  3. GPS not working for Starling 2 Max
gpsstarling max
21 Posts 7 Posters 8.2k Views 2 Watching
  • K Kory4Drone
    Has there been any resolution on this? I have a brand new Starling 2 Max, with 5G and have let the drone sit for over an hour and no GPS.
    B Offline
    B Offline
    Bernhard
    @Kory4Drone sadly there has been no update.
    @Zachary-Lowell-0 is there anything ModalAI can do to support?
    groupoG 1 Reply Last reply
    • B Bernhard
      groupoG Offline
      groupoG Offline
      groupo
      @Bernhard I also have had GPS related issues with my sentinel drone that happens to have a 5G modem. I have two drones and one does work so we havent chased the other one down much. I will be interested to hear what steps the team will have for you
      • Zachary Lowell 0Z Offline
        Zachary Lowell 0
        How far away is the gps from the 5g hat? Also have you leveraged faraday tape around the fuselage of your drone so the signal for the gps doesnt get interfered. Odds are the issue isnt from the 5g hat but from the USB3.0 port if you are leveraging. Multiple studies show there is quite a lot of interference from usb3.0 that can disrupt GPS - the solution for this is taking faraday tape and wrapping it around the right spots to cut the signal:
        https://www.amazon.com/ZTTXL-Conductive-Grounding-Shielding-Interference/dp/B0CW9GL3Q9/ref=asc_df_B0CW9GL3Q9?tag=bingshoppinga-20&linkCode=df0&hvadid=80676856756448&hvnetw=o&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid=pla-4584276320887549&psc=1&msclkid=17e3696f10bd1379a5500e2bb0278770
        groupoG B 2 Replies Last reply
          groupoG Offline
          groupoG Offline
          groupo
          @Zachary-Lowell-0 Are you talking about the USB-C used for ADB? (Maybe there is not the same on the Starling as there is on the Sentinel). Wouldn't that only apply if something was plugged in (i.e.) a cable for ADB
            B Offline
            B Offline
            Bernhard
            @Zachary-Lowell-0 I don't know if there is another way to mount the 5G board (see picture - we sticked the antennas to the arms in the meantime).
            20240822_114213.jpg.
            We assumed since all of the components are official ModalAI products, that they would work together.
            James StrawsonJ 1 Reply Last reply
            • B Bernhard
              James StrawsonJ Offline
              James Strawson
              @Bernhard When we released the 5G version of the Starling Max we also moved the GPS to the back of the drone and specified smaller LTE antennas which those landing gear were designed to fit. I'll reach out to you via PM regarding updating your Starling Max.
              We just discovered a source of EMI which is the cable running to the optional Lepton sensor socket. For a number of reasons we've not offered Lepton as an option of Starling 2 Max yet so you can safely disconnect the 8-pin JST SH connector on the front left side of your camera breakout board next to the barometer cap. This will improve GPS performance. Please see picture below.
              alt text
                alt text
                groupoG Offline
                groupoG Offline
                groupo
                @James-Strawson is this sensor on the sentinel as well?
                • groupoG groupo
                  James Strawson
                  @groupo It is not on Sentinel.
                    alt text
                    B Offline
                    B Offline
                    Bernhard
                    @James-Strawson sadly that did not help.
                    B 1 Reply Last reply
                    • B Bernhard
                      B Offline
                      B Offline
                      Bernhard
                      @James-Strawson, @Zachary-Lowell-0 can we expect an update in the near future?
                      • B Bernhard
                        ROBERT JUDDR Offline
                        ROBERT JUDD
                        @Bernhard @James-Strawson @Zachary-Lowell-0 @Alex-Kushleyev @nuallaino
                        I have a brand new Starling 2 Max (received 3 days ago), and I'm having the same problem described by nuallaino and Bernhard (no GPS even when outside for a long time).
                        My system info and results of px4-listener are pasted below.
                        I did unplug the Lepton 8-pin JST SH connector as suggested by James Strawson, but that had no effect.
                        Everything else seems to work fine (haven't tried 5G comm yet), but I'm hesitant to fly without GPS functioning properly, so at this point I'm stuck.
                        Any suggestions would be most welcome.
                        Thanks for your help !
                        kernel: #1 SMP PREEMPT Mon Nov 11 22:47:44 UTC 2024 4.19.125
                        hw platform: M0054
                        mach.var: 1.0.1
                        voxl-suite: 1.4.1
                        current IP: wlan0: 10.0.0.19
                        voxl2:~$ px4-listener sensor_gps
                        TOPIC: sensor_gps
                        sensor_gps
                        timestamp: 841732144 (0.020669 seconds ago)
                        timestamp_sample: 0
                        time_utc_usec: 0
                        device_id: 11272245 (Type: 0xAC, SERIAL:6 (0x00))
                        lat: 0
                        lon: 0
                        alt: -17000
                        alt_ellipsoid: 0
                        s_variance_m_s: 999.00006
                        c_variance_rad: 3.14159
                        eph: 4294967.50000
                        epv: 3796926.25000
                        hdop: 99.99000
                        vdop: 99.99000
                        noise_per_ms: 64
                        jamming_indicator: 15
                        vel_m_s: 0.00000
                        vel_n_m_s: 0.00000
                        vel_e_m_s: 0.00000
                        vel_d_m_s: 0.00000
                        cog_rad: 0.00000
                        timestamp_time_relative: 0
                        heading: nan
                        heading_offset: 0.00000
                        heading_accuracy: 0.00000
                        rtcm_injection_rate: 0.00000
                        automatic_gain_control: 0
                        fix_type: 0
                        jamming_state: 0
                        spoofing_state: 1
                        vel_ned_valid: False
                        satellites_used: 0
                        selected_rtcm_instance: 0
                        voxl2:~$ px4-listener sensor_mag
                        TOPIC: sensor_mag
                        sensor_mag
                        timestamp: 861420482 (0.006257 seconds ago)
                        timestamp_sample: 861420007 (475 us before timestamp)
                        device_id: 527625 (Type: 0x08, I2C:1 (0x0D))
                        x: -0.04417
                        y: -0.32142
                        z: 0.42167
                        temperature: nan
                        error_count: 0
                        voxl2:~$
                        • ROBERT JUDDR ROBERT JUDD referenced this topic on
