  3. ArduPilot on Voxl2
ArduPilot on Voxl2
flight-core-v2
45 Posts 6 Posters 28.6k Views 3 Watching
  • T TomP
    @Eric-Katzfey The battery monitor works. Thank you very much! I'm sure the PWM will also work and then it's off to the test flight. 🙂
    @TomP What are the settings of all the SERVO(x)_ params?
    • T TomP
      @TomP If you set the SERVO(x)_FUNCTION parameters according to this: https://ardupilot.org/plane/docs/servo-functions.html#overview do you get any PWM output?
      T 1 Reply Last reply
        T Offline
        T Offline
        TomP
        wrote on last edited by TomP
        #25
        @Eric-Katzfey Here are my settings (no PWM output):
        SERVO1_FUNCTION,4
        SERVO1_MAX,1900
        SERVO1_MIN,1100
        SERVO1_REVERSED,0
        SERVO1_TRIM,1500
        SERVO2_FUNCTION,19
        SERVO2_MAX,1900
        SERVO2_MIN,1100
        SERVO2_REVERSED,0
        SERVO2_TRIM,1500
        SERVO3_FUNCTION,70
        SERVO3_MAX,1900
        SERVO3_MIN,1100
        SERVO3_REVERSED,0
        SERVO3_TRIM,1100
        SERVO4_FUNCTION,21
        SERVO4_MAX,1900
        SERVO4_MIN,1100
        SERVO4_REVERSED,0
        SERVO4_TRIM,1500
        SERVO5_FUNCTION,0
        SERVO5_MAX,1900
        SERVO5_MIN,1100
        SERVO5_REVERSED,0
        SERVO5_TRIM,1500
        SERVO6_FUNCTION,0
        SERVO6_MAX,1900
        SERVO6_MIN,1100
        SERVO6_REVERSED,0
        SERVO6_TRIM,1500
        SERVO7_FUNCTION,0
        SERVO7_MAX,1900
        SERVO7_MIN,1100
        SERVO7_REVERSED,0
        SERVO7_TRIM,1500
        SERVO8_FUNCTION,0
        SERVO8_MAX,1900
        SERVO8_MIN,1100
        SERVO8_REVERSED,0
        SERVO8_TRIM,1500
        • T TomP
          SERVO1_FUNCTION,4
          SERVO1_MAX,1900
          SERVO1_MIN,1100
          SERVO1_REVERSED,0
          SERVO1_TRIM,1500
          SERVO2_FUNCTION,19
          SERVO2_MAX,1900
          SERVO2_MIN,1100
          SERVO2_REVERSED,0
          SERVO2_TRIM,1500
          SERVO3_FUNCTION,70
          SERVO3_MAX,1900
          SERVO3_MIN,1100
          SERVO3_REVERSED,0
          SERVO3_TRIM,1100
          SERVO4_FUNCTION,21
          SERVO4_MAX,1900
          SERVO4_MIN,1100
          SERVO4_REVERSED,0
          SERVO4_TRIM,1500
          SERVO5_FUNCTION,0
          SERVO5_MAX,1900
          SERVO5_MIN,1100
          SERVO5_REVERSED,0
          SERVO5_TRIM,1500
          SERVO6_FUNCTION,0
          SERVO6_MAX,1900
          SERVO6_MIN,1100
          SERVO6_REVERSED,0
          SERVO6_TRIM,1500
          SERVO7_FUNCTION,0
          SERVO7_MAX,1900
          SERVO7_MIN,1100
          SERVO7_REVERSED,0
          SERVO7_TRIM,1500
          SERVO8_FUNCTION,0
          SERVO8_MAX,1900
          SERVO8_MIN,1100
          SERVO8_REVERSED,0
          SERVO8_TRIM,1500
          @TomP Hmm, that looks correct. On my test setup running ArduPlane with those values I see output values being sent to the M0065 board. I'm wondering if there is a connectivity issue between the VOXL 2 mini and the IO board.
          • T TomP
            SERVO1_FUNCTION,4
            SERVO1_MAX,1900
            SERVO1_MIN,1100
            SERVO1_REVERSED,0
            SERVO1_TRIM,1500
            SERVO2_FUNCTION,19
            SERVO2_MAX,1900
            SERVO2_MIN,1100
            SERVO2_REVERSED,0
            SERVO2_TRIM,1500
            SERVO3_FUNCTION,70
            SERVO3_MAX,1900
            SERVO3_MIN,1100
            SERVO3_REVERSED,0
            SERVO3_TRIM,1100
            SERVO4_FUNCTION,21
            SERVO4_MAX,1900
            SERVO4_MIN,1100
            SERVO4_REVERSED,0
            SERVO4_TRIM,1500
            SERVO5_FUNCTION,0
            SERVO5_MAX,1900
            SERVO5_MIN,1100
            SERVO5_REVERSED,0
            SERVO5_TRIM,1500
            SERVO6_FUNCTION,0
            SERVO6_MAX,1900
            SERVO6_MIN,1100
            SERVO6_REVERSED,0
            SERVO6_TRIM,1500
            SERVO7_FUNCTION,0
            SERVO7_MAX,1900
            SERVO7_MIN,1100
            SERVO7_REVERSED,0
            SERVO7_TRIM,1500
            SERVO8_FUNCTION,0
            SERVO8_MAX,1900
            SERVO8_MIN,1100
            SERVO8_REVERSED,0
            SERVO8_TRIM,1500
            @TomP Can you tell me how you have connected the UART pins on M0065 to the UART pins on VOXL 2 mini? Like the actual pin numbers that are connected?
              T Offline
              T Offline
              TomP
              @Eric-Katzfey I can rule out connection problems. I checked the contacts on the VOXL2-Mini and the IO board with a continuity tester. Everything is well connected.
              I know that with ardupilot you can at least control the servos without arming. Is this perhaps implemented differently here? Then I would have to calibrate the sensors etc. to test this.
                T Offline
                T Offline
                TomP
                #29
                @Eric-Katzfey Here is the pin configuration (J19 on VOXL2-Mini to J4 on IO Board):
                VOXL2-Mini-----IO Board
                9-----------------1
                8-----------------3
                7-----------------2
                6-----------------4
                (I mistyped the table at the beginning. I have corrected the typo.)
                • T TomP
                  9-----------------1
                  8-----------------3
                  7-----------------2
                  6-----------------4
                  @TomP Yep, that all looks fine. Shoot. I may need to send you a new package with extra debug information to help debug this since by default there really isn't much we can see.
                  • T TomP
                    9-----------------1
                    8-----------------3
                    7-----------------2
                    6-----------------4
                    @TomP Can you stop ardupilot and then run this command on VOXL 2 mini? voxl-2-io detect
                      T Offline
                      T Offline
                      TomP
                      @Eric-Katzfey said in ArduPilot on Voxl2:
                      What do you mean by that?
                      "a new package with extra debug information"
                      • T TomP
                        @TomP A new voxl-ardupilot package with debug information added. But we may not need that. Try voxl-2-io detect and then if that is successful then try voxl-2-io scan
                          T Offline
                          T Offline
                          TomP
                          #34
                          voxl2-mini:~$ voxl-2-io detect
                          enabling bridge
                          bridge enabled
                          [INFO] Detected VOXL2 IO on default port (2).
                          ESC detected: ModalAi I/O Expander (M0065)
                          disabling bridge
                          bridge disabled
                          voxl2-mini:~$ voxl-2-io scan
                          enabling bridge
                          bridge enabled
                          Successfully pinged VOXL2 IO on default port (2).
                          INFO: VOXL2 IO Information:
                              Board      : version 35 : ModalAi I/O Expander (M0065)
                              UID        : 0x8108322152518882066BFF54
                              Firmware   : version 1, hash 6b5ec459
                              Bootloader : version 0, hash 5ba5857f
                          disabling bridge
                          bridge disabled
                          • T TomP
                            enabling bridge
                            bridge enabled
                            disabling bridge
                            bridge disabled
                            enabling bridge
                            bridge enabled
                            disabling bridge
                            bridge disabled
                            @TomP Okay, I think that firmware needs to be upgraded. Can you try voxl-2-io and choose upgrade_firmware?
                            Eric KatzfeyE T 2 Replies Last reply
                              @Eric-Katzfey Or just voxl-2-io upgrade_firmware?
                                T Offline
                                T Offline
                                TomP
                                voxl-2-io
                                It works! Many thanks for the great support! 🙂
                                The firmware upgrade was the solution.
                                • T TomP
                                  voxl-2-io
                                  #38
                                  @TomP Wonderful! So glad to hear. And I would really love to hear how the flight testing goes. We've never tried a VOXL 2 (or VOXL 2 mini) on a fixed wing (with ArduPilot) so be careful and triple check to make sure everything looks setup correctly before launching.
                                  T Sam KileyS 2 Replies Last reply
                                    T Offline
                                    T Offline
                                    TomP
                                    It is an honor for me to report. We will be careful. Of course, a crash can also occur independently of the VOXL2. This is a new drone that we are building.
                                    What might be relevant for you is that we have found a gimbal that will fit one of your cameras with a bit of hardware hacking. The gimbal can also be controlled via serial interface using Ardupilot. We have already successfully tested this with the VOXL2-Mini.
                                    • T TomP
                                      @TomP Oh, yes, this is all great news! Very exciting to hear! I will send an email to your account with some follow up questions.
                                        Sam KileyS Offline
                                        Sam KileyS Offline
                                        Sam Kiley
                                        I am also messing around with Ardupilot on a fixed wing, and wondering if any sort of voxl-io conf is needed for passthrough the PWM and CRSF RC? in a previous SDK, I believe there was a voxl-io-server, which no longer exists in 1.5 SDK, from what I can tell.
                                        I have upgraded the firmware and followed along with the rest of the thread.
                                        Thanks for any info.
                                        • Sam KileyS Sam Kiley
                                          @Sam-Kiley No need for any voxl-io configuration. voxl-io-server is for use with PX4, not ArduPilot. The ArduPilot firmware will detect if there is a VOXL ESC connected or a VOXL 2 IO board connected. If it detects the IO board then you will have up to 8 channels of PWM available.
                                          Sam KileyS 1 Reply Last reply
