  2. VOXL Dev Drones
  3. Starling & Starling 2
  4. VOXL-2 Drone M0054-2 Boot Issue After C26 Camera Update
voxl2starling2
21 Posts 3 Posters 5.4k Views 3 Watching
  • A Offline
    antenna-eng
    Hi Tom,
    I did try removing all of the cameras. Still had the same result. After removing the cameras, I next removed the Wifi board to see if that was causing an issue. Also had the same result. At that point, the only board connected to the VOXL 2 was the power board.
    • A antenna-eng
      Hi Tom,
      @antenna-eng When the switch is set to OFF and the board is powered and plugged in to your machine, what do you see with lsusb?
      A 2 Replies Last reply
        antenna-eng
        @tom I ran lsusb before connecting and after to see the change. Only the normal system USB devices are appearing.
          antenna-eng
          @tom Is the VOXL2 board is malfunctioning? Is there any other way to test the board?
          • A antenna-eng
            @antenna-eng Are you running linux natively on your machine or are you using a VM?
            A 1 Reply Last reply
              antenna-eng
              @tom I'm using WSL Ubuntu to connect to it. It was working well previously.
              tomT VinnyV 2 Replies Last reply
              • A antenna-eng
                @antenna-eng It's possible that the board is booting into a mode that WSL doesn't recognize. I haven't used WSL myself, I would recommend booting a linux machine or dual booting your machine if possible.
                Does the windows device manager recognize it at all? It may be enumerating as a different device type depending on the state of the board
                • A antenna-eng
                  Hi @antenna-eng
                  I've tried WSL for years internally with no luck.. it just does not work!!
                  It's worth buying a $300 Ubuntu laptop and know your issues may all be solved!!! I just searched AMZN and found some for less than $250!!!
                  VinnyV A 3 Replies Last reply
                  • VinnyV Vinny
                    Hi @antenna-eng
                    • VinnyV Vinny
                      Hi @antenna-eng
                      antenna-eng
                      @Vinny I also have other Linux systems (Ubuntu, Redhat, etc) that I can use. We were using WSL to connect to it and it was working fine. We can try some other systems to rule out that issue.
                      • VinnyV Vinny
                        Hi @antenna-eng
                        antenna-eng
                        @Vinny I was reminded after my post that our team did try the system on Ubuntu. Just to check, one of my team members just tried it on a Ubuntu system we have and it doesn't show up as a USB device. What do you think we should do?
                        VinnyV tomT 2 Replies Last reply
                        • A antenna-eng
                          Hi @antenna-eng ,
                          @tom has you covered, I was just expressing my experiences with WSL in the hopes it helped.
                          • A antenna-eng
                            @antenna-eng What do you see with lsusb?
                              antenna-eng
                              The VOXL board isn't appearing when connected. I'm just seeing the system USB bus devices and things like the mouse/keyboard. Below is the output of lsusb
                              drone@ubuntu:~$ lsusb
                              Bus 002 Device 002: ID 2109:0822 VIA Labs, Inc. USB3.1 Hub
                              Bus 001 Device 005: ID 0bda:c811 Realtek Semiconductor Corp. 802.11ac NIC
                              Bus 001 Device 004: ID 046d:c31c Logitech, Inc. Keyboard K120
                              Bus 001 Device 003: ID 046d:c05a Logitech, Inc. M90/M100 Optical Mouse
                              Bus 001 Device 002: ID 2109:2822 VIA Labs, Inc. USB2.0 Hub
                              • A antenna-eng
                                @antenna-eng Can you run sudo dmesg -wH and then plug in the board to your machine and see if it's enumerating?
                                  antenna-eng
                                  @tom Using the dmesg -wH command you provided, I can't see the device enumerating after plugging it in. I also tried different USB cables just to check. Still no change.
                                  • A antenna-eng
                                    @antenna-eng How are you powering the board?
                                      antenna-eng
                                      @tom I connected it to the battery. I made sure the battery was charged.
                                      • A antenna-eng
                                        @antenna-eng What hardware do you have connected to the VOXL 2 board? Cameras etc.
