  3. ArduPilot on Voxl2
ArduPilot on Voxl2
flight-core-v2
45 Posts 6 Posters 28.6k Views 3 Watching
    @TomP Okay, yes, sorry, you need to set BATT_MONITOR to 21 for INA2xx and need to set BATT_I2C_BUS to 1 for that power monitor to come up. I'll investigate the PWM issue.
    T Offline
    T Offline
    TomP
    @Eric-Katzfey The battery monitor works. Thank you very much! I'm sure the PWM will also work and then it's off to the test flight. 🙂
    • T TomP
      @TomP What are the settings of all the SERVO(x)_ params?
      • T TomP
        @TomP If you set the SERVO(x)_FUNCTION parameters according to this: https://ardupilot.org/plane/docs/servo-functions.html#overview do you get any PWM output?
        T 1 Reply Last reply
          T Offline
          T Offline
          TomP
          wrote on last edited by TomP
          #25
          @Eric-Katzfey Here are my settings (no PWM output):
          SERVO1_FUNCTION,4
          SERVO1_MAX,1900
          SERVO1_MIN,1100
          SERVO1_REVERSED,0
          SERVO1_TRIM,1500
          SERVO2_FUNCTION,19
          SERVO2_MAX,1900
          SERVO2_MIN,1100
          SERVO2_REVERSED,0
          SERVO2_TRIM,1500
          SERVO3_FUNCTION,70
          SERVO3_MAX,1900
          SERVO3_MIN,1100
          SERVO3_REVERSED,0
          SERVO3_TRIM,1100
          SERVO4_FUNCTION,21
          SERVO4_MAX,1900
          SERVO4_MIN,1100
          SERVO4_REVERSED,0
          SERVO4_TRIM,1500
          SERVO5_FUNCTION,0
          SERVO5_MAX,1900
          SERVO5_MIN,1100
          SERVO5_REVERSED,0
          SERVO5_TRIM,1500
          SERVO6_FUNCTION,0
          SERVO6_MAX,1900
          SERVO6_MIN,1100
          SERVO6_REVERSED,0
          SERVO6_TRIM,1500
          SERVO7_FUNCTION,0
          SERVO7_MAX,1900
          SERVO7_MIN,1100
          SERVO7_REVERSED,0
          SERVO7_TRIM,1500
          SERVO8_FUNCTION,0
          SERVO8_MAX,1900
          SERVO8_MIN,1100
          SERVO8_REVERSED,0
          SERVO8_TRIM,1500
          • T TomP
            SERVO1_FUNCTION,4
            SERVO1_MAX,1900
            SERVO1_MIN,1100
            SERVO1_REVERSED,0
            SERVO1_TRIM,1500
            SERVO2_FUNCTION,19
            SERVO2_MAX,1900
            SERVO2_MIN,1100
            SERVO2_REVERSED,0
            SERVO2_TRIM,1500
            SERVO3_FUNCTION,70
            SERVO3_MAX,1900
            SERVO3_MIN,1100
            SERVO3_REVERSED,0
            SERVO3_TRIM,1100
            SERVO4_FUNCTION,21
            SERVO4_MAX,1900
            SERVO4_MIN,1100
            SERVO4_REVERSED,0
            SERVO4_TRIM,1500
            SERVO5_FUNCTION,0
            SERVO5_MAX,1900
            SERVO5_MIN,1100
            SERVO5_REVERSED,0
            SERVO5_TRIM,1500
            SERVO6_FUNCTION,0
            SERVO6_MAX,1900
            SERVO6_MIN,1100
            SERVO6_REVERSED,0
            SERVO6_TRIM,1500
            SERVO7_FUNCTION,0
            SERVO7_MAX,1900
            SERVO7_MIN,1100
            SERVO7_REVERSED,0
            SERVO7_TRIM,1500
            SERVO8_FUNCTION,0
            SERVO8_MAX,1900
            SERVO8_MIN,1100
            SERVO8_REVERSED,0
            SERVO8_TRIM,1500
            @TomP Hmm, that looks correct. On my test setup running ArduPlane with those values I see output values being sent to the M0065 board. I'm wondering if there is a connectivity issue between the VOXL 2 mini and the IO board.
            • T TomP
              SERVO1_FUNCTION,4
              SERVO1_MAX,1900
              SERVO1_MIN,1100
              SERVO1_REVERSED,0
              SERVO1_TRIM,1500
              SERVO2_FUNCTION,19
              SERVO2_MAX,1900
              SERVO2_MIN,1100
              SERVO2_REVERSED,0
              SERVO2_TRIM,1500
              SERVO3_FUNCTION,70
              SERVO3_MAX,1900
              SERVO3_MIN,1100
              SERVO3_REVERSED,0
              SERVO3_TRIM,1100
              SERVO4_FUNCTION,21
              SERVO4_MAX,1900
              SERVO4_MIN,1100
              SERVO4_REVERSED,0
              SERVO4_TRIM,1500
              SERVO5_FUNCTION,0
              SERVO5_MAX,1900
              SERVO5_MIN,1100
              SERVO5_REVERSED,0
              SERVO5_TRIM,1500
              SERVO6_FUNCTION,0
              SERVO6_MAX,1900
              SERVO6_MIN,1100
              SERVO6_REVERSED,0
              SERVO6_TRIM,1500
              SERVO7_FUNCTION,0
              SERVO7_MAX,1900
              SERVO7_MIN,1100
              SERVO7_REVERSED,0
              SERVO7_TRIM,1500
              SERVO8_FUNCTION,0
              SERVO8_MAX,1900
              SERVO8_MIN,1100
              SERVO8_REVERSED,0
              SERVO8_TRIM,1500
              @TomP Can you tell me how you have connected the UART pins on M0065 to the UART pins on VOXL 2 mini? Like the actual pin numbers that are connected?
                T Offline
                T Offline
                TomP
                @Eric-Katzfey I can rule out connection problems. I checked the contacts on the VOXL2-Mini and the IO board with a continuity tester. Everything is well connected.
                I know that with ardupilot you can at least control the servos without arming. Is this perhaps implemented differently here? Then I would have to calibrate the sensors etc. to test this.
                  T Offline
                  T Offline
                  TomP
                  #29
                  @Eric-Katzfey Here is the pin configuration (J19 on VOXL2-Mini to J4 on IO Board):
                  VOXL2-Mini-----IO Board
                  9-----------------1
                  8-----------------3
                  7-----------------2
                  6-----------------4
                  (I mistyped the table at the beginning. I have corrected the typo.)
                  • T TomP
                    9-----------------1
                    8-----------------3
                    7-----------------2
                    6-----------------4
                    @TomP Yep, that all looks fine. Shoot. I may need to send you a new package with extra debug information to help debug this since by default there really isn't much we can see.
                    • T TomP
                      9-----------------1
                      8-----------------3
                      7-----------------2
                      6-----------------4
                      @TomP Can you stop ardupilot and then run this command on VOXL 2 mini? voxl-2-io detect
                        T Offline
                        T Offline
                        TomP
                        @Eric-Katzfey said in ArduPilot on Voxl2:
                        What do you mean by that?
                        "a new package with extra debug information"
                        • T TomP
                          @TomP A new voxl-ardupilot package with debug information added. But we may not need that. Try voxl-2-io detect and then if that is successful then try voxl-2-io scan
                            T Offline
                            T Offline
                            TomP
                            #34
                            voxl2-mini:~$ voxl-2-io detect
                            enabling bridge
                            bridge enabled
                            [INFO] Detected VOXL2 IO on default port (2).
                            ESC detected: ModalAi I/O Expander (M0065)
                            disabling bridge
                            bridge disabled
                            voxl2-mini:~$ voxl-2-io scan
                            enabling bridge
                            bridge enabled
                            Successfully pinged VOXL2 IO on default port (2).
                            INFO: VOXL2 IO Information:
                                Board      : version 35 : ModalAi I/O Expander (M0065)
                                UID        : 0x8108322152518882066BFF54
                                Firmware   : version 1, hash 6b5ec459
                                Bootloader : version 0, hash 5ba5857f
                            disabling bridge
                            bridge disabled
                            • T TomP
                              enabling bridge
                              bridge enabled
                              disabling bridge
                              bridge disabled
                              enabling bridge
                              bridge enabled
                              disabling bridge
                              bridge disabled
                              @TomP Okay, I think that firmware needs to be upgraded. Can you try voxl-2-io and choose upgrade_firmware?
                              Eric KatzfeyE T 2 Replies Last reply
                                @Eric-Katzfey Or just voxl-2-io upgrade_firmware?
                                  T Offline
                                  T Offline
                                  TomP
                                  voxl-2-io
                                  It works! Many thanks for the great support! 🙂
                                  The firmware upgrade was the solution.
                                  • T TomP
                                    voxl-2-io
                                    #38
                                    @TomP Wonderful! So glad to hear. And I would really love to hear how the flight testing goes. We've never tried a VOXL 2 (or VOXL 2 mini) on a fixed wing (with ArduPilot) so be careful and triple check to make sure everything looks setup correctly before launching.
                                    T Sam KileyS 2 Replies Last reply
                                      T Offline
                                      T Offline
                                      TomP
                                      It is an honor for me to report. We will be careful. Of course, a crash can also occur independently of the VOXL2. This is a new drone that we are building.
                                      What might be relevant for you is that we have found a gimbal that will fit one of your cameras with a bit of hardware hacking. The gimbal can also be controlled via serial interface using Ardupilot. We have already successfully tested this with the VOXL2-Mini.
                                      • T TomP
                                        @TomP Oh, yes, this is all great news! Very exciting to hear! I will send an email to your account with some follow up questions.
                                          Sam KileyS Offline
                                          Sam KileyS Offline
                                          Sam Kiley
                                          I am also messing around with Ardupilot on a fixed wing, and wondering if any sort of voxl-io conf is needed for passthrough the PWM and CRSF RC? in a previous SDK, I believe there was a voxl-io-server, which no longer exists in 1.5 SDK, from what I can tell.
                                          I have upgraded the firmware and followed along with the rest of the thread.
                                          Thanks for any info.
