  3. LTE - Modem Works But Cannot Ping
cellular
27 Posts 4 Posters 8.3k Views 4 Watching
  • derrick0799D derrick0799
    Ok. I wasn’t sure if I was missing a step in setting this up. I too have verified that the SIM card works and receives data in a different device. I have the V2-Modem, WP7610 Sierra Wireless. I am also connecting to the Verizon “vzwinternet” APN if this detail would further help understand my issue.
    @derrick0799 Are you using the LTE V2 Add-on or Stand Alone?
    derrick0799D 1 Reply Last reply
      wrote on last edited by tom
      @vmassague Are you using the LTE V2 Add-on or Stand Alone? And you're using the Sierra 7607 modem correct?
      vmassagueV 1 Reply Last reply
        derrick0799D Offline
        derrick0799
        @tom, I am using the add-on
          vmassagueV Offline
          vmassagueV Offline
          vmassague
          @tom I'm using the Add-on also and I'm using the Sierra 7607
            @derrick0799 Can you disable the voxl-modem service from running with systemctl disable voxl-modem and reboot your voxl.
            Then run voxl-modem-start.sh manually so I can see the full output?
            derrick0799D 2 Replies Last reply
            • vmassagueV vmassague
              @vmassague Can you disable the voxl-modem service from running with systemctl disable voxl-modem and reboot your voxl.
                derrick0799
                @tom, sure. It will be later this evening before I am able to do so.
                  @derrick0799 @vmassague Another thing for both of you to check is to see if the APN is indeed set correctly, you can do this with the following command:
                  / # echo -ne "AT+CGDCONT?\r" | busybox microcom -t 1000 /dev/ttyUSB2
                  AT+CGDCONT?
                  +CGDCONT: 1,"IP","h2g2","0.0.0.0",0,0,0,0
                  +CGDCONT: 2,"IPV4V6","ims","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
                  +CGDCONT: 3,"IPV4V6","sos","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,1
                  In this case, my APN is h2g2 for GoogleFi
                    derrick0799
                    @tom I ran 'systemctl disable voxl-modem' and reboot voxl then...
                    yocto:~$ voxl-modem-start.sh
                    VOXL detected...
                    Initializing v2 modem...
                    Waiting for ttyUSB2...
                    ttyUSB2
                    Initalizing cellular connection...
                    Configuring GPIO to pull modem out of reset
                    Waiting for the diag serial port(/dev/ttyUSB0) to activate
                    checking for serial port: /dev/ttyUSB0
                    /dev/ttyUSB0 is available
                    Verifying existence of QMI port(/dev/cdc-wdm0)
                    checking for serial port: /dev/cdc-wdm0
                    /dev/cdc-wdm0 is available
                    Unstick QMI countdown: 10
                    Unstick QMI countdown: 9
                    Unstick QMI countdown: 8
                    Unstick QMI countdown: 7
                    Unstick QMI countdown: 6
                    "12253379280"
                    Checking for system registration
                    Attempt: 1
                    "registration": "registered",
                    "plmn_mcc": 311,
                    "plmn_mnc": 480,
                    "plmn_description": "Verizon ",
                    "roaming": false
                    response: [{
                    "plmn_mcc": 311,
                    "plmn_mnc": 480,
                    "roaming": false
                    Successfully registered with the network
                    Starting network
                    "No effect"
                    Checking connection status
                    Connection is up
                    Using the DHCP client to get an IP address
                    udhcpc (v1.23.2) started
                    Sending discover...
                    Sending select for 100.68.239.240...
                    Lease of 100.68.239.240 obtained, lease time 7200
                      AT+CGDCONT?
                      derrick0799
                      @tom said in LTE - Modem Works But Cannot Ping:
                      yocto:~$ echo -ne "AT+CGDCONT?\r" | busybox microcom -t 1000 /dev/ttyUSB2
                      AT+CGDCONT?
                      +CGDCONT: 1,"IP","vzwinternet","0.0.0.0",0,0,0,0
                      OK
                        @derrick0799 Do you have WiFi connected? If so, try disabling it with ifconfig wlan0 down and seeing if you can then ping.
                        Also, can I see the output of route -n?
                        Same for you @vmassague something to try.
                          AT+CGDCONT?
                          OK
                          @derrick0799 Looks like APN is setting correctly so that's good
                            derrick0799
                            @tom after disabling wlan0,
                            / # ping 8.8.8.8
                            connect: Network is unreachable
                            / # route -n
                            Kernel IP routing table
                            Destination Gateway Genmask Flags Metric Ref Use Iface
                            172.17.0.0 0.0.0.0 255.255.0.0 U 0 0 0 docker0
                              @derrick0799 What does ifconfig show?
                                derrick0799
                                / # ifconfig
                                docker0 Link encap:Ethernet HWaddr 02:42:77:DF:4E:80
                                inet addr:172.17.0.1 Bcast:0.0.0.0 Mask:255.255.0.0
                                inet6 addr: fe80::42:77ff:fedf:4e80/64 Scope:Link
                                UP BROADCAST MULTICAST MTU:1500 Metric:1
                                TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
                                collisions:0 txqueuelen:0
                                RX bytes:0 (0.0 B) TX bytes:140 (140.0 B)
                                lo Link encap:Local Loopback
                                inet addr:127.0.0.1 Mask:255.0.0.0
                                UP LOOPBACK RUNNING MTU:65536 Metric:1
                                RX packets:609376 errors:0 dropped:0 overruns:0 frame:0
                                TX packets:609376 errors:0 dropped:0 overruns:0 carrier:0
                                RX bytes:65142775 (62.1 MiB) TX bytes:65142775 (62.1 MiB)
                                  @derrick0799 Is that the output after running voxl-modem-start.sh?
                                    At that point, you should be seeing something similar to:
                                    wwan0     Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
                                              inet addr:30.60.23.115  P-t-P:30.60.23.115  Mask:255.255.255.248
                                              UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1500  Metric:1
                                              RX packets:33 errors:0 dropped:0 overruns:0 frame:0
                                              TX packets:55 errors:0 dropped:0 overruns:0 carrier:0
                                              collisions:0 txqueuelen:1000
                                              RX bytes:3214 (3.1 KiB)  TX bytes:4672 (4.5 KiB)
                                      derrick0799
                                      @tom I think my problem was that the wifi was connected when I ran the voxl-modem-start.sh
                                      Now that I am connect with adb everything started working when I re-ran voxl-modem-start.sh. It is pinging as it should.
                                        derrick0799
                                        / # ifconfig
                                        RX packets:1472332 errors:0 dropped:0 overruns:0 frame:0
                                        TX packets:1472332 errors:0 dropped:0 overruns:0 carrier:0
                                        RX bytes:155328799 (148.1 MiB) TX bytes:155328799 (148.1 MiB)
                                        inet addr:100.76.95.21 P-t-P:100.76.95.21 Mask:255.255.255.252
                                        TX packets:2713 errors:0 dropped:0 overruns:0 carrier:0
                                        RX bytes:612 (612.0 B) TX bytes:1304344 (1.2 MiB)
                                        / # ping 8.8.8.8
                                        PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
                                        64 bytes from 8.8.8.8: icmp_req=1 ttl=113 time=34.3 ms
                                        64 bytes from 8.8.8.8: icmp_req=2 ttl=113 time=35.1 ms
                                        64 bytes from 8.8.8.8: icmp_req=3 ttl=113 time=34.0 ms
                                        64 bytes from 8.8.8.8: icmp_req=4 ttl=113 time=27.1 ms
                                        64 bytes from 8.8.8.8: icmp_req=5 ttl=113 time=31.1 ms
                                        64 bytes from 8.8.8.8: icmp_req=6 ttl=113 time=36.5 ms
                                        64 bytes from 8.8.8.8: icmp_req=7 ttl=113 time=24.0 ms
                                        Thanks @Tom
                                          @derrick0799 Great to hear!
