  3. GPS not working for Starling 2 Max
gpsstarling max
21 Posts 7 Posters 8.7k Views 2 Watching
  • Zachary Lowell 0Z Offline
    Zachary Lowell 0
    @Bernhard what is your testing environment? Safe to assume you are outside yeah? Also to confirm can you run cat /etc/modalai/voxl-px4.conf and paste the output?
    B 1 Reply Last reply
      B Offline
      B Offline
      Bernhard
      @Zachary-Lowell-0 yes, we test outside.
      The only difference between the Starling 2 and the Starling Max is the 5G board. On the Max we have the 5G board installed, which seems to be the root of the problem.
      We have tried switchen the GPS modules and the VOXL board itself in the meantime, and the GPS always works on the Starling 2, but not on the Max.
      Is there something additional to do when installing the 5G board? We swapped the Wifi module for the 5G module, configured voxl-modem and it works. But GPS does not work with it it seems.
      Besides, output for voxl-px4.conf:
      GPS=AUTODETECT
      RC=CRSF
      POWER_MANAGER=VOXLPM
      DISTANCE_SENSOR=NONE
      OSD=DISABLE
      DAEMON_MODE=ENABLE
      SENSOR_CAL=ACTUAL
      EXTRA_STEPS=()
        Zachary Lowell 0
        I wonder if there is some form of interference - I do know that from time to time when I am in the same situation as you (GPS showing 0's for both lat and lon) I just have to wait it out for like 10 minutes and then after that, the GPS data shows - unsure why it would take that long, but I can say I have recreated this issue in the past and the solution was to wait - @brahim I believe you ran into this and just let the drone sit for a while before gps was acquired.
        I would be hard pressed to say the issue is directly from the 5g hat - all the hardware is tested rigorously together to ensure safe flights and such.
          B Offline
          B Offline
          Bernhard
          For anyone wondering:
          We figured out what the problem was.
          The 5G is not the only source for interferences.
          It turned out the video transmission hardware we use (Siyi MK 32 https://shop.siyi.biz/products/siyi-mk32?VariantsId=10619) blocks the GPS from finding any satellites.
          We will try to somehow shield the GPS from the video transmission signal.
          @Zachary-Lowell-0 FYI
            Zachary Lowell 0
            @Bernhard said in GPS not working for Starling 2 Max:
            Makes sense to me @Bernhard we have leveraged faraday tape to dull the signals coming off.
              B Offline
              B Offline
              Bernhard
              @Zachary-Lowell-0 actually I have to correct that statement.
              I have now invested quite some time into testing the whole situation thoroughly.
              The drone's GPS works fine without 5G and video transmission. The drone's GPS has problems with 5G (at least where we are testing - populated area, probably some other interferences). The drone's problem also has a problem with the video transmission.
              So basically, both 5G and video cause the problem. But it does not even work with the 5G module that ModalAI provides. Is there any further help available?
              N 1 Reply Last reply
              • B Bernhard
                N Offline
                N Offline
                nuallaino
                @Bernhard Maybe our issues are related? See [my post].(https://forum.modalai.com/topic/3912/problem-acquiring-gps-satellites-possible-voxl2-board-emi?_=1731073406011)
                • N nuallaino
                  B Offline
                  B Offline
                  Bernhard
                  @nuallaino that might be.
                  But for us the GPS-sensor usually works, we only have problems when using 5G and/or video transmission.
                  We will test if an external GPS-sensor fixes the situation.
                  • K Offline
                    K Offline
                    Kory4Drone
                    Has there been any resolution on this? I have a brand new Starling 2 Max, with 5G and have let the drone sit for over an hour and no GPS.
                    • K Kory4Drone
                      B Offline
                      B Offline
                      Bernhard
                      @Kory4Drone sadly there has been no update.
                      @Zachary-Lowell-0 is there anything ModalAI can do to support?
                      groupoG 1 Reply Last reply
                      • B Bernhard
                        groupoG Offline
                        groupoG Offline
                        groupo
                        @Bernhard I also have had GPS related issues with my sentinel drone that happens to have a 5G modem. I have two drones and one does work so we havent chased the other one down much. I will be interested to hear what steps the team will have for you
                          Zachary Lowell 0
                          How far away is the gps from the 5g hat? Also have you leveraged faraday tape around the fuselage of your drone so the signal for the gps doesnt get interfered. Odds are the issue isnt from the 5g hat but from the USB3.0 port if you are leveraging. Multiple studies show there is quite a lot of interference from usb3.0 that can disrupt GPS - the solution for this is taking faraday tape and wrapping it around the right spots to cut the signal:
                          https://www.amazon.com/ZTTXL-Conductive-Grounding-Shielding-Interference/dp/B0CW9GL3Q9/ref=asc_df_B0CW9GL3Q9?tag=bingshoppinga-20&linkCode=df0&hvadid=80676856756448&hvnetw=o&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid=pla-4584276320887549&psc=1&msclkid=17e3696f10bd1379a5500e2bb0278770
                          groupoG B 2 Replies Last reply
                            groupoG Offline
                            groupoG Offline
                            groupo
                            @Zachary-Lowell-0 Are you talking about the USB-C used for ADB? (Maybe there is not the same on the Starling as there is on the Sentinel). Wouldn't that only apply if something was plugged in (i.e.) a cable for ADB
                              B Offline
                              B Offline
                              Bernhard
                              @Zachary-Lowell-0 I don't know if there is another way to mount the 5G board (see picture - we sticked the antennas to the arms in the meantime).
                              20240822_114213.jpg.
                              We assumed since all of the components are official ModalAI products, that they would work together.
                              James StrawsonJ 1 Reply Last reply
                              • B Bernhard
                                James StrawsonJ Offline
                                James Strawson
                                @Bernhard When we released the 5G version of the Starling Max we also moved the GPS to the back of the drone and specified smaller LTE antennas which those landing gear were designed to fit. I'll reach out to you via PM regarding updating your Starling Max.
                                We just discovered a source of EMI which is the cable running to the optional Lepton sensor socket. For a number of reasons we've not offered Lepton as an option of Starling 2 Max yet so you can safely disconnect the 8-pin JST SH connector on the front left side of your camera breakout board next to the barometer cap. This will improve GPS performance. Please see picture below.
                                alt text
                                  alt text
                                  groupoG Offline
                                  groupoG Offline
                                  groupo
                                  @James-Strawson is this sensor on the sentinel as well?
                                  • groupoG groupo
                                    James Strawson
                                    @groupo It is not on Sentinel.
                                      alt text
                                      B Offline
                                      B Offline
                                      Bernhard
                                      @James-Strawson sadly that did not help.
                                      • B Bernhard
                                        B Offline
                                        B Offline
                                        Bernhard
                                        @James-Strawson, @Zachary-Lowell-0 can we expect an update in the near future?
                                        • B Bernhard
                                          ROBERT JUDDR Offline
                                          ROBERT JUDD
                                          @Bernhard @James-Strawson @Zachary-Lowell-0 @Alex-Kushleyev @nuallaino
                                          I have a brand new Starling 2 Max (received 3 days ago), and I'm having the same problem described by nuallaino and Bernhard (no GPS even when outside for a long time).
                                          My system info and results of px4-listener are pasted below.
                                          I did unplug the Lepton 8-pin JST SH connector as suggested by James Strawson, but that had no effect.
                                          Everything else seems to work fine (haven't tried 5G comm yet), but I'm hesitant to fly without GPS functioning properly, so at this point I'm stuck.
                                          Any suggestions would be most welcome.
                                          Thanks for your help !
                                          kernel: #1 SMP PREEMPT Mon Nov 11 22:47:44 UTC 2024 4.19.125
                                          hw platform: M0054
                                          mach.var: 1.0.1
                                          voxl-suite: 1.4.1
                                          current IP: wlan0: 10.0.0.19
                                          voxl2:~$ px4-listener sensor_gps
                                          TOPIC: sensor_gps
                                          sensor_gps
                                          timestamp: 841732144 (0.020669 seconds ago)
                                          timestamp_sample: 0
                                          time_utc_usec: 0
                                          device_id: 11272245 (Type: 0xAC, SERIAL:6 (0x00))
                                          lat: 0
                                          lon: 0
                                          alt: -17000
                                          alt_ellipsoid: 0
                                          s_variance_m_s: 999.00006
                                          c_variance_rad: 3.14159
                                          eph: 4294967.50000
                                          epv: 3796926.25000
                                          hdop: 99.99000
                                          vdop: 99.99000
                                          noise_per_ms: 64
                                          jamming_indicator: 15
                                          vel_m_s: 0.00000
                                          vel_n_m_s: 0.00000
                                          vel_e_m_s: 0.00000
                                          vel_d_m_s: 0.00000
                                          cog_rad: 0.00000
                                          timestamp_time_relative: 0
                                          heading: nan
                                          heading_offset: 0.00000
                                          heading_accuracy: 0.00000
                                          rtcm_injection_rate: 0.00000
                                          automatic_gain_control: 0
                                          fix_type: 0
                                          jamming_state: 0
                                          spoofing_state: 1
                                          vel_ned_valid: False
                                          satellites_used: 0
                                          selected_rtcm_instance: 0
                                          voxl2:~$ px4-listener sensor_mag
                                          TOPIC: sensor_mag
                                          sensor_mag
                                          timestamp: 861420482 (0.006257 seconds ago)
                                          timestamp_sample: 861420007 (475 us before timestamp)
                                          device_id: 527625 (Type: 0x08, I2C:1 (0x0D))
                                          x: -0.04417
                                          y: -0.32142
                                          z: 0.42167
                                          temperature: nan
                                          error_count: 0
                                          voxl2:~$
                                          • ROBERT JUDDR ROBERT JUDD referenced this topic on
