  3. Arming VOXL, but motors won't spin up
14 Posts 4 Posters 2.2k Views 2 Watching
  • Matthew WellnerM Offline
    Matthew Wellner
    I have a VOXL 2 with the m0134_6 ESC that @Alex-Kushleyev has been helping me tune for low kV motors. In the process, I updated the ESC to a new firmware that changed the baud rate from 250000 to 200000. I updated the params for the vehicle in QGC, but now I can arm the VOXL 2, but it won't spin the motors at all and there aren't any errors that I can see.
    I can still voxl-esc scan / spin / etc. without any issues.
    Any ideas?
      Any ideas?
      @Matthew-Wellner , the baud rate is 2000000 (2Mbit), not 200K, can you please double check your PX4 params?
      Also, some helpful commands:
      px4-listener esc_status
      this will print out the esc_status message, which the ESC driver should be sending out
      Also, if you run voxl-px4 in foreground
      systemctl stop voxl-px4
      voxl-px4 -d
      then you can open another terminal / adb and run:
      px4-qshell voxl_esc status
      this will print status of voxl esc driver and the params (in the window where voxl-px4 -d is running)
      Chase RileyC Matthew WellnerM 3 Replies Last reply
        voxl-px4 -d
        Chase RileyC Offline
        Chase Riley
        @Alex-Kushleyev I may be experiencing the same issue. I will tag along here.
        @Eric-Katzfey I responded in our thread about the spectrum error thinking this might be linked to it, but this is very similar to what I am seeing. So it could be a linked to this instead.
          voxl-px4 -d
          Chase Riley
          @Alex-Kushleyev This is the results I get from running px4-listener esc_status and capturing the results of running px4-qshell voxl_esc status.
          voxl2:/$ px4-listener esc_status
          TOPIC: esc_status
           esc_status
              timestamp: 28243762 (0.002512 seconds ago)
              counter: 12602
              esc_count: 4
              esc_connectiontype: 1
              esc_online_flags: 15 (0b1111)
              esc_armed_flags: 15 (0b1111)
            esc[0] (esc_report):
              timestamp: 28241456 (0.005087 seconds ago)
              esc_errorcount: 0
              esc_rpm: 0
              esc_voltage: 24.03100
              esc_current: -0.05600
              esc_temperature: 31.00000
              failures: 0
              esc_address: 3
              esc_cmdcount: 56
              esc_state: 0
              actuator_function: 0
              esc_power: 0
            esc[1] (esc_report):
              timestamp: 28242530 (0.004309 seconds ago)
              esc_errorcount: 0
              esc_rpm: 0
              esc_voltage: 24.03000
              esc_current: -0.01600
              esc_temperature: 30.00000
              failures: 0
              esc_address: 2
              esc_cmdcount: 57
              esc_state: 0
              esc_power: 0
            esc[2] (esc_report):
              timestamp: 28243762 (0.003363 seconds ago)
              esc_errorcount: 0
              esc_rpm: 0
              esc_voltage: 24.03300
              failures: 0
              esc_address: 4
              esc_cmdcount: 58
              esc_state: 0
              esc_power: 0
            esc[3] (esc_report):
              timestamp: 28240673 (0.006735 seconds ago)
              esc_errorcount: 0
              esc_rpm: 0
              esc_voltage: 24.01200
              esc_current: -0.02400
              failures: 0
              esc_address: 1
              esc_cmdcount: 55
              esc_state: 0
              esc_power: 0
            esc[4] (esc_report):
              timestamp: 0
              esc_errorcount: 0
              esc_rpm: 0
              esc_voltage: 0.00000
              esc_current: 0.00000
              esc_temperature: 0.00000
              failures: 0
              esc_address: 0
              esc_cmdcount: 0
              esc_state: 0
              esc_power: 0
            esc[5] (esc_report):
              timestamp: 0
              esc_errorcount: 0
              esc_rpm: 0
              failures: 0
              esc_address: 0
              esc_cmdcount: 0
              esc_state: 0
              esc_power: 0
            esc[6] (esc_report):
              timestamp: 0
              esc_errorcount: 0
              esc_rpm: 0
              failures: 0
              esc_address: 0
              esc_cmdcount: 0
              esc_state: 0
              esc_power: 0
            esc[7] (esc_report):
              timestamp: 0
              esc_errorcount: 0
              esc_rpm: 0
              failures: 0
              esc_address: 0
              esc_cmdcount: 0
              esc_state: 0
              esc_power: 0
          INFO  [muorb] SLPI: qshell gotten: voxl_esc status
          INFO  [muorb] SLPI:   arg0 = 'voxl_esc'
          INFO  [muorb] SLPI:   arg1 = 'status'
          INFO  [muorb] SLPI: Max update rate: 0 Hz
          INFO  [muorb] SLPI: Outputs on: no
          INFO  [muorb] SLPI: UART port: 2
          INFO  [muorb] SLPI: UART open: yes
          INFO  [muorb] SLPI:
          INFO  [muorb] SLPI: Params: VOXL_ESC_CONFIG: 1
          INFO  [muorb] SLPI: Params: VOXL_ESC_BAUD: 2000000
          INFO  [muorb] SLPI: Params: VOXL_ESC_FUNC1: 103
          INFO  [muorb] SLPI: Params: VOXL_ESC_FUNC2: 102
          INFO  [muorb] SLPI: Params: VOXL_ESC_FUNC3: 104
          INFO  [muorb] SLPI: Params: VOXL_ESC_FUNC4: 101
          INFO  [muorb] SLPI: Params: VOXL_ESC_SDIR1: 0
          INFO  [muorb] SLPI: Params: VOXL_ESC_SDIR2: 0
          INFO  [muorb] SLPI: Params: VOXL_ESC_SDIR3: 0
          INFO  [muorb] SLPI: Params: VOXL_ESC_SDIR4: 0
          INFO  [muorb] SLPI: Params: VOXL_ESC_RPM_MIN: 700
          INFO  [muorb] SLPI: Params: VOXL_ESC_RPM_MAX: 8000
          INFO  [muorb] SLPI:
          INFO  [muorb] SLPI: -- ID: 0
          INFO  [muorb] SLPI:    Motor:           3
          INFO  [muorb] SLPI:    Direction:       1
          INFO  [muorb] SLPI:    State:           0
          INFO  [muorb] SLPI:    Requested:       0 RPM
          INFO  [muorb] SLPI:    Measured:        0 RPM
          INFO  [muorb] SLPI:    Command Counter: 137
          INFO  [muorb] SLPI:    Voltage:         24.010000 VDC
          INFO  [muorb] SLPI:
          INFO  [muorb] SLPI: -- ID: 1
          INFO  [muorb] SLPI:    Motor:           2
          INFO  [muorb] SLPI:    Command Counter: 138
          INFO  [muorb] SLPI:    Voltage:         24.028002 VDC
          INFO  [muorb] SLPI:
          INFO  [muorb] SLPI: -- ID: 2
          INFO  [muorb] SLPI:    Motor:           4
          INFO  [muorb] SLPI:    Command Counter: 139
          INFO  [muorb] SLPI:    Voltage:         24.020000 VDC
          INFO  [muorb] SLPI:
          INFO  [muorb] SLPI: -- ID: 3
          INFO  [muorb] SLPI:    Motor:           1
          INFO  [muorb] SLPI:    Command Counter: 136
          INFO  [muorb] SLPI:
          INFO  [muorb] SLPI: voxl_esc: cycle: 44256 events, 37887531us elapsed, 856.10us avg, min 64us max 2164us 318.
          INFO  [muorb] SLPI: voxl_esc: output update interval: 44255 events, 1271.43us avg, min 196us max 50628us 1397
          INFO  [muorb] SLPI: Param prefix: VOXL_ESC
          INFO  [muorb] SLPI: control latency: 44218 events, 60898443us elapsed, 1377.23us avg, min 314us max 3288us 48
          INFO  [muorb] SLPI: Switched to rate_ctrl work queue
          INFO  [muorb] SLPI: Channel Configuration:
          INFO  [muorb] SLPI: Channel 0: func: 103, value: 0, failsafe: 0, disarmed: 0, min: 700, max: 8000
          INFO  [muorb] SLPI: Channel 1: func: 102, value: 0, failsafe: 0, disarmed: 0, min: 700, max: 8000
          INFO  [muorb] SLPI: Channel 2: func: 104, value: 0, failsafe: 0, disarmed: 0, min: 700, max: 8000
          INFO  [muorb] SLPI: Channel 3: func: 101, value: 0, failsafe: 0, disarmed: 0, min: 700, max: 8000
          INFO  [muorb] SLPI: Ok executing command: voxl_esc status
          • Chase RileyC Chase Riley
            TOPIC: esc_status
             esc_status
                counter: 12602
                esc_count: 4
                esc_errorcount: 0
                esc_rpm: 0
                failures: 0
                esc_address: 3
                esc_cmdcount: 56
                esc_state: 0
                esc_power: 0
                esc_errorcount: 0
                esc_rpm: 0
                failures: 0
                esc_address: 2
                esc_cmdcount: 57
                esc_state: 0
                esc_power: 0
                esc_errorcount: 0
                esc_rpm: 0
                failures: 0
                esc_address: 4
                esc_cmdcount: 58
                esc_state: 0
                esc_power: 0
                esc_errorcount: 0
                esc_rpm: 0
                failures: 0
                esc_address: 1
                esc_cmdcount: 55
                esc_state: 0
                esc_power: 0
                timestamp: 0
                esc_errorcount: 0
                esc_rpm: 0
                failures: 0
                esc_address: 0
                esc_cmdcount: 0
                esc_state: 0
                esc_power: 0
                timestamp: 0
                esc_errorcount: 0
                esc_rpm: 0
                failures: 0
                esc_address: 0
                esc_cmdcount: 0
                esc_state: 0
                esc_power: 0
                timestamp: 0
                esc_errorcount: 0
                esc_rpm: 0
                failures: 0
                esc_address: 0
                esc_cmdcount: 0
                esc_state: 0
                esc_power: 0
                timestamp: 0
                esc_errorcount: 0
                esc_rpm: 0
                failures: 0
                esc_address: 0
                esc_cmdcount: 0
                esc_state: 0
                esc_power: 0
            INFO  [muorb] SLPI:
            INFO  [muorb] SLPI:
            INFO  [muorb] SLPI:
            INFO  [muorb] SLPI:
            INFO  [muorb] SLPI:
            INFO  [muorb] SLPI:
            @Chase-Riley, your output indicates that the ESC driver in PX4 is communicating with the ESC, I do not see any issue with that!
              Chase Riley
              @Alex-Kushleyev Not sure what happened but you are correct it is functioning now.
                voxl-px4 -d
                Matthew Wellner
                Interesting - px4-listener esc_status gives me "never published".
                  Matthew Wellner
                  When I run and the motors don't spin up here is what your second set of commands gives me:
                    Matthew Wellner
                    I also watched as px4 started up and it looks like the process fails to open the port for the ESC (see the red after the voxl_esc start command) -
                      @Matthew-Wellner your ESC baud rate in PX4 params is 200,000 , not 2,000,000 which is most likely the issue.
                        the failure to open the UART port is most likely due to unsupported baud rate (200,000) instead of desired baud rate (2,000,000)
                          Matthew Wellner
                          @Alex-Kushleyev - Thanks again. You were right and that was all I needed to change. Sorry!
                            @Matthew-Wellner , no worries! I am glad you got that part working.
                            Kiazoa JoaoK 1 Reply Last reply
                              Kiazoa JoaoK Offline
                              Kiazoa Joao
                              @Alex-Kushleyev I had a similar issue and this helped a lot. thanks.
