  3. LTE - Modem Works But Cannot Ping
cellular
27 Posts 4 Posters 8.3k Views 4 Watching
  • vmassagueV vmassague
    @tom I'm using the Add-on also and I'm using the Sierra 7607
    @vmassague Can you disable the voxl-modem service from running with systemctl disable voxl-modem and reboot your voxl.
    Then run voxl-modem-start.sh manually so I can see the full output?
      @derrick0799 Can you disable the voxl-modem service from running with systemctl disable voxl-modem and reboot your voxl.
      derrick0799D Offline
      derrick0799
      @tom, sure. It will be later this evening before I am able to do so.
      • derrick0799D derrick0799
        @derrick0799 @vmassague Another thing for both of you to check is to see if the APN is indeed set correctly, you can do this with the following command:
        / # echo -ne "AT+CGDCONT?\r" | busybox microcom -t 1000 /dev/ttyUSB2
        AT+CGDCONT?
        +CGDCONT: 1,"IP","h2g2","0.0.0.0",0,0,0,0
        +CGDCONT: 2,"IPV4V6","ims","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
        +CGDCONT: 3,"IPV4V6","sos","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,1
        In this case, my APN is h2g2 for GoogleFi
        derrick0799D 1 Reply Last reply
          derrick0799
          @tom I ran 'systemctl disable voxl-modem' and reboot voxl then...
          yocto:~$ voxl-modem-start.sh
          VOXL detected...
          Initializing v2 modem...
          Waiting for ttyUSB2...
          ttyUSB2
          Initalizing cellular connection...
          Configuring GPIO to pull modem out of reset
          Waiting for the diag serial port(/dev/ttyUSB0) to activate
          checking for serial port: /dev/ttyUSB0
          /dev/ttyUSB0 is available
          Verifying existence of QMI port(/dev/cdc-wdm0)
          checking for serial port: /dev/cdc-wdm0
          /dev/cdc-wdm0 is available
          Unstick QMI countdown: 10
          Unstick QMI countdown: 9
          Unstick QMI countdown: 8
          Unstick QMI countdown: 7
          Unstick QMI countdown: 6
          "12253379280"
          Checking for system registration
          Attempt: 1
          "registration": "registered",
          "plmn_mcc": 311,
          "plmn_mnc": 480,
          "plmn_description": "Verizon ",
          "roaming": false
          response: [{
          "plmn_mcc": 311,
          "plmn_mnc": 480,
          "roaming": false
          Successfully registered with the network
          Starting network
          "No effect"
          Checking connection status
          Connection is up
          Using the DHCP client to get an IP address
          udhcpc (v1.23.2) started
          Sending discover...
          Sending select for 100.68.239.240...
          Lease of 100.68.239.240 obtained, lease time 7200
            AT+CGDCONT?
            derrick0799
            @tom said in LTE - Modem Works But Cannot Ping:
            yocto:~$ echo -ne "AT+CGDCONT?\r" | busybox microcom -t 1000 /dev/ttyUSB2
            AT+CGDCONT?
            +CGDCONT: 1,"IP","vzwinternet","0.0.0.0",0,0,0,0
            OK
              @derrick0799 Do you have WiFi connected? If so, try disabling it with ifconfig wlan0 down and seeing if you can then ping.
              Also, can I see the output of route -n?
              Same for you @vmassague something to try.
                AT+CGDCONT?
                OK
                @derrick0799 Looks like APN is setting correctly so that's good
                  derrick0799
                  @tom after disabling wlan0,
                  / # ping 8.8.8.8
                  connect: Network is unreachable
                  / # route -n
                  Kernel IP routing table
                  Destination Gateway Genmask Flags Metric Ref Use Iface
                  172.17.0.0 0.0.0.0 255.255.0.0 U 0 0 0 docker0
                    @derrick0799 What does ifconfig show?
                      derrick0799
                      / # ifconfig
                      docker0 Link encap:Ethernet HWaddr 02:42:77:DF:4E:80
                      inet addr:172.17.0.1 Bcast:0.0.0.0 Mask:255.255.0.0
                      inet6 addr: fe80::42:77ff:fedf:4e80/64 Scope:Link
                      UP BROADCAST MULTICAST MTU:1500 Metric:1
                      TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
                      collisions:0 txqueuelen:0
                      RX bytes:0 (0.0 B) TX bytes:140 (140.0 B)
                      lo Link encap:Local Loopback
                      inet addr:127.0.0.1 Mask:255.0.0.0
                      UP LOOPBACK RUNNING MTU:65536 Metric:1
                      RX packets:609376 errors:0 dropped:0 overruns:0 frame:0
                      TX packets:609376 errors:0 dropped:0 overruns:0 carrier:0
                      RX bytes:65142775 (62.1 MiB) TX bytes:65142775 (62.1 MiB)
                        @derrick0799 Is that the output after running voxl-modem-start.sh?
                          At that point, you should be seeing something similar to:
                          wwan0     Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
                                    inet addr:30.60.23.115  P-t-P:30.60.23.115  Mask:255.255.255.248
                                    UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1500  Metric:1
                                    RX packets:33 errors:0 dropped:0 overruns:0 frame:0
                                    TX packets:55 errors:0 dropped:0 overruns:0 carrier:0
                                    collisions:0 txqueuelen:1000
                                    RX bytes:3214 (3.1 KiB)  TX bytes:4672 (4.5 KiB)
                          derrick0799D 2 Replies Last reply
                            derrick0799
                            @tom I think my problem was that the wifi was connected when I ran the voxl-modem-start.sh
                            Now that I am connect with adb everything started working when I re-ran voxl-modem-start.sh. It is pinging as it should.
                              derrick0799
                              / # ifconfig
                              RX packets:1472332 errors:0 dropped:0 overruns:0 frame:0
                              TX packets:1472332 errors:0 dropped:0 overruns:0 carrier:0
                              RX bytes:155328799 (148.1 MiB) TX bytes:155328799 (148.1 MiB)
                              inet addr:100.76.95.21 P-t-P:100.76.95.21 Mask:255.255.255.252
                              TX packets:2713 errors:0 dropped:0 overruns:0 carrier:0
                              RX bytes:612 (612.0 B) TX bytes:1304344 (1.2 MiB)
                              / # ping 8.8.8.8
                              PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
                              64 bytes from 8.8.8.8: icmp_req=1 ttl=113 time=34.3 ms
                              64 bytes from 8.8.8.8: icmp_req=2 ttl=113 time=35.1 ms
                              64 bytes from 8.8.8.8: icmp_req=3 ttl=113 time=34.0 ms
                              64 bytes from 8.8.8.8: icmp_req=4 ttl=113 time=27.1 ms
                              64 bytes from 8.8.8.8: icmp_req=5 ttl=113 time=31.1 ms
                              64 bytes from 8.8.8.8: icmp_req=6 ttl=113 time=36.5 ms
                              64 bytes from 8.8.8.8: icmp_req=7 ttl=113 time=24.0 ms
                              Thanks @Tom
                                @derrick0799 Great to hear!
                                • vmassagueV Offline
                                  vmassagueV Offline
                                  vmassague
                                  Problem solved for me too! I think it was also the wlan0 being up. Thanks a lot for the support @tom
                                    @vmassague Awesome!
                                    • wilkinsafW wilkinsaf referenced this topic on
