  3. Not going in Position mode
29 Posts 7 Posters 7.3k Views 5 Watching
  • G Offline
    G Offline
    gauravshukla914
    @tom I'm just attemting to use VIO.
      @gauravshukla914 Okay, in that case we will want to get you updated to System Image 3.2.0 / voxl-suite 0.3.4.
      Before we do that though, I want to make sure you are able to backup your camera calibration files so that you won't need to re-calibrate.
      In order to do this you can use the voxl-backup utility which should currently be installed on your VOXL as it is included in the voxl-utils package.
      First you will use voxl-backup -b BACKUP_PATH in order to save your camera calibration files to the specified path. Then, I would recommend pulling these files off of your voxl using adb pull BACKUP_PATH HOST_PC_DIR so that you have them saved for the future.
      You can then go ahead and flash System Image 3.2.0, located here.
      After you finish flashing you can adb push your camera cal files back onto your VOXL and use voxl-backup -r BACKUP_ROOT in order to restore them to their correct locations.
      • G Offline
        G Offline
        gauravshukla914
        @tom I did that. I flashed with the image that you asked me to. Unfortunately the problem is still there. I'm able to see the odometry on my terminal once I do the "voxl-version-px4 -o". But no luck with the QgroundControl. Basically the same problem!
        adb shell
        / # voxl-version
        cat: /etc/modalai/voxl-software-bundle-version.txt: No such file or directory
        system-image:    ModalAI 3.2.0 BUILDER: ekatzfey BUILD_TIME: 2021-02-05_19:54
        kernel:          #1 SMP PREEMPT Fri Feb 5 20:03:22 UTC 2021 3.18.71-perf
        factory-bundle:  1.0.1 (Yocto installation)
        architecture:    aarch64
        processor:       apq8096
        os:              GNU/Linux
        voxl-suite:
        Package: voxl-suite
        Version: 0.3.4
        Depends: voxl-utils (>= 0.6.0), libmodal_json (>= 0.3.4), libmodal_pipe (>= 1.7.8), librc_math (>= 1.1.4), libvoxl_io (>= 0.5.4), mavlink-camera-manager (>= 0.0.1), opencv (>= 4.5.1), openmp (>= 10.0.1), voxl-camera-server (>= 0.5.6), voxl-dfs-server (>= 0.0.7), voxl-docker-support (>= 1.1.1), voxl-gphoto2 (>= 0.0.5), voxl-hal3-tof-cam-ros (>= 0.0.5), voxl-imu-server (>= 0.7.8), voxl-modem (>= 0.11.0), voxl-mpa-tflite-server (>= 0.0.2), voxl-mpa-tools (>= 0.1.6), voxl-nodes (>= 0.1.3), voxl-qvio-server (>= 0.2.1), voxl-rtsp (>= 1.0.3), voxl-streamer (>= 0.2.1), voxl-vision-px4 (>= 0.8.1), voxl-vpn (>= 0.0.3)
        Section: base
        Architecture: all
        Maintainer: james@modalai.com
        MD5Sum: e1e5bf1a125affe5036099f6ce895bed
        Filename: voxl-suite_0.3.4.ipk
        Description: meta-package for voxl-suite stable release
        Installed-Time: 1622142966
        Package: voxl-suite
        Version: 0.2.0
        Depends: docker, imu_app (= 0.0.6), libvoxl_io (= 0.5.2), voxl-cam-manager (= 0.2.2), voxl-docker-support (= 1.1.1), voxl-hal3-tof-cam-ros (= 0.0.2), voxl-modem (= 0.10.0), voxl-nodes (= 0.0.8), voxl-rtsp (= 1.0.2), voxl-utils (= 0.5.2), voxl-vision-px4 (= 0.6.8), voxl_imu (= 0.0.4), voxl-time-sync (= 0.0.1), voxl-vpn (= 0.0.2), librc_math (= 1.1.2), libmodal_pipe (= 1.2.2), modalai-vl (= 0.1.3)
        Section: base
        Architecture: armv7a
        MD5Sum: af706cd3c1ea59f274f2ed9b93141f1d
        Filename: voxl-suite_0.2.0.ipk
        Description: meta-package to install all of the voxl-suite
          @gauravshukla914 Can you post your voxl-vision-px4 conf file?
          cat /etc/modalai/voxl-vision-px4.conf
          • G Offline
            G Offline
            gauravshukla914
            @tom said in Not going in Position mode:
            	"qgc_ip":	"192.168.100.174",
            	"en_secondary_qgc":	false,
            	"secondary_qgc_ip":	"192.168.1.214",
            	"qgc_udp_port_number":	14550,
            	"en_vio":	true,
            	"en_voa":	false,
            	"en_send_vio_to_qgc":	true,
            	"en_send_voa_to_qgc":	false,
            	"en_adsb":	true,
            	"adsb_uart_bus":	7,
            	"adsb_uart_baudrate":	57600,
            	"px4_uart_bus":	5,
            	"px4_uart_baudrate":	921600,
            	"offboard_mode":	"off",
            	"follow_tag_id":	0,
            	"en_apriltag_fixed_frame":	false,
            	"fixed_frame_filter_len":	5,
            	"en_transform_mavlink_pos_setpoints_from_fixed_frame":	true
            • G Offline
              G Offline
              gauravshukla914
              @tom @modaltb @Jeremy-Schmidt is there anything else I can send?
                @gauravshukla914 see this post here. In there case they had the same symptom. To fix, they made sure voxl-imu-server and voxl-camera-server were running on boot and feeding the data to voxl-qvio-server
                • G Offline
                  G Offline
                  gauravshukla914
                  @Chad-Sweet I made sure this, but still no luck with the local position ned and its still failing to go into position mode. I have attached the screenshots.
                  @modaltb @tom @Jeremy-Schmidt is there a way we can set up a screen share for this? I think it'd be great if we can do that and may be together we can come up with a solution for this.qgc.png voxl.png
                  • Cliff WongC Offline
                    Cliff WongC Offline
                    Cliff Wong
                    Can you report what your EKF2_AID_MASK is set to in PX4 and post the value? thanks.
                    • G Offline
                      G Offline
                      gauravshukla914
                      wrote on last edited by gauravshukla914
                      #25
                      @Cliff-Wong its set to 280. I have also posted the PX4 param above somewhere in the beginning and you can have a look at that too.
                        Have you changed the firmware in some way? This is not normal behavior. You could try going to original firmware and settings: https://docs.modalai.com/flight-core-firmware/
                        • G gauravshukla914
                          Cliff WongC Offline
                          Cliff WongC Offline
                          Cliff Wong
                          @gauravshukla914
                          thanks, if you are using standard firmware as Chad mentioned in the following post, PX4 (not voxl) selectively stops certain position updates in order to trigger specific logic in ECL. Saying that, the behavior you're seeing appears just like aid mask (280) is being ignored. If you watch this: https://drive.google.com/file/d/15MPZeez2zgfBQySNgxlsEqq3Ttj34b7M/view?usp=sharing I think I recreated your behavior as described (note "afla" = udp). Thus, you may want to explicitly set aid_mask/reboot to confirm the same behavior which will help us narrow down the problem to mavlink (possible crc issue) or px4-general logic.
                          If you are using custom firmware, it very likely the aid mask param is not setting the internal modes properly.
                          • G Offline
                            G Offline
                            gauravshukla914
                            @Chad-Sweet No I have not changed the firmware. The firmware version is 1.11.3. I have also attached the picture of it in my previous comments. We are running out of ideas now.
                            @Cliff-Wong - Thanks for the video. We did set the aid mask explicitly to 280 multiple times and rebooted PX4, but still no luck
                            • James StrawsonJ Offline
                              James Strawson
                              Do you have a GPS/Mag plugged in? If not please try plugging in a GPS/Mag and set the PX4 parameter SYS_HAS_MAG to 1. There is a PX4 bug that prevents VIO-only operation if a magnetometer is missing, even if the magnetometer is not in use.
                              We've been trying to get the bugfix approved and merged into PX4 master for over a year now but it seems to be a lost cause. For now our own branch of PX4 has the bugfix along with some custom tools for our ESCs. If your system starts working again with the magnetometer then we know somehow a standard PX4 image got onto your flight core instead of one of our own.
                              Regards,
                              James
