  3. ArduPilot on Voxl2
ArduPilot on Voxl2
flight-core-v2
45 Posts 6 Posters 26.5k Views 3 Watching
    @TomP A new voxl-ardupilot package with debug information added. But we may not need that. Try voxl-2-io detect and then if that is successful then try voxl-2-io scan
    T Offline
    T Offline
    TomP
    wrote on last edited by TomP
    #34
    @Eric-Katzfey said in ArduPilot on Voxl2:
    voxl2-mini:~$ voxl-2-io detect
    enabling bridge
    bridge enabled
    [INFO] Detected VOXL2 IO on default port (2).
    ESC detected: ModalAi I/O Expander (M0065)
    disabling bridge
    bridge disabled
    voxl2-mini:~$ voxl-2-io scan
    enabling bridge
    bridge enabled
    Successfully pinged VOXL2 IO on default port (2).
    INFO: VOXL2 IO Information:
        Board      : version 35 : ModalAi I/O Expander (M0065)
        UID        : 0x8108322152518882066BFF54
        Firmware   : version 1, hash 6b5ec459
        Bootloader : version 0, hash 5ba5857f
    disabling bridge
    bridge disabled
    • T TomP
      enabling bridge
      bridge enabled
      disabling bridge
      bridge disabled
      enabling bridge
      bridge enabled
      disabling bridge
      bridge disabled
      @TomP Okay, I think that firmware needs to be upgraded. Can you try voxl-2-io and choose upgrade_firmware?
      Eric KatzfeyE T 2 Replies Last reply
        @Eric-Katzfey Or just voxl-2-io upgrade_firmware?
          T Offline
          T Offline
          TomP
          voxl-2-io
          It works! Many thanks for the great support! 🙂
          The firmware upgrade was the solution.
          • T TomP
            voxl-2-io
            #38
            @TomP Wonderful! So glad to hear. And I would really love to hear how the flight testing goes. We've never tried a VOXL 2 (or VOXL 2 mini) on a fixed wing (with ArduPilot) so be careful and triple check to make sure everything looks setup correctly before launching.
            T Sam KileyS 2 Replies Last reply
              T Offline
              T Offline
              TomP
              It is an honor for me to report. We will be careful. Of course, a crash can also occur independently of the VOXL2. This is a new drone that we are building.
              What might be relevant for you is that we have found a gimbal that will fit one of your cameras with a bit of hardware hacking. The gimbal can also be controlled via serial interface using Ardupilot. We have already successfully tested this with the VOXL2-Mini.
              • T TomP
                @TomP Oh, yes, this is all great news! Very exciting to hear! I will send an email to your account with some follow up questions.
                  Sam KileyS Offline
                  Sam KileyS Offline
                  Sam Kiley
                  I am also messing around with Ardupilot on a fixed wing, and wondering if any sort of voxl-io conf is needed for passthrough the PWM and CRSF RC? in a previous SDK, I believe there was a voxl-io-server, which no longer exists in 1.5 SDK, from what I can tell.
                  I have upgraded the firmware and followed along with the rest of the thread.
                  Thanks for any info.
                  • Sam KileyS Sam Kiley
                    @Sam-Kiley No need for any voxl-io configuration. voxl-io-server is for use with PX4, not ArduPilot. The ArduPilot firmware will detect if there is a VOXL ESC connected or a VOXL 2 IO board connected. If it detects the IO board then you will have up to 8 channels of PWM available.
                    Sam KileyS 1 Reply Last reply
                      Sam KileyS Offline
                      Sam KileyS Offline
                      Sam Kiley
                      wrote on last edited by Sam Kiley
                      #43
                      • A Offline
                        adiprin1
                        I would like to add a UART device to the starling 2 max running arducopter. can i use the VOXL 2 IO board's UART output to connect it to an a serial device? if so, what would the UART number be within arducopter?
                        • A adiprin1
                          @adiprin1 Can you please start a new forum topic for this? And please include information about the device that you are looking to attach? Thanks!
