  3. voxl-streamer client repetitive connect/disconnect
63 Posts 3 Posters 37.8k Views 3 Watching
    @wilkinsaf That shows a failure of the camera to support either MJPEG or YUV422. In order to support that camera you need to know what formats it supports. The best way to do that is to query it's capabilities on the command line. First of all use the lsusb command to find out the device id and product id of the camera. For example:
    Ubuntu18$ lsusb
    Bus 001 Device 090: ID 046d:0825 Logitech, Inc. Webcam C270
    This shows you that the UVC webcam has device id and product id 046d:0825. You can use that to query it's capabilities with lsusb -v -d 046d:0825. This will dump all of the camera capabilities to the output. Can you respond with the output from your camera?
    wilkinsafW Offline
    wilkinsafW Offline
    wilkinsaf
    Apologies for the delay. Some other things came up.
    I was able to pull down the camera information. We have 2 cameras we are trying to get up.
    Cam 1: https://pastebin.com/qHvHKXay
    Cam 2: https://pastebin.com/7DgvP58k
    They appear to be able to post in MJPEG
    Eric KatzfeyE 4 Replies Last reply
    • wilkinsafW Offline
      wilkinsafW Offline
      wilkinsaf
      Not sure if voxl-uvc-server got removed.
      I can not seem to find it in the public repo:
      • wilkinsafW wilkinsaf
        @wilkinsaf Project is here: https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-uvc-server
        wilkinsafW 1 Reply Last reply
          @wilkinsaf The current voxl-uvc-server capabilities only cover uncompressed frames, not mjpeg. The two cameras that you are looking at both have uncompressed formats but the guidFormat is slightly different than the cameras I have tested with. Let me look into this a little deeper.
            @wilkinsaf The formats should be compatible. I'll have to dig into the libuvc code to see why they are not accepted.
              @wilkinsaf Are either of these cameras cheap and easy to purchase?
                wilkinsafW Offline
                wilkinsaf
                I believe so. Let me find them online really quick. I was able to get the video's from the cameras streaming using the directions here: https://docs.modalai.com/uvc-streaming/
                I moved over the ffmpeg ipk and executed
                ffmpeg -i /dev/video2 -f mpegts udp://QCS_IP:4242
                So I know that they are working.
                  @wilkinsaf There are some clues here: https://github.com/gregkh/usbutils/issues/42. It seems like there are some endian issues with interpretation of the guidFormat field. For example, for my Logitech C270 test camera, lsusb reports the guidFormat as 32595559-0000-0010-8000-00aa00389b71 but libuvc (which voxl-uvc-server uses) reports the guidFormat as 59555932-0000-1000-8000-00aa00389b71. So, my guess is that since lsusb reports the guidFormat of your camera as 59555932-0000-1000-8000-00aa00389b71, libuvc (and hence voxl-uvc-server) will see it as 32595559-0000-0010-8000-00aa00389b71 which doesn't match any valid formats. I think I can hack libuvc to add the extra guidFormat and then your cameras will work but I won't be able to test it without one of your cameras. But I will post it and you can try it. For reference this is where libuvc needs to be modified to add the extra guidFormat: https://github.com/libuvc/libuvc/blob/37f00abd32b083a3d748f2a25c1c794578b51c16/src/stream.c#L109
                    @wilkinsaf There is a new version of libuvc available at http://voxl-packages.modalai.com/dev/libuvc_1.0.2_202112182223.ipk with the changes. If you rebuild the dev branch of voxl-uvc-server and install build deps from dev you should pick up the new libuvc. Then you can rebuild and test with your camera.
                    wilkinsafW 2 Replies Last reply
                      wilkinsafW Offline
                      wilkinsafW Offline
                      wilkinsaf
                      @Eric-Katzfey roger that. thank you for your support here Eric
                        wilkinsafW Offline
                        wilkinsafW Offline
                        wilkinsaf
                        @Eric-Katzfey will post results after run
                          wilkinsafW Offline
                          wilkinsafW Offline
                          wilkinsaf
                          @Eric-Katzfey Sorry for being such a pain, but it seems like this repo keeps moving.
                          I went to https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-uvc-server
                          but got this
                          I keep searching around for the repo, but can not find it
                            but got this
                            @wilkinsaf Sorry, it was setup as private. I changed it to public. Can you try again?
                              wilkinsafW Offline
                              wilkinsafW Offline
                              wilkinsaf
                              @Eric-Katzfey Got it, thank you!
                              Will download and play with
                                wilkinsafW Offline
                                wilkinsafW Offline
                                wilkinsaf
                                @Eric-Katzfey Will it remain public?
                                  @wilkinsaf Yes, it will remain public. Did you get a chance to see if the changes worked?
                                    wilkinsafW Offline
                                    wilkinsafW Offline
                                    wilkinsaf
                                    @Eric-Katzfey Testing out today
                                      wilkinsafW Offline
                                      wilkinsafW Offline
                                      wilkinsaf
                                      We seem to be having trouble finding the camera now which is weird. I wonder if we need to specifically download and install the drivers?
                                        @wilkinsaf No, you shouldn't need any drivers. Any USB device should be listed with lsusb, even without any specific drivers. Does it show up when plugged into a regular Linux computer?
                                          wilkinsafW Offline
                                          wilkinsafW Offline
                                          wilkinsaf
                                          @Eric-Katzfey Yes, we have hardwired it into a computer before. We have seen the stream using ffmpeg on VOXL as well. We just can not seem to get voxl-streamer to work with it
