  3. Arming VOXL, but motors won't spin up
14 Posts 4 Posters 2.5k Views 2 Watching
    @Matthew-Wellner , the baud rate is 2000000 (2Mbit), not 200K, can you please double check your PX4 params?
    Also, some helpful commands:
    px4-listener esc_status
    this will print out the esc_status message, which the ESC driver should be sending out
    Also, if you run voxl-px4 in foreground
    systemctl stop voxl-px4
    voxl-px4 -d
    then you can open another terminal / adb and run:
    px4-qshell voxl_esc status
    this will print status of voxl esc driver and the params (in the window where voxl-px4 -d is running)
    Chase RileyC Offline
    Chase Riley
    @Alex-Kushleyev This is the results I get from running px4-listener esc_status and capturing the results of running px4-qshell voxl_esc status.
    voxl2:/$ px4-listener esc_status
    TOPIC: esc_status
     esc_status
        timestamp: 28243762 (0.002512 seconds ago)
        counter: 12602
        esc_count: 4
        esc_connectiontype: 1
        esc_online_flags: 15 (0b1111)
        esc_armed_flags: 15 (0b1111)
      esc[0] (esc_report):
        timestamp: 28241456 (0.005087 seconds ago)
        esc_errorcount: 0
        esc_rpm: 0
        esc_voltage: 24.03100
        esc_current: -0.05600
        esc_temperature: 31.00000
        failures: 0
        esc_address: 3
        esc_cmdcount: 56
        esc_state: 0
        actuator_function: 0
        esc_power: 0
      esc[1] (esc_report):
        timestamp: 28242530 (0.004309 seconds ago)
        esc_errorcount: 0
        esc_rpm: 0
        esc_voltage: 24.03000
        esc_current: -0.01600
        esc_temperature: 30.00000
        failures: 0
        esc_address: 2
        esc_cmdcount: 57
        esc_state: 0
        esc_power: 0
      esc[2] (esc_report):
        timestamp: 28243762 (0.003363 seconds ago)
        esc_errorcount: 0
        esc_rpm: 0
        esc_voltage: 24.03300
        failures: 0
        esc_address: 4
        esc_cmdcount: 58
        esc_state: 0
        esc_power: 0
      esc[3] (esc_report):
        timestamp: 28240673 (0.006735 seconds ago)
        esc_errorcount: 0
        esc_rpm: 0
        esc_voltage: 24.01200
        esc_current: -0.02400
        failures: 0
        esc_address: 1
        esc_cmdcount: 55
        esc_state: 0
        esc_power: 0
      esc[4] (esc_report):
        timestamp: 0
        esc_errorcount: 0
        esc_rpm: 0
        esc_voltage: 0.00000
        esc_current: 0.00000
        esc_temperature: 0.00000
        failures: 0
        esc_address: 0
        esc_cmdcount: 0
        esc_state: 0
        esc_power: 0
      esc[5] (esc_report):
        timestamp: 0
        esc_errorcount: 0
        esc_rpm: 0
        failures: 0
        esc_address: 0
        esc_cmdcount: 0
        esc_state: 0
        esc_power: 0
      esc[6] (esc_report):
        timestamp: 0
        esc_errorcount: 0
        esc_rpm: 0
        failures: 0
        esc_address: 0
        esc_cmdcount: 0
        esc_state: 0
        esc_power: 0
      esc[7] (esc_report):
        timestamp: 0
        esc_errorcount: 0
        esc_rpm: 0
        failures: 0
        esc_address: 0
        esc_cmdcount: 0
        esc_state: 0
        esc_power: 0
    INFO  [muorb] SLPI: qshell gotten: voxl_esc status
    INFO  [muorb] SLPI:   arg0 = 'voxl_esc'
    INFO  [muorb] SLPI:   arg1 = 'status'
    INFO  [muorb] SLPI: Max update rate: 0 Hz
    INFO  [muorb] SLPI: Outputs on: no
    INFO  [muorb] SLPI: UART port: 2
    INFO  [muorb] SLPI: UART open: yes
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: Params: VOXL_ESC_CONFIG: 1
    INFO  [muorb] SLPI: Params: VOXL_ESC_BAUD: 2000000
    INFO  [muorb] SLPI: Params: VOXL_ESC_FUNC1: 103
    INFO  [muorb] SLPI: Params: VOXL_ESC_FUNC2: 102
    INFO  [muorb] SLPI: Params: VOXL_ESC_FUNC3: 104
    INFO  [muorb] SLPI: Params: VOXL_ESC_FUNC4: 101
    INFO  [muorb] SLPI: Params: VOXL_ESC_SDIR1: 0
    INFO  [muorb] SLPI: Params: VOXL_ESC_SDIR2: 0
    INFO  [muorb] SLPI: Params: VOXL_ESC_SDIR3: 0
    INFO  [muorb] SLPI: Params: VOXL_ESC_SDIR4: 0
    INFO  [muorb] SLPI: Params: VOXL_ESC_RPM_MIN: 700
    INFO  [muorb] SLPI: Params: VOXL_ESC_RPM_MAX: 8000
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: -- ID: 0
    INFO  [muorb] SLPI:    Motor:           3
    INFO  [muorb] SLPI:    Direction:       1
    INFO  [muorb] SLPI:    State:           0
    INFO  [muorb] SLPI:    Requested:       0 RPM
    INFO  [muorb] SLPI:    Measured:        0 RPM
    INFO  [muorb] SLPI:    Command Counter: 137
    INFO  [muorb] SLPI:    Voltage:         24.010000 VDC
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: -- ID: 1
    INFO  [muorb] SLPI:    Motor:           2
    INFO  [muorb] SLPI:    Command Counter: 138
    INFO  [muorb] SLPI:    Voltage:         24.028002 VDC
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: -- ID: 2
    INFO  [muorb] SLPI:    Motor:           4
    INFO  [muorb] SLPI:    Command Counter: 139
    INFO  [muorb] SLPI:    Voltage:         24.020000 VDC
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: -- ID: 3
    INFO  [muorb] SLPI:    Motor:           1
    INFO  [muorb] SLPI:    Command Counter: 136
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: voxl_esc: cycle: 44256 events, 37887531us elapsed, 856.10us avg, min 64us max 2164us 318.
    INFO  [muorb] SLPI: voxl_esc: output update interval: 44255 events, 1271.43us avg, min 196us max 50628us 1397
    INFO  [muorb] SLPI: Param prefix: VOXL_ESC
    INFO  [muorb] SLPI: control latency: 44218 events, 60898443us elapsed, 1377.23us avg, min 314us max 3288us 48
    INFO  [muorb] SLPI: Switched to rate_ctrl work queue
    INFO  [muorb] SLPI: Channel Configuration:
    INFO  [muorb] SLPI: Channel 0: func: 103, value: 0, failsafe: 0, disarmed: 0, min: 700, max: 8000
    INFO  [muorb] SLPI: Channel 1: func: 102, value: 0, failsafe: 0, disarmed: 0, min: 700, max: 8000
    INFO  [muorb] SLPI: Channel 2: func: 104, value: 0, failsafe: 0, disarmed: 0, min: 700, max: 8000
    INFO  [muorb] SLPI: Channel 3: func: 101, value: 0, failsafe: 0, disarmed: 0, min: 700, max: 8000
    INFO  [muorb] SLPI: Ok executing command: voxl_esc status
    • Chase RileyC Chase Riley
      TOPIC: esc_status
       esc_status
          counter: 12602
          esc_count: 4
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 3
          esc_cmdcount: 56
          esc_state: 0
          esc_power: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 2
          esc_cmdcount: 57
          esc_state: 0
          esc_power: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 4
          esc_cmdcount: 58
          esc_state: 0
          esc_power: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 1
          esc_cmdcount: 55
          esc_state: 0
          esc_power: 0
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          esc_power: 0
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          esc_power: 0
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          esc_power: 0
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          esc_power: 0
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      @Chase-Riley, your output indicates that the ESC driver in PX4 is communicating with the ESC, I do not see any issue with that!
        Chase Riley
        @Alex-Kushleyev Not sure what happened but you are correct it is functioning now.
          voxl-px4 -d
          Matthew WellnerM Offline
          Matthew Wellner
          Interesting - px4-listener esc_status gives me "never published".
            Matthew Wellner
            When I run and the motors don't spin up here is what your second set of commands gives me:
              Matthew Wellner
              I also watched as px4 started up and it looks like the process fails to open the port for the ESC (see the red after the voxl_esc start command) -
                @Matthew-Wellner your ESC baud rate in PX4 params is 200,000 , not 2,000,000 which is most likely the issue.
                  the failure to open the UART port is most likely due to unsupported baud rate (200,000) instead of desired baud rate (2,000,000)
                    Matthew Wellner
                    @Alex-Kushleyev - Thanks again. You were right and that was all I needed to change. Sorry!
                      @Matthew-Wellner , no worries! I am glad you got that part working.
                      Kiazoa JoaoK 1 Reply Last reply
                        Kiazoa JoaoK Offline
                        Kiazoa Joao
                        @Alex-Kushleyev I had a similar issue and this helped a lot. thanks.
