  3. ArduPilot on Voxl2
ArduPilot on Voxl2
flight-core-v2
45 Posts 6 Posters 27.2k Views 3 Watching
  • Andrew TridgellA Andrew Tridgell
    Support for ArduPilot on QURT (the RTOS used on Voxl-2) is now merged in ArduPilot master
    Basic instructions on building and installing are here:
    https://github.com/ArduPilot/ardupilot/tree/master/libraries/AP_HAL_QURT/ap_host/service
    Pre-built binaries are available here:
    • https://firmware.ardupilot.org/Copter/latest/QURT/
    • https://firmware.ardupilot.org/Plane/latest/QURT/
    • https://firmware.ardupilot.org/Rover/latest/QURT/
    This should still be considered experimemtal, with active development happening with @Eric-Katzfey and myself.
    Flight video here on an autonomy dev kit copter:
    https://www.youtube.com/watch?v=l6c65-E-lzg
    Enjoy!
    T Offline
    T Offline
    TomP
      @Andrew-Tridgell Here is the start of our ModalAI ArduPilot documentation: https://docs.modalai.com/voxl-ardupilot/
      T Offline
      T Offline
      TomP
      @Eric-Katzfey I understand that you have not yet tested Arduplane. Apart from that, it could work, right? I want to test Arduplane together with the I/O board because I use a normal ESC which needs a pwm signal.
      • T TomP
        @TomP It's missing support for that I/O board right now. So you would either have to add that yourself or wait for support to be added.
        T 1 Reply Last reply
          T Offline
          T Offline
          TomP
          @Eric-Katzfey When could the support for this be added?
          Alex KushleyevA Eric KatzfeyE 2 Replies Last reply
          • T TomP
            @TomP , if you wanted to try this yourself, a minimal integration of the VOXL2 IO board (M0065) can be done by sending out a single UART packet which contains the PWM output values.
            • the function that creates the packet can be found here and it is used in the voxl2_io px4 driver here. You simply provide an array of pwm values (in nanoseconds). This packet is variable length and supports 1,2,4,6, or 8 outputs.
            • this would be a minimal implementation, which does not include querying the VOXL2 IO board, checking it's version, etc, which is normally done in our PX4 driver. However, it could unblock your work if you are looking to fly a fixed wing ASAP.
            • the packet wrapping function uses the same structure as used for the ModalAI ESC, so that code should already exist in ArduPilot and can be re-used.
            Just to add, make sure the latest M0065 firmware is loaded
            • https://docs.modalai.com/voxl2-io-user-guide/
            • https://docs.modalai.com/voxl2-io-firmware/
            The VOXL2 IO board firmware currently operates in one-shot mode pwm, that is for one PWM command packet there will be one pulse generated without a delay. The communication baud rate with the VOXL2 IO firmware is 921600.
            • T TomP
              @TomP said in ArduPilot on Voxl2:
              Unfortunately, we don't have a fixed date for that support yet. We are striving to support ArduPilot on VOXL 2 by end of this year and that would include support for the IO board. Otherwise I would say keep your eye on the commits going in to AP to see if something comes in sooner.
              T 2 Replies Last reply
                T Offline
                T Offline
                TomP
                @Eric-Katzfey That is a manageable period of time for me. We can use it to plan our product roadmap. Thank you very much and keep up the good work.
                  T Offline
                  T Offline
                  TomP
                  @Eric-Katzfey Is there an update on the timeline yet?
                  Best regards
                  Tom
                    Enjoy!
                    T Offline
                    T Offline
                    TomP
                    @Andrew-Tridgell @Eric-Katzfey I wanted to ask again about the current roadmap regarding Arduplane and the IO board for PWM.
                    Best regards
                    Tom
                    • T TomP
                      Best regards
                      Tom
                      @TomP We are still shooting for the end of this year. I would like to know what external peripherals you would like to support though. I'm guessing GPS, magnetometer, RC, a PWM based motor ESC, and some servos for flight surface control? Also an airspeed sensor? A distance sensor? What kind of RC are you expecting to use? There are some I/O limitations with VOXL 2 so want to make sure that what you want to build can be supported by what we are putting together.
                        T Offline
                        T Offline
                        TomP
                        @Eric-Katzfey We use GPS, compass and the IO board for a PWM-controlled ESC and two servos. We also need two more PWM channels for gimbal control. That's it.
                        We do not use an RC. The control is purely via MAVLink. Joystick inputs are made via the MAVLink command MANUAL_CONTROL. Data is transmitted via the mobile network.
                        • T TomP
                          @TomP I have updated the documentation at https://docs.modalai.com/voxl-ardupilot/. The VOXL 2 IO board with up to 4 PWM outputs is now supported and has been tested on a quadcopter with 4 PWM ESCs. You should be able to use this for arduplane now. We are putting together our own fixed wing test platform and hope to begin testing soon.
                            @Eric-Katzfey I will need to add the support for up to 8 PWM outputs on VOXL 2 IO board. Right now it only supports 4. You should be able to do test flights without the gimbal with 4 PWM outputs.
                            • T TomP
                              @TomP The update to support all 8 PWM outputs from the IO board is now in mainline. You can get it in the latest build posted here: https://firmware.ardupilot.org/Copter/latest/QURT/
                              • T Offline
                                T Offline
                                TomP
                                How can I configure the battery monitor for ArduPlane on the VOXL2-Mini?
                                Which value do I have to enter for BATT_MONITOR and which values for BATT_I2C_ADDR and BAT_I2C_BUS?
                                The "VOXL 2 Mini Power" transmits the current and voltage measurement data via I2C.
                                Best regards,
                                Tom
                                • T TomP
                                  Best regards,
                                  Tom
                                  @TomP It should just scan the available I2C ports and automatically detect the VOXL 2 mini power module if it has been connected. Is it not detecting it?
                                    T Offline
                                    T Offline
                                    TomP
                                    @Eric-Katzfey No, this is not detected. The configuration does not seem to be correct either. The parameter list mentions "Analog Voltage and Current" and corresponding pins.
                                    Here is a screenshot:
                                    • T Offline
                                      T Offline
                                      TomP
                                      There is another problem. The PWM board does not output PWMs. I have also measured this with an oscilloscope. According to SERVO_OUTPUT_RAW, however, the FC should output PWM values.
                                      Do I have to set another parameter in Arduplane so that the VOXL 2 I/O Expander Board is controlled correctly?
                                      I use the VOXL2-Mini J19 connector: GND, pin 7, pin 8 and VREG_3P3V_RC for the power supply.
                                      Here is my setup:
                                      • T TomP
                                        Here is my setup:
                                        @TomP Okay, yes, sorry, you need to set BATT_MONITOR to 21 for INA2xx and need to set BATT_I2C_BUS to 1 for that power monitor to come up. I'll investigate the PWM issue.
                                          T Offline
                                          T Offline
                                          TomP
                                          @Eric-Katzfey The battery monitor works. Thank you very much! I'm sure the PWM will also work and then it's off to the test flight. 🙂
