  3. voxl-streamer client repetitive connect/disconnect
63 Posts 3 Posters 35.4k Views 3 Watching
  • wilkinsafW wilkinsaf
    @Eric-Katzfey
    Apologies for the delay. Some other things came up.
    I was able to pull down the camera information. We have 2 cameras we are trying to get up.
    Cam 1: https://pastebin.com/qHvHKXay
    Cam 2: https://pastebin.com/7DgvP58k
    They appear to be able to post in MJPEG
    @wilkinsaf There are some clues here: https://github.com/gregkh/usbutils/issues/42. It seems like there are some endian issues with interpretation of the guidFormat field. For example, for my Logitech C270 test camera, lsusb reports the guidFormat as 32595559-0000-0010-8000-00aa00389b71 but libuvc (which voxl-uvc-server uses) reports the guidFormat as 59555932-0000-1000-8000-00aa00389b71. So, my guess is that since lsusb reports the guidFormat of your camera as 59555932-0000-1000-8000-00aa00389b71, libuvc (and hence voxl-uvc-server) will see it as 32595559-0000-0010-8000-00aa00389b71 which doesn't match any valid formats. I think I can hack libuvc to add the extra guidFormat and then your cameras will work but I won't be able to test it without one of your cameras. But I will post it and you can try it. For reference this is where libuvc needs to be modified to add the extra guidFormat: https://github.com/libuvc/libuvc/blob/37f00abd32b083a3d748f2a25c1c794578b51c16/src/stream.c#L109
      @Eric-Katzfey
      @wilkinsaf There is a new version of libuvc available at http://voxl-packages.modalai.com/dev/libuvc_1.0.2_202112182223.ipk with the changes. If you rebuild the dev branch of voxl-uvc-server and install build deps from dev you should pick up the new libuvc. Then you can rebuild and test with your camera.
      wilkinsafW 2 Replies Last reply
        wilkinsafW Offline
        wilkinsafW Offline
        wilkinsaf
        @Eric-Katzfey roger that. thank you for your support here Eric
          wilkinsafW Offline
          wilkinsafW Offline
          wilkinsaf
          @Eric-Katzfey will post results after run
            @wilkinsaf Project is here: https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-uvc-server
            wilkinsafW Offline
            wilkinsafW Offline
            wilkinsaf
            @Eric-Katzfey Sorry for being such a pain, but it seems like this repo keeps moving.
            I went to https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-uvc-server
            but got this
            I keep searching around for the repo, but can not find it
              but got this
              @wilkinsaf Sorry, it was setup as private. I changed it to public. Can you try again?
                wilkinsafW Offline
                wilkinsafW Offline
                wilkinsaf
                @Eric-Katzfey Got it, thank you!
                Will download and play with
                  wilkinsafW Offline
                  wilkinsafW Offline
                  wilkinsaf
                  @Eric-Katzfey Will it remain public?
                    @wilkinsaf Yes, it will remain public. Did you get a chance to see if the changes worked?
                      wilkinsafW Offline
                      wilkinsafW Offline
                      wilkinsaf
                      @Eric-Katzfey Testing out today
                        wilkinsafW Offline
                        wilkinsafW Offline
                        wilkinsaf
                        @Eric-Katzfey
                        We seem to be having trouble finding the camera now which is weird. I wonder if we need to specifically download and install the drivers?
                          @Eric-Katzfey
                          @wilkinsaf No, you shouldn't need any drivers. Any USB device should be listed with lsusb, even without any specific drivers. Does it show up when plugged into a regular Linux computer?
                          wilkinsafW 1 Reply Last reply
                            wilkinsafW Offline
                            wilkinsafW Offline
                            wilkinsaf
                            @Eric-Katzfey Yes, we have hardwired it into a computer before. We have seen the stream using ffmpeg on VOXL as well. We just can not seem to get voxl-streamer to work with it
                              @Eric-Katzfey
                              @wilkinsaf If you unplug the camera from Voxl does anything disappear from the lsusb list?
                                wilkinsafW Offline
                                wilkinsafW Offline
                                wilkinsaf
                                wrote on last edited by wilkinsaf
                                #35
                                @Eric-Katzfey
                                Yes, the top 3 entries in lsusb screenshots above are all cameras. I can unplug those one by one and see them disappear.
                                Would it matter if we have 2 UVC cameras?
                                  @Eric-Katzfey
                                  @wilkinsaf Just try one at a time for now. And when you plug the camera in do you see a new /dev/videoX entry appear?
                                    @Eric-Katzfey
                                    @wilkinsaf Also, were you able to get the ordering information for these cameras? If they aren't too expensive I would like to order at least one of them to test against.
                                    wilkinsafW 3 Replies Last reply
                                      wilkinsafW Offline
                                      wilkinsafW Offline
                                      wilkinsaf
                                      @Eric-Katzfey
                                      Yes, let me try one at a time now.
                                      Here are the two cameras
                                      4de39b51-2708-4707-a1fe-d67161270aa3-image.png ![0_1640728100493_PXL_20211228_214717072.jpg](Uploading 100%)
                                      1. Banggood URL
                                      2. Blue Robotics URL
                                        wilkinsafW Offline
                                        wilkinsafW Offline
                                        wilkinsaf
                                        @Eric-Katzfey
                                        Good news, I was able to get voxl-uvc-server to spin up with one usb camera connected.
                                        However, I am getting this issue from voxl-streamer
                                        Seems like I need to figure out the frame size and set the correct one. Let me play around with that now
                                          wilkinsafW Offline
                                          wilkinsafW Offline
                                          wilkinsaf
                                          @Eric-Katzfey Doesn't look to be frame size as the "sizes" seem non-deterministic
