    Arming VOXL, but motors won't spin up
    912
    • M
      Matthew Wellner
      I have a VOXL 2 with the m0134_6 ESC that @Alex-Kushleyev has been helping me tune for low kV motors. In the process, I updated the ESC to a new firmware that changed the baud rate from 250000 to 200000. I updated the params for the vehicle in QGC, but now I can arm the VOXL 2, but it won't spin the motors at all and there aren't any errors that I can see.
      I can still voxl-esc scan / spin / etc. without any issues.
      Any ideas?
      A 1 Reply Last reply 23 Jan 2024, 19:19 Reply Quote 0
      • A
        Alex Kushleyev ModalAI Team @Matthew Wellner
        @Matthew-Wellner , the baud rate is 2000000 (2Mbit), not 200K, can you please double check your PX4 params?
        Also, some helpful commands:
        px4-listener esc_status
        this will print out the esc_status message, which the ESC driver should be sending out
        Also, if you run voxl-px4 in foreground
        systemctl stop voxl-px4
        voxl-px4 -d
        then you can open another terminal / adb and run:
        px4-qshell voxl_esc status
        this will print status of voxl esc driver and the params (in the window where voxl-px4 -d is running)
        C M 3 Replies Last reply 23 Jan 2024, 19:23 Reply Quote 0
        • C
          Chase Riley @Alex Kushleyev
          @Alex-Kushleyev I may be experiencing the same issue. I will tag along here.
          @Eric-Katzfey I responded in our thread about the spectrum error thinking this might be linked to it, but this is very similar to what I am seeing. So it could be a linked to this instead.
          • C
            @Alex-Kushleyev This is the results I get from running px4-listener esc_status and capturing the results of running px4-qshell voxl_esc status.
            voxl2:/$ px4-listener esc_status
            TOPIC: esc_status
             esc_status
                timestamp: 28243762 (0.002512 seconds ago)
                counter: 12602
                esc_count: 4
                esc_connectiontype: 1
                esc_online_flags: 15 (0b1111)
                esc_armed_flags: 15 (0b1111)
              esc[0] (esc_report):
                timestamp: 28241456 (0.005087 seconds ago)
                esc_errorcount: 0
                esc_rpm: 0
                esc_voltage: 24.03100
                esc_current: -0.05600
                esc_temperature: 31.00000
                failures: 0
                esc_address: 3
                esc_cmdcount: 56
                esc_state: 0
                actuator_function: 0
                esc_power: 0
              esc[1] (esc_report):
                timestamp: 28242530 (0.004309 seconds ago)
                esc_errorcount: 0
                esc_rpm: 0
                esc_voltage: 24.03000
                esc_current: -0.01600
                esc_temperature: 30.00000
                failures: 0
                esc_address: 2
                esc_cmdcount: 57
                esc_state: 0
                esc_power: 0
              esc[2] (esc_report):
                timestamp: 28243762 (0.003363 seconds ago)
                esc_errorcount: 0
                esc_rpm: 0
                esc_voltage: 24.03300
                failures: 0
                esc_address: 4
                esc_cmdcount: 58
                esc_state: 0
                esc_power: 0
              esc[3] (esc_report):
                timestamp: 28240673 (0.006735 seconds ago)
                esc_errorcount: 0
                esc_rpm: 0
                esc_voltage: 24.01200
                esc_current: -0.02400
                failures: 0
                esc_address: 1
                esc_cmdcount: 55
                esc_state: 0
                esc_power: 0
              esc[4] (esc_report):
                timestamp: 0
                esc_errorcount: 0
                esc_rpm: 0
                esc_voltage: 0.00000
                esc_current: 0.00000
                esc_temperature: 0.00000
                failures: 0
                esc_address: 0
                esc_cmdcount: 0
                esc_state: 0
                esc_power: 0
              esc[5] (esc_report):
                timestamp: 0
                esc_errorcount: 0
                esc_rpm: 0
                failures: 0
                esc_address: 0
                esc_cmdcount: 0
                esc_state: 0
                esc_power: 0
              esc[6] (esc_report):
                timestamp: 0
                esc_errorcount: 0
                esc_rpm: 0
                failures: 0
                esc_address: 0
                esc_cmdcount: 0
                esc_state: 0
                esc_power: 0
              esc[7] (esc_report):
                timestamp: 0
                esc_errorcount: 0
                esc_rpm: 0
                failures: 0
                esc_address: 0
                esc_cmdcount: 0
                esc_state: 0
                esc_power: 0
            INFO  [muorb] SLPI: qshell gotten: voxl_esc status
            INFO  [muorb] SLPI:   arg0 = 'voxl_esc'
            INFO  [muorb] SLPI:   arg1 = 'status'
            INFO  [muorb] SLPI: Max update rate: 0 Hz
            INFO  [muorb] SLPI: Outputs on: no
            INFO  [muorb] SLPI: UART port: 2
            INFO  [muorb] SLPI: UART open: yes
            INFO  [muorb] SLPI:
            INFO  [muorb] SLPI: Params: VOXL_ESC_CONFIG: 1
            INFO  [muorb] SLPI: Params: VOXL_ESC_BAUD: 2000000
            INFO  [muorb] SLPI: Params: VOXL_ESC_FUNC1: 103
            INFO  [muorb] SLPI: Params: VOXL_ESC_FUNC2: 102
            INFO  [muorb] SLPI: Params: VOXL_ESC_FUNC3: 104
            INFO  [muorb] SLPI: Params: VOXL_ESC_FUNC4: 101
            INFO  [muorb] SLPI: Params: VOXL_ESC_SDIR1: 0
            INFO  [muorb] SLPI: Params: VOXL_ESC_SDIR2: 0
            INFO  [muorb] SLPI: Params: VOXL_ESC_SDIR3: 0
            INFO  [muorb] SLPI: Params: VOXL_ESC_SDIR4: 0
            INFO  [muorb] SLPI: Params: VOXL_ESC_RPM_MIN: 700
            INFO  [muorb] SLPI: Params: VOXL_ESC_RPM_MAX: 8000
            INFO  [muorb] SLPI:
            INFO  [muorb] SLPI: -- ID: 0
            INFO  [muorb] SLPI:    Motor:           3
            INFO  [muorb] SLPI:    Direction:       1
            INFO  [muorb] SLPI:    State:           0
            INFO  [muorb] SLPI:    Requested:       0 RPM
            INFO  [muorb] SLPI:    Measured:        0 RPM
            INFO  [muorb] SLPI:    Command Counter: 137
            INFO  [muorb] SLPI:    Voltage:         24.010000 VDC
            INFO  [muorb] SLPI:
            INFO  [muorb] SLPI: -- ID: 1
            INFO  [muorb] SLPI:    Motor:           2
            INFO  [muorb] SLPI:    Command Counter: 138
            INFO  [muorb] SLPI:    Voltage:         24.028002 VDC
            INFO  [muorb] SLPI:
            INFO  [muorb] SLPI: -- ID: 2
            INFO  [muorb] SLPI:    Motor:           4
            INFO  [muorb] SLPI:    Command Counter: 139
            INFO  [muorb] SLPI:    Voltage:         24.020000 VDC
            INFO  [muorb] SLPI:
            INFO  [muorb] SLPI: -- ID: 3
            INFO  [muorb] SLPI:    Motor:           1
            INFO  [muorb] SLPI:    Command Counter: 136
            INFO  [muorb] SLPI:
            INFO  [muorb] SLPI: voxl_esc: cycle: 44256 events, 37887531us elapsed, 856.10us avg, min 64us max 2164us 318.
            INFO  [muorb] SLPI: voxl_esc: output update interval: 44255 events, 1271.43us avg, min 196us max 50628us 1397
            INFO  [muorb] SLPI: Param prefix: VOXL_ESC
            INFO  [muorb] SLPI: control latency: 44218 events, 60898443us elapsed, 1377.23us avg, min 314us max 3288us 48
            INFO  [muorb] SLPI: Switched to rate_ctrl work queue
            INFO  [muorb] SLPI: Channel Configuration:
            INFO  [muorb] SLPI: Channel 0: func: 103, value: 0, failsafe: 0, disarmed: 0, min: 700, max: 8000
            INFO  [muorb] SLPI: Channel 1: func: 102, value: 0, failsafe: 0, disarmed: 0, min: 700, max: 8000
            INFO  [muorb] SLPI: Channel 2: func: 104, value: 0, failsafe: 0, disarmed: 0, min: 700, max: 8000
            INFO  [muorb] SLPI: Channel 3: func: 101, value: 0, failsafe: 0, disarmed: 0, min: 700, max: 8000
            INFO  [muorb] SLPI: Ok executing command: voxl_esc status
            A 1 Reply Last reply 23 Jan 2024, 19:50 Reply Quote 0
            • A
              Alex Kushleyev ModalAI Team @Chase Riley
              @Chase-Riley, your output indicates that the ESC driver in PX4 is communicating with the ESC, I do not see any issue with that!
              C 1 Reply Last reply 23 Jan 2024, 19:55 Reply Quote 0
              • C
                @Alex-Kushleyev Not sure what happened but you are correct it is functioning now.
                • M
                  Matthew Wellner @Alex Kushleyev
                  Interesting - px4-listener esc_status gives me "never published".
                  M 1 Reply Last reply 23 Jan 2024, 20:20 Reply Quote 0
                  • M
                    Matthew Wellner @Matthew Wellner
                    When I run and the motors don't spin up here is what your second set of commands gives me:
                    M 1 Reply Last reply 23 Jan 2024, 20:24 Reply Quote 0
                    • M
                      I also watched as px4 started up and it looks like the process fails to open the port for the ESC (see the red after the voxl_esc start command) -
                      A 1 Reply Last reply 23 Jan 2024, 20:27 Reply Quote 0
                      • A
                        @Matthew-Wellner your ESC baud rate in PX4 params is 200,000 , not 2,000,000 which is most likely the issue.
                        A 1 Reply Last reply 23 Jan 2024, 21:05 Reply Quote 0
                        • A
                          the failure to open the UART port is most likely due to unsupported baud rate (200,000) instead of desired baud rate (2,000,000)
                          M 1 Reply Last reply 24 Jan 2024, 13:24 Reply Quote 0
                          • M
                            @Alex-Kushleyev - Thanks again. You were right and that was all I needed to change. Sorry!
                            A 1 Reply Last reply 24 Jan 2024, 19:44 Reply Quote 0
                            • A
                              @Matthew-Wellner , no worries! I am glad you got that part working.
                              Kiazoa JoaoK 1 Reply Last reply 26 Aug 2024, 18:50 Reply Quote 0
                              • Kiazoa JoaoK
                                Kiazoa Joao @Alex Kushleyev
                                @Alex-Kushleyev I had a similar issue and this helped a lot. thanks.
