    avoidance collision prevention disabled
    8340
    • A
      AP123
      Avoidance collision prevention disabled, not sure why its not working. I'm running 0.9.5 SDK. VOA is set to true. All help is appreciated.
      Thank you
        tom admin @AP123
        @AP123 First off I'd recommend loading SDK 1.0 but secondly did you load the voa helper files from https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.12/collision_prevention_enable.params ?
        These are px4 v1.12 specific since you're on SDK 0.9.5
        • A
          AP123 @tom
          @tom I have not, are there instructions on how to load the file by chance?
            tom admin @AP123
            @AP123 SDK 1.0 allows you to load params using an onboard wizard but on 0.9.5 you'll have to load them via. QGroundControl: https://docs.modalai.com/upload-px4-parameters/#4-upload-parameters-file
            You'll have to clone the https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params repo and load this file https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.12/collision_prevention_enable.params through the above method
            • A
              AP123 @tom
              @tom I have loaded the file but it still says avoidance system not available. Any ideas why?
                tom admin @AP123
                @AP123 Where is it saying that message>
                • A
                  AP123 @tom
                  @tom image.png On QGC when i try to arm the drone.
                  • A
                    AP123 @AP123
                      tom admin @AP123
                      @AP123 Are you able to see all the expected data in voxl-portal? https://docs.modalai.com/voxl-vision-px4-collision-prevention-0_9/#voxl-portal-to-view-depth-map
                      • A
                        AP123 @tom
                        This is what i have
                          tom admin @AP123
                          @AP123 And when you view them , data is coming through correctly?
                          • A
                            AP123 @tom
                            @tom No data is coming through. I tried messing with QGC IP in /etc/modalai/voxl-vision-px4.conf. But didn't work. Where can i find that value just to verify i changed it correctly? Also, could there be another reason data is not coming in?
                              tom admin @AP123
                              @AP123 In portal you aren't seeing anything when you select "Stereo Front Disparity" for example?
                              • A
                                AP123 @tom
                                nope nothing
                                  tom admin @AP123
                                  @AP123 What about the "stereo" one itself?
                                  A 2 Replies Last reply Reply Quote 0
                                  • A
                                    AP123 @tom
                                    @tom yes i have camera feed there
                                    • A
                                      AP123 @tom
                                      @tom ok, i am getting data now from all off them! Although the avoidance system is still not working
                                        tom admin @AP123
                                        @AP123 might be worth trying this to see if the voxl-vision-px4 is handling the avoidance data correctly: https://docs.modalai.com/voxl-vision-px4-collision-prevention-0_9/#debugging-collision-prevention
                                        • A
                                          AP123 @tom
                                          @tom The data is flowing properly but QGC is still saying Not Ready, and Avoidance system not ready. What else can i do?
                                            tom admin @AP123
                                            @AP123 When you click on Not Ready does it give you any more info?
