TomP
                                        @TomP A new voxl-ardupilot package with debug information added. But we may not need that. Try voxl-2-io detect and then if that is successful then try voxl-2-io scan
                                          T Offline
                                          T Offline
                                          TomP
                                          #34
                                          voxl2-mini:~$ voxl-2-io detect
                                          enabling bridge
                                          bridge enabled
                                          [INFO] Detected VOXL2 IO on default port (2).
                                          ESC detected: ModalAi I/O Expander (M0065)
                                          disabling bridge
                                          bridge disabled
                                          voxl2-mini:~$ voxl-2-io scan
                                          enabling bridge
                                          bridge enabled
                                          Successfully pinged VOXL2 IO on default port (2).
                                          INFO: VOXL2 IO Information:
                                              Board      : version 35 : ModalAi I/O Expander (M0065)
                                              UID        : 0x8108322152518882066BFF54
                                              Firmware   : version 1, hash 6b5ec459
                                              Bootloader : version 0, hash 5ba5857f
                                          disabling bridge
                                          bridge disabled
