  3. ArduPilot on Voxl2
ArduPilot on Voxl2
flight-core-v2
45 Posts 6 Posters 28.6k Views 3 Watching
    @TomP Can you tell me how you have connected the UART pins on M0065 to the UART pins on VOXL 2 mini? Like the actual pin numbers that are connected?
    T Offline
    T Offline
    TomP
    wrote on last edited by TomP
    #29
    @Eric-Katzfey Here is the pin configuration (J19 on VOXL2-Mini to J4 on IO Board):
    VOXL2-Mini-----IO Board
    9-----------------1
    8-----------------3
    7-----------------2
    6-----------------4
    (I mistyped the table at the beginning. I have corrected the typo.)
    • T TomP
      9-----------------1
      8-----------------3
      7-----------------2
      6-----------------4
      @TomP Yep, that all looks fine. Shoot. I may need to send you a new package with extra debug information to help debug this since by default there really isn't much we can see.
      T 1 Reply Last reply
      • T TomP
        9-----------------1
        8-----------------3
        7-----------------2
        6-----------------4
        @TomP Can you stop ardupilot and then run this command on VOXL 2 mini? voxl-2-io detect
          T Offline
          T Offline
          TomP
          @Eric-Katzfey said in ArduPilot on Voxl2:
          What do you mean by that?
          "a new package with extra debug information"
          • T TomP
            @TomP A new voxl-ardupilot package with debug information added. But we may not need that. Try voxl-2-io detect and then if that is successful then try voxl-2-io scan
              T Offline
              T Offline
              TomP
              #34
              voxl2-mini:~$ voxl-2-io detect
              enabling bridge
              bridge enabled
              [INFO] Detected VOXL2 IO on default port (2).
              ESC detected: ModalAi I/O Expander (M0065)
              disabling bridge
              bridge disabled
              voxl2-mini:~$ voxl-2-io scan
              enabling bridge
              bridge enabled
              Successfully pinged VOXL2 IO on default port (2).
              INFO: VOXL2 IO Information:
                  Board      : version 35 : ModalAi I/O Expander (M0065)
                  UID        : 0x8108322152518882066BFF54
                  Firmware   : version 1, hash 6b5ec459
                  Bootloader : version 0, hash 5ba5857f
              disabling bridge
              bridge disabled
              • T TomP
                enabling bridge
                bridge enabled
                disabling bridge
                bridge disabled
                enabling bridge
                bridge enabled
                disabling bridge
                bridge disabled
                @TomP Okay, I think that firmware needs to be upgraded. Can you try voxl-2-io and choose upgrade_firmware?
                Eric KatzfeyE T 2 Replies Last reply
                  @Eric-Katzfey Or just voxl-2-io upgrade_firmware?
                    T Offline
                    T Offline
                    TomP
                    voxl-2-io
                    It works! Many thanks for the great support! 🙂
                    The firmware upgrade was the solution.
                    • T TomP
                      voxl-2-io
                      #38
                      @TomP Wonderful! So glad to hear. And I would really love to hear how the flight testing goes. We've never tried a VOXL 2 (or VOXL 2 mini) on a fixed wing (with ArduPilot) so be careful and triple check to make sure everything looks setup correctly before launching.
                      T Sam KileyS 2 Replies Last reply
                        T Offline
                        T Offline
                        TomP
                        It is an honor for me to report. We will be careful. Of course, a crash can also occur independently of the VOXL2. This is a new drone that we are building.
                        What might be relevant for you is that we have found a gimbal that will fit one of your cameras with a bit of hardware hacking. The gimbal can also be controlled via serial interface using Ardupilot. We have already successfully tested this with the VOXL2-Mini.
                        • T TomP
                          @TomP Oh, yes, this is all great news! Very exciting to hear! I will send an email to your account with some follow up questions.
                            Sam KileyS Offline
                            Sam KileyS Offline
                            Sam Kiley
                            I am also messing around with Ardupilot on a fixed wing, and wondering if any sort of voxl-io conf is needed for passthrough the PWM and CRSF RC? in a previous SDK, I believe there was a voxl-io-server, which no longer exists in 1.5 SDK, from what I can tell.
                            I have upgraded the firmware and followed along with the rest of the thread.
                            Thanks for any info.
                            • Sam KileyS Sam Kiley
                              @Sam-Kiley No need for any voxl-io configuration. voxl-io-server is for use with PX4, not ArduPilot. The ArduPilot firmware will detect if there is a VOXL ESC connected or a VOXL 2 IO board connected. If it detects the IO board then you will have up to 8 channels of PWM available.
                              Sam KileyS 1 Reply Last reply
                                Sam KileyS Offline
                                Sam KileyS Offline
                                Sam Kiley
                                wrote on last edited by Sam Kiley
                                #43
                                • A Offline
                                  adiprin1
                                  I would like to add a UART device to the starling 2 max running arducopter. can i use the VOXL 2 IO board's UART output to connect it to an a serial device? if so, what would the UART number be within arducopter?
                                  • A adiprin1
                                    @adiprin1 Can you please start a new forum topic for this? And please include information about the device that you are looking to attach? Thanks!
