  3. LTE - Modem Works But Cannot Ping
cellular
27 Posts 4 Posters 7.7k Views 4 Watching
  • vmassagueV Offline
    vmassagueV Offline
    vmassague
    In my case, I double-checked with the cellphone to have the same APN since I am using a custom one, but still no success. I tried with two different modules and VOXL boards.
    FYI, I am connecting the LTE antennas one in Antenna (main) and the other to Antenna (diversity)
    • derrick0799D derrick0799
      Ok. I wasn’t sure if I was missing a step in setting this up. I too have verified that the SIM card works and receives data in a different device. I have the V2-Modem, WP7610 Sierra Wireless. I am also connecting to the Verizon “vzwinternet” APN if this detail would further help understand my issue.
      @derrick0799 Are you using the LTE V2 Add-on or Stand Alone?
      derrick0799D 1 Reply Last reply
        wrote on last edited by tom
        @vmassague Are you using the LTE V2 Add-on or Stand Alone? And you're using the Sierra 7607 modem correct?
        vmassagueV 1 Reply Last reply
          derrick0799D Offline
          derrick0799
          @tom, I am using the add-on
            vmassagueV Offline
            vmassagueV Offline
            vmassague
            @tom I'm using the Add-on also and I'm using the Sierra 7607
              @derrick0799 Can you disable the voxl-modem service from running with systemctl disable voxl-modem and reboot your voxl.
              Then run voxl-modem-start.sh manually so I can see the full output?
              derrick0799D 2 Replies Last reply
              • vmassagueV vmassague
                @vmassague Can you disable the voxl-modem service from running with systemctl disable voxl-modem and reboot your voxl.
                  derrick0799
                  @tom, sure. It will be later this evening before I am able to do so.
                    @derrick0799 @vmassague Another thing for both of you to check is to see if the APN is indeed set correctly, you can do this with the following command:
                    / # echo -ne "AT+CGDCONT?\r" | busybox microcom -t 1000 /dev/ttyUSB2
                    AT+CGDCONT?
                    +CGDCONT: 1,"IP","h2g2","0.0.0.0",0,0,0,0
                    +CGDCONT: 2,"IPV4V6","ims","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
                    +CGDCONT: 3,"IPV4V6","sos","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,1
                    In this case, my APN is h2g2 for GoogleFi
                      derrick0799
                      @tom I ran 'systemctl disable voxl-modem' and reboot voxl then...
                      yocto:~$ voxl-modem-start.sh
                      VOXL detected...
                      Initializing v2 modem...
                      Waiting for ttyUSB2...
                      ttyUSB2
                      Initalizing cellular connection...
                      Configuring GPIO to pull modem out of reset
                      Waiting for the diag serial port(/dev/ttyUSB0) to activate
                      checking for serial port: /dev/ttyUSB0
                      /dev/ttyUSB0 is available
                      Verifying existence of QMI port(/dev/cdc-wdm0)
                      checking for serial port: /dev/cdc-wdm0
                      /dev/cdc-wdm0 is available
                      Unstick QMI countdown: 10
                      Unstick QMI countdown: 9
                      Unstick QMI countdown: 8
                      Unstick QMI countdown: 7
                      Unstick QMI countdown: 6
                      "12253379280"
                      Checking for system registration
                      Attempt: 1
                      "registration": "registered",
                      "plmn_mcc": 311,
                      "plmn_mnc": 480,
                      "plmn_description": "Verizon ",
                      "roaming": false
                      response: [{
                      "plmn_mcc": 311,
                      "plmn_mnc": 480,
                      "roaming": false
                      Successfully registered with the network
                      Starting network
                      "No effect"
                      Checking connection status
                      Connection is up
                      Using the DHCP client to get an IP address
                      udhcpc (v1.23.2) started
                      Sending discover...
                      Sending select for 100.68.239.240...
                      Lease of 100.68.239.240 obtained, lease time 7200
                        AT+CGDCONT?
                        derrick0799
                        @tom said in LTE - Modem Works But Cannot Ping:
                        yocto:~$ echo -ne "AT+CGDCONT?\r" | busybox microcom -t 1000 /dev/ttyUSB2
                        AT+CGDCONT?
                        +CGDCONT: 1,"IP","vzwinternet","0.0.0.0",0,0,0,0
                        OK
                          @derrick0799 Do you have WiFi connected? If so, try disabling it with ifconfig wlan0 down and seeing if you can then ping.
                          Also, can I see the output of route -n?
                          Same for you @vmassague something to try.
                            AT+CGDCONT?
                            OK
                            @derrick0799 Looks like APN is setting correctly so that's good
                              derrick0799
                              @tom after disabling wlan0,
                              / # ping 8.8.8.8
                              connect: Network is unreachable
                              / # route -n
                              Kernel IP routing table
                              Destination Gateway Genmask Flags Metric Ref Use Iface
                              172.17.0.0 0.0.0.0 255.255.0.0 U 0 0 0 docker0
                                @derrick0799 What does ifconfig show?
                                  derrick0799
                                  / # ifconfig
                                  docker0 Link encap:Ethernet HWaddr 02:42:77:DF:4E:80
                                  inet addr:172.17.0.1 Bcast:0.0.0.0 Mask:255.255.0.0
                                  inet6 addr: fe80::42:77ff:fedf:4e80/64 Scope:Link
                                  UP BROADCAST MULTICAST MTU:1500 Metric:1
                                  TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
                                  collisions:0 txqueuelen:0
                                  RX bytes:0 (0.0 B) TX bytes:140 (140.0 B)
                                  lo Link encap:Local Loopback
                                  inet addr:127.0.0.1 Mask:255.0.0.0
                                  UP LOOPBACK RUNNING MTU:65536 Metric:1
                                  RX packets:609376 errors:0 dropped:0 overruns:0 frame:0
                                  TX packets:609376 errors:0 dropped:0 overruns:0 carrier:0
                                  RX bytes:65142775 (62.1 MiB) TX bytes:65142775 (62.1 MiB)
                                    @derrick0799 Is that the output after running voxl-modem-start.sh?
                                      At that point, you should be seeing something similar to:
                                      wwan0     Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
                                                inet addr:30.60.23.115  P-t-P:30.60.23.115  Mask:255.255.255.248
                                                UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1500  Metric:1
                                                RX packets:33 errors:0 dropped:0 overruns:0 frame:0
                                                TX packets:55 errors:0 dropped:0 overruns:0 carrier:0
                                                collisions:0 txqueuelen:1000
                                                RX bytes:3214 (3.1 KiB)  TX bytes:4672 (4.5 KiB)
                                        derrick0799
                                        @tom I think my problem was that the wifi was connected when I ran the voxl-modem-start.sh
                                        Now that I am connect with adb everything started working when I re-ran voxl-modem-start.sh. It is pinging as it should.
                                          derrick0799
                                          / # ifconfig
                                          RX packets:1472332 errors:0 dropped:0 overruns:0 frame:0
                                          TX packets:1472332 errors:0 dropped:0 overruns:0 carrier:0
                                          RX bytes:155328799 (148.1 MiB) TX bytes:155328799 (148.1 MiB)
                                          inet addr:100.76.95.21 P-t-P:100.76.95.21 Mask:255.255.255.252
                                          TX packets:2713 errors:0 dropped:0 overruns:0 carrier:0
                                          RX bytes:612 (612.0 B) TX bytes:1304344 (1.2 MiB)
                                          / # ping 8.8.8.8
                                          PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
                                          64 bytes from 8.8.8.8: icmp_req=1 ttl=113 time=34.3 ms
                                          64 bytes from 8.8.8.8: icmp_req=2 ttl=113 time=35.1 ms
                                          64 bytes from 8.8.8.8: icmp_req=3 ttl=113 time=34.0 ms
                                          64 bytes from 8.8.8.8: icmp_req=4 ttl=113 time=27.1 ms
                                          64 bytes from 8.8.8.8: icmp_req=5 ttl=113 time=31.1 ms
                                          64 bytes from 8.8.8.8: icmp_req=6 ttl=113 time=36.5 ms
                                          64 bytes from 8.8.8.8: icmp_req=7 ttl=113 time=24.0 ms
                                          Thanks @Tom
