  3. M0173 dual tracking camera error
12 Posts 3 Posters 1.7k Views 2 Watching
  • Jetson NanoJ Offline
    Jetson Nano
    Veteran
    Hello @Alex-Kushleyev @Eric-Katzfey @tom @modaltb can anyone help me with this error.
    I am using the sdk 1.4.0 with the m0173 board with the configuration 29. While I run the voxl-qvio server I am getting error of missing files both opencv_tracking_front_intrinsics.yml and opencv_tracking_down_intrinsics.yml. even after manually placing them there are other errors occuring.
    voxl2:/$ voxl-qvio-server
    loading config file
    odr_hz:                           30.000
    use_camera_height_bootstrap:      1
    camera_height_off_ground_m:        0.085
    enable_init_while_moving:         0
    cam_imu_timeshift_s:               0.000
    cam_imu_timeshift_s_uncertainty:   0.000
    T_cam_wrt_imu_uncertainty:         0.001  0.001  0.001
    R_cam_to_imu_uncertainty:          0.005  0.005  0.005
    accl_fsr_ms2:                     156.000
    gyro_fsr_rad:                     34.000
    accl_noise_std_dev:                0.316
    gyro_noise_std_dev:                0.010
    cam_noise_std_dev:                100.000
    min_std_pixel_noise:               0.500
    fail_high_pixel_noise_points:      1.665
    limited_imu_bw_trigger:           25.000
    gps_imu_time_alignment_s:          0.000
    T_gps_wrt_imu:                     0.000  0.000  0.000
    enable_mapping:                   1
    enable_gps_vel:                   0
    en_auto_reset:                    1
    auto_reset_max_velocity:          10.000
    auto_reset_max_v_cov_instant:      0.100
    auto_reset_max_v_cov:              0.010
    auto_reset_max_v_cov_timeout_s:    0.500
    auto_reset_min_features:          3
    auto_reset_min_feature_timeout_s:  1.000
    en_standby_mode:                  1
    standby_skip_frames:              1
    mask_file_path:
    vio_cam config:
    cam 0:
        enable:                1
        pipe_for_preview:      tracking_front
        pipe_for_tracking:     tracking_front_misp_norm
        is_occluded_on_ground: 0
        imu:                   imu_apps
        is_extrinsic_present:  1
        extrinsic cam wrt imu:
        parent:                imu_apps
        child:                 tracking_front
        T_cam_wrt_imu:         0.037   0.000   0.001
        RPY_imu_to_cam:        0.0    90.0    90.0
        R_cam_to_imu:          0.000  -0.000   1.000
                               1.000   0.000  -0.000
                              -0.000   1.000   0.000
        cal file:              opencv_tracking_front_intrinsics.yml
        is_cal_present:        1
        cam cal intrinsics:
        width:                 640
        height:                480
        fx:                    286.951
        fy:                    288.010
        cx:                    339.072
        cy:                    232.400
        n_coeffs:              4
        is_fisheye:            1
        D: -0.0135 0.0046 0.0000 0.0000
    existing instance of qvio-server found, attempting to stop it
    thread is locked to cores: 4 5 6 7
    waiting for imu
    waiting for cam
    connected to imu server
    waiting for cpu_monitor
    connected to camera server
    Connected to cpu-monitor
    ERROR expected 1280x800 img, got 640x480
    Image resolution must match what's in the selected lens cal file
    and another error is voxl-mapper not starting because of vio error.
    which is better qvio or ov.
    voxl2:/$ voxl-mapper
    Loading our own config file
    Loading extrinsics config file
    existing instance of voxl-mapper found, attempting to stop it
    Trying to init tsdf server
    created tsdf server
    waiting for server at /run/mpa/vvhub_body_wrt_fixed/
    waiting for server at /run/mpa/tof
    Connected to VIO server
    Initializing ESDF structs
    Connected to depth pipe
    ESDF Thread is now locked to the following cores: 4 5 6
    INFO waiting for VIO to start
    voxl2:~$ voxl-inspect-vins
    waiting for server at /run/mpa/ov_extended
        T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)| state| error_code
        0.00    0.00    0.00|   0.0   -0.0    0.0| INIT | STALLED ERROR validating t
    read 8424 bytes, but it should be a multiple of 5268
    ERROR validating EXT VIO data received through pipe: read partial packet
    read 2112 bytes, but it should be a multiple of 5268
        0.00    0.00    0.00|   0.0   -0.0    0.0| INIT | STALLED ^C
    received SIGINT Ctrl-C
    voxl2:~$ voxl-inspect-vio
    waiting for server
     dt(ms) |    T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)|features|quality| state|
       33.3 |    0.00    0.00    0.00|   0.0   -0.0    0.0|     0  |   -1% | FAIL |C
    closing and exiting
    voxl2:~$ voxl-inspect-vio-cams
    cam 0:
        enable:                1
        imu:                   imu_apps
        parent:                imu_apps
        T_cam_wrt_imu:         0.039   0.000   0.001
                               1.000   0.000  -0.000
                              -0.000   1.000   0.000
        is_cal_present:        1
        cam cal intrinsics:
        width:                 640
        height:                480
        fx:                    286.951
        fy:                    288.010
        cx:                    339.072
        cy:                    232.400
        n_coeffs:              4
        is_fisheye:            1
    cam 1:
        enable:                1
        pipe_for_preview:      tracking_down
        pipe_for_tracking:     tracking_down_misp_norm
        is_occluded_on_ground: 1
        imu:                   imu_apps
        parent:                imu_apps
        child:                 tracking_down
        T_cam_wrt_imu:        -0.089  -0.007   0.033
        RPY_imu_to_cam:        0.0     0.0   180.0
        R_cam_to_imu:         -1.000  -0.000   0.000
                               0.000  -1.000  -0.000
                               0.000   0.000   1.000
        cal file:              opencv_tracking_down_intrinsics.yml
        is_cal_present:        1
        cam cal intrinsics:
        width:                 640
        height:                480
        fx:                    286.951
        fy:                    288.010
        cx:                    339.072
        cy:                    232.400
        n_coeffs:              4
        is_fisheye:            1
    R_imu_apps_to_body:
              1.000  -0.000   0.000
              0.000   1.000  -0.000
              0.000   0.000   1.000
    |                 Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |t
    |   feature_tracker_overlay | 6144000 | 1280 | 1600 |  0.00 |    0 |        0 |    332.4  |  5.4 |  261.0 | RGB
    |    hires_down_large_color |18495360 | 4056 | 3040 | 33.23 | 6678 |    12245 |   1538.8  |  5.6 |  832.8 | NV12
    |  hires_down_large_encoded |    2336 | 4056 | 3040 | 33.23 | 6678 |    12247 |   1397.2  |  5.6 |    0.1 | H264 (P)
    |     hires_down_large_grey |12330240 | 4056 | 3040 | 33.23 | 6678 |    12247 |   1369.4  |  5.7 |  557.7 | RAW8
    |    hires_down_small_color | 1179648 | 1024 |  768 | 33.23 | 6678 |    12251 |   1327.3  |  5.8 |   54.7 | NV12
    |  hires_down_small_encoded |      64 | 1024 |  768 | 33.23 | 6678 |    12251 |   1312.8  |  5.8 |    0.0 | H264 (P)
    |     hires_down_small_grey |  786432 | 1024 |  768 | 33.23 | 6678 |    12249 |   1296.7  |  5.8 |   36.5 | RAW8
    |       hires_down_snapshot |  786432 | 1024 |  768 | 33.23 | 6678 |    12211 |   8
    |   hires_front_large_color |18495360 | 4056 | 3040 | 33.23 | 6678 |    12266 |   1946.7  |  5.5 |  813.1 | NV12
    | hires_front_large_encoded |   20304 | 4056 | 3040 | 33.23 | 6678 |    12268 |   1592.5  |  5.4 |    0.8 | H264 (P)
    |    hires_front_large_grey |12330240 | 4056 | 3040 | 33.23 | 6678 |    12268 |   1548.0  |  5.5 |  545.2 | RAW8
    |   hires_front_small_color | 1179648 | 1024 |  768 | 33.23 | 6678 |    12271 |   1503.0  |  5.6 |   53.2 | NV12
    | hires_front_small_encoded |    2496 | 1024 |  768 | 33.23 | 6678 |    12284 |   1545.8  |  6.1 |    0.1 | H264 (P)
    |    hires_front_small_grey |  786432 | 1024 |  768 | 33.23 | 6678 |    12273 |   1532.1  |  5.7 |   36.0 | RAW8
    |      hires_front_snapshot |  786432 | 1024 |  768 | 33.23 | 6678 |    12233 |   8
    |                ov_overlay | 2211840 | 1280 | 1728 | 12.00 | 1596 |    12487 |    298.3  |  4.5 |   80.3 | RAW8
    |                  tof_conf |   43200 |  180 |  240 |  0.06 |    0 |     4174 |    149.1  |  9.2 |    3.2 | RAW8
    |                 tof_depth |   43200 |  180 |  240 |  0.06 |    0 |     4174 |    148.8  |  9.2 |    3.2 | RAW8
    |                    tof_ir |   43200 |  180 |  240 |  0.06 |    0 |     4174 |    147.8  |  9.2 |    3.2 | RAW8
    |             tracking_down | 1024000 | 1280 |  800 | 12.00 | 1596 |    12457 |    189.0  | 14.6 |  119.8 | RAW8
    |       tracking_down_bayer | 1024000 | 1280 |  800 | 12.00 | 1596 |    12459 |    190.2  | 14.9 |  121.8 | RAW8
    |   tracking_down_misp_grey | 1024000 | 1280 |  800 | 12.00 | 1596 |    12459 |    189.5  | 14.9 |  121.8 | RAW8
    |   tracking_down_misp_norm | 1024000 | 1280 |  800 | 12.00 | 1596 |    12458 |    209.6  | 14.6 |  119.8 | RAW8
    |            tracking_front | 1024000 | 1280 |  800 | 12.00 | 1596 |    12492 |    198.6  | 16.5 |  135.5 | RAW8
    |      tracking_front_bayer | 1024000 | 1280 |  800 | 12.00 | 1596 |    12491 |    196.6  | 16.5 |  135.5 | RAW8
    |  tracking_front_misp_grey | 1024000 | 1280 |  800 | 12.00 | 1596 |    12492 |    177.6  | 16.5 |  135.5 | RAW8
    |  tracking_front_misp_norm | 1024000 | 1280 |  800 | 12.00 | 1596 |    12491 |    201.4  | 16.5 |  135.5 | RAW8
    ERROR: only read 0 bytes of data, expected 10240000 | 12.00 | 1596 |    12392 |   8
    voxl2:~$ voxl-inspect-services
    Scanning services...
     voxl-auto-logger         | Disabled  | Not Running |
     voxl-camera-server       |  Enabled  |   Running   |   204.0%
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.9%
     voxl-elrs-startup        | Disabled  | Not Running |
     voxl-feature-tracker     |  Enabled  |   Running   |    75.7%
     voxl-imu-server          |  Enabled  |   Running   |     3.6%
     voxl-io-server           | Disabled  | Not Running |
     voxl-lepton-server       |  Enabled  |   Running   |     3.4%
     voxl-lepton-tracker      | Disabled  | Not Running |
     voxl-logger              | Disabled  | Not Running |
     voxl-mapper              |  Enabled  |   Running   |     2.2%
     voxl-mavlink-server      |  Enabled  |   Running   |     1.8%
     voxl-open-vins-server    |  Enabled  |   Running   |    29.8%
     voxl-osd                 | Disabled  | Not Running |
     voxl-portal              |  Enabled  |   Running   |     1.8%
     voxl-px4-imu-server      | Disabled  | Not Running |
     voxl-px4                 | Disabled  | Not Running |
     voxl-qvio-server         | Disabled  | Not Running |
     voxl-rangefinder-server  |  Enabled  | Not Running |
     voxl-softap              |  Enabled  |  Completed  |
     voxl-state-estimator     | Disabled  | Not Running |
     voxl-streamer            |  Enabled  |   Running   |     0.0%
     voxl-vision-hub          |  Enabled  |   Running   |     3.4%
     voxl-vrx                 | Disabled  | Not Running |
     voxl-vtx                 | Disabled  | Not Running |
    • Alex KushleyevA Offline
      @Jetson-Nano , it seems you are using cameras that output image resolution of 1280x800 but the calibration files contain information for 640x480 resolution. Wrong calibration files?
      Please double check this.
        Jetson Nano
        Veteran
        @Alex-Kushleyev can you please share the calibration file opencv_tracking_open_intrinsics.yml and opencv_tracking_down_intrinsics.yml.
        • Jetson NanoJ Jetson Nano
          tomT Online
          tomT Online
          @Jetson-Nano Is this a Starling 2 drone that you're using? If so, if you provide the serial number of the drone I can provide the calibration files. If not, you'll have to do the calibration yourself using a calibration card.
            Jetson Nano
            Veteran
            @tom Yes I am using the starling 2 drone. I changed the camera modules to the latest cameras with M0173 board.
            where will I find the serial number?
              tomT Online
              tomT Online
              @Jetson-Nano The serial number is likely located somewhere on the frame of the drone. Should be on a white sticker and have the form MXX00000XXX
              Jetson NanoJ 2 Replies Last reply
                Jetson Nano
                Veteran
                  Jetson Nano
                  Veteran
                    [[topic:post-is-deleted]]
                    tomT Online
                    tomT Online
                    @Jetson-Nano oh sorry I missed that you swapped to the M0173 + AR0144s, in that case you will have to recalibrate the cameras yourself as all I have is the original camera calibration which won't match your new setup
                      Jetson Nano
                      Veteran
                      #10
                      @tom @Alex-Kushleyev @Eric-Katzfey
                      I calibrated the camera, now i am not getting error while running the qvio-server, but different debug message
                      voxl2:~$ voxl-qvio-server
                      loading config file
                      odr_hz:                           30.000
                      enable_mapping:                   1
                      enable_gps_vel:                   0
                      en_auto_reset:                    1
                      en_standby_mode:                  1
                      mask_file_path:
                      vio_cam config:
                      cam 0:
                          enable:                1
                          imu:                   imu_apps
                          parent:                imu_apps
                                                 1.000   0.000  -0.000
                                                -0.000   1.000   0.000
                          is_cal_present:        1
                          cam cal intrinsics:
                          width:                 1280
                          height:                800
                          fx:                    460.295
                          fy:                    462.185
                          cx:                    635.691
                          cy:                    396.209
                          n_coeffs:              4
                          is_fisheye:            1
                          D: 0.0752 -0.0103 0.0157 -0.0074
                      waiting for imu
                      waiting for cam
                      Client requested hard reset
                      WARNING failed to init in time, trying again
                      Still I am not able to get data from voxl-mapper. how can I use the vio data from open-vins-server rather qvio-server
                      created tsdf server
                        loading config file
                        odr_hz:                           30.000
                        enable_mapping:                   1
                        enable_gps_vel:                   0
                        en_auto_reset:                    1
                        en_standby_mode:                  1
                        mask_file_path:
                        vio_cam config:
                        cam 0:
                            enable:                1
                            imu:                   imu_apps
                            parent:                imu_apps
                                                   1.000   0.000  -0.000
                                                  -0.000   1.000   0.000
                            is_cal_present:        1
                            cam cal intrinsics:
                            width:                 1280
                            height:                800
                            fx:                    460.295
                            fy:                    462.185
                            cx:                    635.691
                            cy:                    396.209
                            n_coeffs:              4
                            is_fisheye:            1
                        waiting for imu
                        waiting for cam
                        created tsdf server
                        @Jetson-Nano , can you please clarify what you are working on? Are you setting single camera QVIO or your custom drone or dual camera Open Vins? Is it a custom drone and have you created correct extrinsic calibration files for the cameras / IMU transforms?
                          Jetson Nano
                          Veteran
                          @Alex-Kushleyev, I using voxl2 with M0173 board with camera config 29.
                          The errors are now solved, I made the necessary changes and reconfigured every server and pipeline and calibrated the cameras.
