    Outdoor navigation GPS problem
    Qualcomm Flight RB5 5G Drone
    1.3k
    • V
      vjuliani
      The issue is similar to the https://forum.modalai.com/topic/3410/outdoor-navigation-problem one.
      When I try an outdoor flight in position mode using EKF2_GPS_CHECK to 245, QGC shows a lot of GPS Speed Accuracy too low failure messages. With that, the drone status remains in Not Ready and it can't fly.
      If I try to set EKF2_GPS_CHECK to 1, I get Pre-flight check failure: GPS Position Required messages from QGC. So, the status remains in Not Ready and the drone can't fly.
      The only manner I found the drone flight to work was to set COM_ARM_WO_GPS to 1 and use altitude or manual flight mode.
      I think it might be a gps hardware issue, like the one in the topic linked above.
      The GPS model I had is M8N and I already had this issue with VOXL SDK 0.9.5.
      Any suggestions?
      M E 2 Replies Last reply 9 Jul 2024, 05:25 Reply Quote 0
      • V vjuliani referenced this topic on 5 Jul 2024, 17:28
      • M
        Moderator ModalAI Team @vjuliani
        @vjuliani Can you lower the error threshold a bit?
        • E
          Eric Katzfey ModalAI Team @vjuliani
          @vjuliani So if you change EKF2_GPS_CHECK to 1 then it is only looking at number of satellites as a quality metric. But it seems you are still not able to arm unless you allow arming without any GPS. Can you arm and do a manual flight and then attach the log from the flight here? Are you trying this outdoors with a clear unobstructed view to the sky?
          • V
            vjuliani
            @Moderator Yes, how can I do that?
            @Eric-Katzfey, yes I am trying outdoors. I am even waiting more than 10 minutes too see if the GPS locks but it doesnt
            Here are the logs of two of the outdoor flight attempts with manual flight mode: https://www.mediafire.com/folder/qhidipn0n1xng/RB5-outdoor-flight-logs
            When I tried the outdoor flights with manual flight mode, one of the drone's rotors seemed to not be working properly. You can see it in this video: https://www.youtube.com/watch?v=F7ug6u2W8Yw
            Is there any PX4 parameter I could change in order to try to fix it?
            It happened after upgrading from VOXL SDK 0.9.5 to 1.1.2...
            Thanks in advance!
            E 4 Replies Last reply 11 Jul 2024, 15:56 Reply Quote 0
            • E
              @vjuliani The log shows a 3D GPS lock with 14 satellites.
              • E
                @vjuliani Your GPS location from the log: https://www.google.com/maps/place/22°48'54.2"S+47°02'48.1"W/@-22.8154809,-47.0471945,1108m/data=!3m1!1e3!4m4!3m3!8m2!3d-22.8150558!4d-47.0466938?entry=ttu
                • E
                  @vjuliani So, the GPS seems to be working okay. It's not clear why you cannot get a global position in PX4 using that data. Let me look through the parameters and see if I can suggest some others to change.
                  E 1 Reply Last reply 11 Jul 2024, 16:45 Reply Quote 0
                  • E
                    @vjuliani Can you please open a separate forum post for the drone not flying properly? Let's keep this one for the GPS issue only. Thanks!
                    • E
                      Eric Katzfey ModalAI Team @Eric Katzfey
                      @Eric-Katzfey You can try setting EKF2_GPS_CHECK back to the default 245 value. Then experiment with the various GPS thresholds to see if you can increase any of them to get the drone to go into position mode. The relevant parameters are:
                      Maximum allowed PDOP set by EKF2_REQ_PDOP
                      Maximum allowed horizontal position error set by EKF2_REQ_EPH
                      Maximum allowed vertical position error set by EKF2_REQ_EPV
                      Maximum allowed speed error set by EKF2_REQ_SACC
                      Maximum allowed horizontal position rate set by EKF2_REQ_HDRIFT. This check will only run when the vehicle is on ground and stationary.
                      Maximum allowed vertical position rate set by EKF2_REQ_VDRIFT. This check will only run when the vehicle is on ground and stationary.
                      Maximum allowed horizontal speed set by EKF2_REQ_HDRIFT. This check will only run when the vehicle is on ground and stationary.
                      Maximum allowed vertical velocity discrepancy set by EKF2_REQ_VDRIFT
                      E 1 Reply Last reply 11 Jul 2024, 16:48 Reply Quote 0
                      • E
                        @Eric-Katzfey Since it was originally complaining about speed accuracy then maybe you can increase EKF2_REQ_SACC and see if that error goes away. I do notice from the log that there is a lot of GPS noise and jamming. Not sure if that is part of the issue here though. Is there another open field in a different location that you can try as well?
                        • V vjuliani referenced this topic on 11 Jul 2024, 19:20
                        • V
                          vjuliani
                          Hi @Eric-Katzfey
                          Yeah, I will try in another open field in a different location and experiment with the various GPS thresholds you mentioned. Thanks!
                          We did a site survey in the open field area we tried the flights and we got the results below: tela1.png
                          We used an AARONIA AG HyperLOG Broadband Directional antenna and a Spectrum Analyzer.
                          It might help.
                          • V
                            vjuliani
                            Hi @Eric-Katzfey
                            As you said, QGC and PX4 were receiving GPS data from M8N, however, EKF2 couldn't estimate the global and local valid positions.
                            After changing EKF2_MAG_TYPE, which value was as None, to Automatic, EKF2 could finished the global and local valid positions estimation and the drone became Ready to Fly with no issues from QGC.
                            So, now, after changing EKF2_REQ_SACC to 0.8m/s and EKF2_MAG_TYPE to Automatic, the drone became Ready to Fly and I could arm it using GPS.
                            Which is curious though is that here https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.14/EKF2_helpers/outdoor_gps_baro.params in the EKF2 helper file, which I used to first configure the drone's PX4 params after upgrading from VOXL SDK 0.9.5 to 1.1.2, it says to set EKF2_MAG_TYPE to 0, so I am not sure if setting EKF2_MAG_TYPE to Automatic is the right fix, what are your thoughts? Is 0 meaning Automatic?
                            After setting EKF2_MAG_TYPE to Automatic, I tried some flights in Position Flight Mode and had the same problems of when I had tried the Manual Flight Mode flights (The one showed in the youtube video above), which @Alex-Kushleyev is helping me to figure it out in the https://forum.modalai.com/topic/3634/rb5-can-t-leave-the-ground-properly-when-flying-in-manual-flight-mode/ topic. The logs can be seen here https://www.mediafire.com/folder/jbuu2or25tjdr/position-flight-mode-logs
                            E 1 Reply Last reply 16 Jul 2024, 15:07 Reply Quote 0
                            • V vjuliani referenced this topic on 15 Jul 2024, 21:12
                            • E
                              @vjuliani Yes, 0 is automatic.
                              V 1 Reply Last reply 16 Jul 2024, 18:20 Reply Quote 0
                              • V
                                vjuliani @Eric Katzfey
                                Ok, thanks
                                Can I use the file:
                                https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.14/ci_helpers/ci_sentinel.params
                                To configure RB5 px4 parameters using QGC?
                                I didn't find a specific file to RB5 in the folder
                                tomT 1 Reply Last reply 16 Jul 2024, 18:58 Reply Quote 0
                                  tom admin @vjuliani
                                  @vjuliani You'll want to use these: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.14/platforms/Sentinel_V1.params
                                  Or you can run
                                  voxl-configure-px4-params --platform MRB-D0006
                                  • V
                                    vjuliani
                                    @Eric-Katzfey @tom
                                    After running "voxl-configure-px4-params --platform MRB-D0006" to configure RB5 PX4 parameters, I could perform an outdoors flight with RB5 using Position Flight Mode without GPS or motor problems: https://youtu.be/D8zP0hOx8wc
                                    It seems that the issue was RB5 running with Sentinel PX4 parameters after SDK upgrade.
                                    Thank you very much guys for your help
                                    1 out of 16
