avoidance collision prevention disabled
@AP123 First off I'd recommend loading SDK 1.0 but secondly did you load the voa helper files from https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.12/collision_prevention_enable.params ?
These are px4 v1.12 specific since you're on SDK 0.9.5
This post is deleted! -
@AP123 SDK 1.0 allows you to load params using an onboard wizard but on 0.9.5 you'll have to load them via. QGroundControl: https://docs.modalai.com/upload-px4-parameters/#4-upload-parameters-file
You'll have to clone the https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params repo and load this file https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.12/collision_prevention_enable.params through the above method
@AP123 Are you able to see all the expected data in voxl-portal? https://docs.modalai.com/voxl-vision-px4-collision-prevention-0_9/#voxl-portal-to-view-depth-map
@AP123 In portal you aren't seeing anything when you select "Stereo Front Disparity" for example?
@AP123 might be worth trying this to see if the voxl-vision-px4 is handling the avoidance data correctly: https://docs.modalai.com/voxl-vision-px4-collision-prevention-0_9/#debugging-collision-prevention
