  3. voxl-streamer client repetitive connect/disconnect
63 Posts 3 Posters 37.8k Views 3 Watching
  • wilkinsafW wilkinsaf
    quick comment for anyone reading this, it is
    voxl-uvc-server -d when running
    @wilkinsaf Thanks! I fixed the typo in the original post.
    • wilkinsafW Offline
      wilkinsafW Offline
      wilkinsaf
      #12
      I am seeing that this failed for MJPEG
      voxl:~$ voxl-uvc-server -d
      Enabling debug messages
      voxl-uvc-server starting
      UVC initialized
      Device found
      Device opened
      uvc_get_stream_ctrl_format_size failed for MJPEG
      Is there a config file for this that I can modify to change the format?
        UVC initialized
        Device found
        Device opened
        @wilkinsaf That shows a failure of the camera to support either MJPEG or YUV422. In order to support that camera you need to know what formats it supports. The best way to do that is to query it's capabilities on the command line. First of all use the lsusb command to find out the device id and product id of the camera. For example:
        Ubuntu18$ lsusb
        Bus 001 Device 090: ID 046d:0825 Logitech, Inc. Webcam C270
        This shows you that the UVC webcam has device id and product id 046d:0825. You can use that to query it's capabilities with lsusb -v -d 046d:0825. This will dump all of the camera capabilities to the output. Can you respond with the output from your camera?
        wilkinsafW 1 Reply Last reply
          Ubuntu18$ lsusb
          wilkinsafW Offline
          wilkinsafW Offline
          wilkinsaf
          Apologies for the delay. Some other things came up.
          I was able to pull down the camera information. We have 2 cameras we are trying to get up.
          Cam 1: https://pastebin.com/qHvHKXay
          Cam 2: https://pastebin.com/7DgvP58k
          They appear to be able to post in MJPEG
          Eric KatzfeyE 4 Replies Last reply
            wilkinsafW Offline
            wilkinsaf
            Not sure if voxl-uvc-server got removed.
            I can not seem to find it in the public repo:
              @wilkinsaf Project is here: https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-uvc-server
                @wilkinsaf The current voxl-uvc-server capabilities only cover uncompressed frames, not mjpeg. The two cameras that you are looking at both have uncompressed formats but the guidFormat is slightly different than the cameras I have tested with. Let me look into this a little deeper.
                  @wilkinsaf The formats should be compatible. I'll have to dig into the libuvc code to see why they are not accepted.
                    @wilkinsaf Are either of these cameras cheap and easy to purchase?
                      wilkinsafW Offline
                      wilkinsaf
                      I believe so. Let me find them online really quick. I was able to get the video's from the cameras streaming using the directions here: https://docs.modalai.com/uvc-streaming/
                      I moved over the ffmpeg ipk and executed
                      ffmpeg -i /dev/video2 -f mpegts udp://QCS_IP:4242
                      So I know that they are working.
                        @wilkinsaf There are some clues here: https://github.com/gregkh/usbutils/issues/42. It seems like there are some endian issues with interpretation of the guidFormat field. For example, for my Logitech C270 test camera, lsusb reports the guidFormat as 32595559-0000-0010-8000-00aa00389b71 but libuvc (which voxl-uvc-server uses) reports the guidFormat as 59555932-0000-1000-8000-00aa00389b71. So, my guess is that since lsusb reports the guidFormat of your camera as 59555932-0000-1000-8000-00aa00389b71, libuvc (and hence voxl-uvc-server) will see it as 32595559-0000-0010-8000-00aa00389b71 which doesn't match any valid formats. I think I can hack libuvc to add the extra guidFormat and then your cameras will work but I won't be able to test it without one of your cameras. But I will post it and you can try it. For reference this is where libuvc needs to be modified to add the extra guidFormat: https://github.com/libuvc/libuvc/blob/37f00abd32b083a3d748f2a25c1c794578b51c16/src/stream.c#L109
                          @wilkinsaf There is a new version of libuvc available at http://voxl-packages.modalai.com/dev/libuvc_1.0.2_202112182223.ipk with the changes. If you rebuild the dev branch of voxl-uvc-server and install build deps from dev you should pick up the new libuvc. Then you can rebuild and test with your camera.
                          wilkinsafW 2 Replies Last reply
                            wilkinsafW Offline
                            wilkinsafW Offline
                            wilkinsaf
                            @Eric-Katzfey roger that. thank you for your support here Eric
                              wilkinsafW Offline
                              wilkinsafW Offline
                              wilkinsaf
                              @Eric-Katzfey will post results after run
                                wilkinsafW Offline
                                wilkinsafW Offline
                                wilkinsaf
                                @Eric-Katzfey Sorry for being such a pain, but it seems like this repo keeps moving.
                                I went to https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-uvc-server
                                but got this
                                I keep searching around for the repo, but can not find it
                                  but got this
                                  @wilkinsaf Sorry, it was setup as private. I changed it to public. Can you try again?
                                    wilkinsafW Offline
                                    wilkinsafW Offline
                                    wilkinsaf
                                    @Eric-Katzfey Got it, thank you!
                                    Will download and play with
                                      wilkinsafW Offline
                                      wilkinsafW Offline
                                      wilkinsaf
                                      @Eric-Katzfey Will it remain public?
                                        @wilkinsaf Yes, it will remain public. Did you get a chance to see if the changes worked?
                                          wilkinsafW Offline
                                          wilkinsafW Offline
                                          wilkinsaf
                                          @Eric-Katzfey Testing out today
