  3. ArduPilot on Voxl2
ArduPilot on Voxl2
flight-core-v2
45 Posts 6 Posters 28.6k Views 3 Watching
  • T Offline
    T Offline
    TomP
    How can I configure the battery monitor for ArduPlane on the VOXL2-Mini?
    Which value do I have to enter for BATT_MONITOR and which values for BATT_I2C_ADDR and BAT_I2C_BUS?
    The "VOXL 2 Mini Power" transmits the current and voltage measurement data via I2C.
    Best regards,
    Tom
    • T TomP
      Best regards,
      Tom
      @TomP It should just scan the available I2C ports and automatically detect the VOXL 2 mini power module if it has been connected. Is it not detecting it?
      T 1 Reply Last reply
        T Offline
        T Offline
        TomP
        @Eric-Katzfey No, this is not detected. The configuration does not seem to be correct either. The parameter list mentions "Analog Voltage and Current" and corresponding pins.
        Here is a screenshot:
        • T Offline
          T Offline
          TomP
          There is another problem. The PWM board does not output PWMs. I have also measured this with an oscilloscope. According to SERVO_OUTPUT_RAW, however, the FC should output PWM values.
          Do I have to set another parameter in Arduplane so that the VOXL 2 I/O Expander Board is controlled correctly?
          I use the VOXL2-Mini J19 connector: GND, pin 7, pin 8 and VREG_3P3V_RC for the power supply.
          Here is my setup:
          • T TomP
            Here is my setup:
            @TomP Okay, yes, sorry, you need to set BATT_MONITOR to 21 for INA2xx and need to set BATT_I2C_BUS to 1 for that power monitor to come up. I'll investigate the PWM issue.
              T Offline
              T Offline
              TomP
              @Eric-Katzfey The battery monitor works. Thank you very much! I'm sure the PWM will also work and then it's off to the test flight. 🙂
              • T TomP
                @TomP What are the settings of all the SERVO(x)_ params?
                • T TomP
                  @TomP If you set the SERVO(x)_FUNCTION parameters according to this: https://ardupilot.org/plane/docs/servo-functions.html#overview do you get any PWM output?
                    T Offline
                    T Offline
                    TomP
                    wrote on last edited by TomP
                    #25
                    @Eric-Katzfey Here are my settings (no PWM output):
                    SERVO1_FUNCTION,4
                    SERVO1_MAX,1900
                    SERVO1_MIN,1100
                    SERVO1_REVERSED,0
                    SERVO1_TRIM,1500
                    SERVO2_FUNCTION,19
                    SERVO2_MAX,1900
                    SERVO2_MIN,1100
                    SERVO2_REVERSED,0
                    SERVO2_TRIM,1500
                    SERVO3_FUNCTION,70
                    SERVO3_MAX,1900
                    SERVO3_MIN,1100
                    SERVO3_REVERSED,0
                    SERVO3_TRIM,1100
                    SERVO4_FUNCTION,21
                    SERVO4_MAX,1900
                    SERVO4_MIN,1100
                    SERVO4_REVERSED,0
                    SERVO4_TRIM,1500
                    SERVO5_FUNCTION,0
                    SERVO5_MAX,1900
                    SERVO5_MIN,1100
                    SERVO5_REVERSED,0
                    SERVO5_TRIM,1500
                    SERVO6_FUNCTION,0
                    SERVO6_MAX,1900
                    SERVO6_MIN,1100
                    SERVO6_REVERSED,0
                    SERVO6_TRIM,1500
                    SERVO7_FUNCTION,0
                    SERVO7_MAX,1900
                    SERVO7_MIN,1100
                    SERVO7_REVERSED,0
                    SERVO7_TRIM,1500
                    SERVO8_FUNCTION,0
                    SERVO8_MAX,1900
                    SERVO8_MIN,1100
                    SERVO8_REVERSED,0
                    SERVO8_TRIM,1500
                    • T TomP
                      SERVO1_FUNCTION,4
                      SERVO1_MAX,1900
                      SERVO1_MIN,1100
                      SERVO1_REVERSED,0
                      SERVO1_TRIM,1500
                      SERVO2_FUNCTION,19
                      SERVO2_MAX,1900
                      SERVO2_MIN,1100
                      SERVO2_REVERSED,0
                      SERVO2_TRIM,1500
                      SERVO3_FUNCTION,70
                      SERVO3_MAX,1900
                      SERVO3_MIN,1100
                      SERVO3_REVERSED,0
                      SERVO3_TRIM,1100
                      SERVO4_FUNCTION,21
                      SERVO4_MAX,1900
                      SERVO4_MIN,1100
                      SERVO4_REVERSED,0
                      SERVO4_TRIM,1500
                      SERVO5_FUNCTION,0
                      SERVO5_MAX,1900
                      SERVO5_MIN,1100
                      SERVO5_REVERSED,0
                      SERVO5_TRIM,1500
                      SERVO6_FUNCTION,0
                      SERVO6_MAX,1900
                      SERVO6_MIN,1100
                      SERVO6_REVERSED,0
                      SERVO6_TRIM,1500
                      SERVO7_FUNCTION,0
                      SERVO7_MAX,1900
                      SERVO7_MIN,1100
                      SERVO7_REVERSED,0
                      SERVO7_TRIM,1500
                      SERVO8_FUNCTION,0
                      SERVO8_MAX,1900
                      SERVO8_MIN,1100
                      SERVO8_REVERSED,0
                      SERVO8_TRIM,1500
                      @TomP Hmm, that looks correct. On my test setup running ArduPlane with those values I see output values being sent to the M0065 board. I'm wondering if there is a connectivity issue between the VOXL 2 mini and the IO board.
                      • T TomP
                        SERVO1_FUNCTION,4
                        SERVO1_MAX,1900
                        SERVO1_MIN,1100
                        SERVO1_REVERSED,0
                        SERVO1_TRIM,1500
                        SERVO2_FUNCTION,19
                        SERVO2_MAX,1900
                        SERVO2_MIN,1100
                        SERVO2_REVERSED,0
                        SERVO2_TRIM,1500
                        SERVO3_FUNCTION,70
                        SERVO3_MAX,1900
                        SERVO3_MIN,1100
                        SERVO3_REVERSED,0
                        SERVO3_TRIM,1100
                        SERVO4_FUNCTION,21
                        SERVO4_MAX,1900
                        SERVO4_MIN,1100
                        SERVO4_REVERSED,0
                        SERVO4_TRIM,1500
                        SERVO5_FUNCTION,0
                        SERVO5_MAX,1900
                        SERVO5_MIN,1100
                        SERVO5_REVERSED,0
                        SERVO5_TRIM,1500
                        SERVO6_FUNCTION,0
                        SERVO6_MAX,1900
                        SERVO6_MIN,1100
                        SERVO6_REVERSED,0
                        SERVO6_TRIM,1500
                        SERVO7_FUNCTION,0
                        SERVO7_MAX,1900
                        SERVO7_MIN,1100
                        SERVO7_REVERSED,0
                        SERVO7_TRIM,1500
                        SERVO8_FUNCTION,0
                        SERVO8_MAX,1900
                        SERVO8_MIN,1100
                        SERVO8_REVERSED,0
                        SERVO8_TRIM,1500
                        @TomP Can you tell me how you have connected the UART pins on M0065 to the UART pins on VOXL 2 mini? Like the actual pin numbers that are connected?
                          T Offline
                          T Offline
                          TomP
                          @Eric-Katzfey I can rule out connection problems. I checked the contacts on the VOXL2-Mini and the IO board with a continuity tester. Everything is well connected.
                          I know that with ardupilot you can at least control the servos without arming. Is this perhaps implemented differently here? Then I would have to calibrate the sensors etc. to test this.
                            T Offline
                            T Offline
                            TomP
                            #29
                            @Eric-Katzfey Here is the pin configuration (J19 on VOXL2-Mini to J4 on IO Board):
                            VOXL2-Mini-----IO Board
                            9-----------------1
                            8-----------------3
                            7-----------------2
                            6-----------------4
                            (I mistyped the table at the beginning. I have corrected the typo.)
                            • T TomP
                              9-----------------1
                              8-----------------3
                              7-----------------2
                              6-----------------4
                              @TomP Yep, that all looks fine. Shoot. I may need to send you a new package with extra debug information to help debug this since by default there really isn't much we can see.
                              • T TomP
                                9-----------------1
                                8-----------------3
                                7-----------------2
                                6-----------------4
                                @TomP Can you stop ardupilot and then run this command on VOXL 2 mini? voxl-2-io detect
                                  T Offline
                                  T Offline
                                  TomP
                                  @Eric-Katzfey said in ArduPilot on Voxl2:
                                  What do you mean by that?
                                  "a new package with extra debug information"
                                  • T TomP
                                    @TomP A new voxl-ardupilot package with debug information added. But we may not need that. Try voxl-2-io detect and then if that is successful then try voxl-2-io scan
                                      T Offline
                                      T Offline
                                      TomP
                                      #34
                                      voxl2-mini:~$ voxl-2-io detect
                                      enabling bridge
                                      bridge enabled
                                      [INFO] Detected VOXL2 IO on default port (2).
                                      ESC detected: ModalAi I/O Expander (M0065)
                                      disabling bridge
                                      bridge disabled
                                      voxl2-mini:~$ voxl-2-io scan
                                      enabling bridge
                                      bridge enabled
                                      Successfully pinged VOXL2 IO on default port (2).
                                      INFO: VOXL2 IO Information:
                                          Board      : version 35 : ModalAi I/O Expander (M0065)
                                          UID        : 0x8108322152518882066BFF54
                                          Firmware   : version 1, hash 6b5ec459
                                          Bootloader : version 0, hash 5ba5857f
                                      disabling bridge
                                      bridge disabled
                                      • T TomP
                                        enabling bridge
                                        bridge enabled
                                        disabling bridge
                                        bridge disabled
                                        enabling bridge
                                        bridge enabled
                                        disabling bridge
                                        bridge disabled
                                        @TomP Okay, I think that firmware needs to be upgraded. Can you try voxl-2-io and choose upgrade_firmware?
                                        Eric KatzfeyE T 2 Replies Last reply
                                          @Eric-Katzfey Or just voxl-2-io upgrade_firmware?
