  3. ArduPilot on Voxl2
ArduPilot on Voxl2
flight-core-v2
45 Posts 6 Posters 28.6k Views 3 Watching
  • T TomP
    @Eric-Katzfey When could the support for this be added?
    @TomP said in ArduPilot on Voxl2:
    Unfortunately, we don't have a fixed date for that support yet. We are striving to support ArduPilot on VOXL 2 by end of this year and that would include support for the IO board. Otherwise I would say keep your eye on the commits going in to AP to see if something comes in sooner.
    T 2 Replies Last reply
      T Offline
      T Offline
      TomP
      @Eric-Katzfey That is a manageable period of time for me. We can use it to plan our product roadmap. Thank you very much and keep up the good work.
        T Offline
        T Offline
        TomP
        @Eric-Katzfey Is there an update on the timeline yet?
        Best regards
        Tom
        • Andrew TridgellA Andrew Tridgell
          Support for ArduPilot on QURT (the RTOS used on Voxl-2) is now merged in ArduPilot master
          Basic instructions on building and installing are here:
          https://github.com/ArduPilot/ardupilot/tree/master/libraries/AP_HAL_QURT/ap_host/service
          Pre-built binaries are available here:
          • https://firmware.ardupilot.org/Copter/latest/QURT/
          • https://firmware.ardupilot.org/Plane/latest/QURT/
          • https://firmware.ardupilot.org/Rover/latest/QURT/
          This should still be considered experimemtal, with active development happening with @Eric-Katzfey and myself.
          Flight video here on an autonomy dev kit copter:
          https://www.youtube.com/watch?v=l6c65-E-lzg
          Enjoy!
          T Offline
          T Offline
          TomP
          @Andrew-Tridgell @Eric-Katzfey I wanted to ask again about the current roadmap regarding Arduplane and the IO board for PWM.
          Best regards
          Tom
          • T TomP
            Best regards
            Tom
            @TomP We are still shooting for the end of this year. I would like to know what external peripherals you would like to support though. I'm guessing GPS, magnetometer, RC, a PWM based motor ESC, and some servos for flight surface control? Also an airspeed sensor? A distance sensor? What kind of RC are you expecting to use? There are some I/O limitations with VOXL 2 so want to make sure that what you want to build can be supported by what we are putting together.
            T 1 Reply Last reply
              T Offline
              T Offline
              TomP
              @Eric-Katzfey We use GPS, compass and the IO board for a PWM-controlled ESC and two servos. We also need two more PWM channels for gimbal control. That's it.
              We do not use an RC. The control is purely via MAVLink. Joystick inputs are made via the MAVLink command MANUAL_CONTROL. Data is transmitted via the mobile network.
              • T TomP
                @TomP I have updated the documentation at https://docs.modalai.com/voxl-ardupilot/. The VOXL 2 IO board with up to 4 PWM outputs is now supported and has been tested on a quadcopter with 4 PWM ESCs. You should be able to use this for arduplane now. We are putting together our own fixed wing test platform and hope to begin testing soon.
                  @Eric-Katzfey I will need to add the support for up to 8 PWM outputs on VOXL 2 IO board. Right now it only supports 4. You should be able to do test flights without the gimbal with 4 PWM outputs.
                  • T TomP
                    @TomP The update to support all 8 PWM outputs from the IO board is now in mainline. You can get it in the latest build posted here: https://firmware.ardupilot.org/Copter/latest/QURT/
                    • T Offline
                      T Offline
                      TomP
                      How can I configure the battery monitor for ArduPlane on the VOXL2-Mini?
                      Which value do I have to enter for BATT_MONITOR and which values for BATT_I2C_ADDR and BAT_I2C_BUS?
                      The "VOXL 2 Mini Power" transmits the current and voltage measurement data via I2C.
                      Best regards,
                      Tom
                      • T TomP
                        Best regards,
                        Tom
                        @TomP It should just scan the available I2C ports and automatically detect the VOXL 2 mini power module if it has been connected. Is it not detecting it?
                          T Offline
                          T Offline
                          TomP
                          @Eric-Katzfey No, this is not detected. The configuration does not seem to be correct either. The parameter list mentions "Analog Voltage and Current" and corresponding pins.
                          Here is a screenshot:
                          • T Offline
                            T Offline
                            TomP
                            There is another problem. The PWM board does not output PWMs. I have also measured this with an oscilloscope. According to SERVO_OUTPUT_RAW, however, the FC should output PWM values.
                            Do I have to set another parameter in Arduplane so that the VOXL 2 I/O Expander Board is controlled correctly?
                            I use the VOXL2-Mini J19 connector: GND, pin 7, pin 8 and VREG_3P3V_RC for the power supply.
                            Here is my setup:
                            • T TomP
                              Here is my setup:
                              @TomP Okay, yes, sorry, you need to set BATT_MONITOR to 21 for INA2xx and need to set BATT_I2C_BUS to 1 for that power monitor to come up. I'll investigate the PWM issue.
                                T Offline
                                T Offline
                                TomP
                                @Eric-Katzfey The battery monitor works. Thank you very much! I'm sure the PWM will also work and then it's off to the test flight. 🙂
                                • T TomP
                                  @TomP What are the settings of all the SERVO(x)_ params?
                                  • T TomP
                                    @TomP If you set the SERVO(x)_FUNCTION parameters according to this: https://ardupilot.org/plane/docs/servo-functions.html#overview do you get any PWM output?
                                      T Offline
                                      T Offline
                                      TomP
                                      wrote on last edited by TomP
                                      #25
                                      @Eric-Katzfey Here are my settings (no PWM output):
                                      SERVO1_FUNCTION,4
                                      SERVO1_MAX,1900
                                      SERVO1_MIN,1100
                                      SERVO1_REVERSED,0
                                      SERVO1_TRIM,1500
                                      SERVO2_FUNCTION,19
                                      SERVO2_MAX,1900
                                      SERVO2_MIN,1100
                                      SERVO2_REVERSED,0
                                      SERVO2_TRIM,1500
                                      SERVO3_FUNCTION,70
                                      SERVO3_MAX,1900
                                      SERVO3_MIN,1100
                                      SERVO3_REVERSED,0
                                      SERVO3_TRIM,1100
                                      SERVO4_FUNCTION,21
                                      SERVO4_MAX,1900
                                      SERVO4_MIN,1100
                                      SERVO4_REVERSED,0
                                      SERVO4_TRIM,1500
                                      SERVO5_FUNCTION,0
                                      SERVO5_MAX,1900
                                      SERVO5_MIN,1100
                                      SERVO5_REVERSED,0
                                      SERVO5_TRIM,1500
                                      SERVO6_FUNCTION,0
                                      SERVO6_MAX,1900
                                      SERVO6_MIN,1100
                                      SERVO6_REVERSED,0
                                      SERVO6_TRIM,1500
                                      SERVO7_FUNCTION,0
                                      SERVO7_MAX,1900
                                      SERVO7_MIN,1100
                                      SERVO7_REVERSED,0
                                      SERVO7_TRIM,1500
                                      SERVO8_FUNCTION,0
                                      SERVO8_MAX,1900
                                      SERVO8_MIN,1100
                                      SERVO8_REVERSED,0
                                      SERVO8_TRIM,1500
                                      • T TomP
                                        SERVO1_FUNCTION,4
                                        SERVO1_MAX,1900
                                        SERVO1_MIN,1100
                                        SERVO1_REVERSED,0
                                        SERVO1_TRIM,1500
                                        SERVO2_FUNCTION,19
                                        SERVO2_MAX,1900
                                        SERVO2_MIN,1100
                                        SERVO2_REVERSED,0
                                        SERVO2_TRIM,1500
                                        SERVO3_FUNCTION,70
                                        SERVO3_MAX,1900
                                        SERVO3_MIN,1100
                                        SERVO3_REVERSED,0
                                        SERVO3_TRIM,1100
                                        SERVO4_FUNCTION,21
                                        SERVO4_MAX,1900
                                        SERVO4_MIN,1100
                                        SERVO4_REVERSED,0
                                        SERVO4_TRIM,1500
                                        SERVO5_FUNCTION,0
                                        SERVO5_MAX,1900
                                        SERVO5_MIN,1100
                                        SERVO5_REVERSED,0
                                        SERVO5_TRIM,1500
                                        SERVO6_FUNCTION,0
                                        SERVO6_MAX,1900
                                        SERVO6_MIN,1100
                                        SERVO6_REVERSED,0
                                        SERVO6_TRIM,1500
                                        SERVO7_FUNCTION,0
                                        SERVO7_MAX,1900
                                        SERVO7_MIN,1100
                                        SERVO7_REVERSED,0
                                        SERVO7_TRIM,1500
                                        SERVO8_FUNCTION,0
                                        SERVO8_MAX,1900
                                        SERVO8_MIN,1100
                                        SERVO8_REVERSED,0
                                        SERVO8_TRIM,1500
                                        @TomP Hmm, that looks correct. On my test setup running ArduPlane with those values I see output values being sent to the M0065 board. I'm wondering if there is a connectivity issue between the VOXL 2 mini and the IO board.
                                        • T TomP
                                          SERVO1_FUNCTION,4
                                          SERVO1_MAX,1900
                                          SERVO1_MIN,1100
                                          SERVO1_REVERSED,0
                                          SERVO1_TRIM,1500
                                          SERVO2_FUNCTION,19
                                          SERVO2_MAX,1900
                                          SERVO2_MIN,1100
                                          SERVO2_REVERSED,0
                                          SERVO2_TRIM,1500
                                          SERVO3_FUNCTION,70
                                          SERVO3_MAX,1900
                                          SERVO3_MIN,1100
                                          SERVO3_REVERSED,0
                                          SERVO3_TRIM,1100
                                          SERVO4_FUNCTION,21
                                          SERVO4_MAX,1900
                                          SERVO4_MIN,1100
                                          SERVO4_REVERSED,0
                                          SERVO4_TRIM,1500
                                          SERVO5_FUNCTION,0
                                          SERVO5_MAX,1900
                                          SERVO5_MIN,1100
                                          SERVO5_REVERSED,0
                                          SERVO5_TRIM,1500
                                          SERVO6_FUNCTION,0
                                          SERVO6_MAX,1900
                                          SERVO6_MIN,1100
                                          SERVO6_REVERSED,0
                                          SERVO6_TRIM,1500
                                          SERVO7_FUNCTION,0
                                          SERVO7_MAX,1900
                                          SERVO7_MIN,1100
                                          SERVO7_REVERSED,0
                                          SERVO7_TRIM,1500
                                          SERVO8_FUNCTION,0
                                          SERVO8_MAX,1900
                                          SERVO8_MIN,1100
                                          SERVO8_REVERSED,0
                                          SERVO8_TRIM,1500
                                          @TomP Can you tell me how you have connected the UART pins on M0065 to the UART pins on VOXL 2 mini? Like the actual pin numbers that are connected?
