    Drone not flying manually with ORQA FPV.Ctrl controller
    1217
    • Jainik MehtaJ
      Jainik Mehta
      Hello, I am trying to fly the starling 2 drone with the controller (uber lite ORQA FPV.Ctrl) that came with it, but somehow my drone is not arming. I am not sure if drone is even bounded to controller or not. But as soon as I turn on my controller the led in back turns green and also the led on drone turns green from red, which seems to me that controller is bounded, but then when I turn my left joystick to bottom right corner for arming the drone doesn't arm and propellor doesn't spin. The kill switch is also off. So I don't know what is the problem. Could you please help me with this?
      Thank you!
      tomT Eric KatzfeyE 2 Replies Last reply Reply Quote 0
      • tomT
        tom admin @Jainik Mehta
        @Jainik-Mehta I recommend connecting your drone to QGroundControl via WiFi and viewing the arming restriction messages
        • Eric KatzfeyE
          Eric Katzfey ModalAI Team @Jainik Mehta
          @Jainik-Mehta Can you arm directly with QGC? Also, try calibrating the RC in QGC to see if that changes things. Also, what is the value of the PX4 parameter MAN_ARM_GESTURE?
          Jainik MehtaJ 2 Replies Last reply Reply Quote 0
          • Jainik MehtaJ
            Jainik Mehta @Eric Katzfey
            @Eric-Katzfey I am trying to arm my drone via QGC but I am getting following error:
            I am not sure what can be the problem.
            • Jainik MehtaJ
              @Eric-Katzfey Also I am getting following message:
              I guess radio transmitter is still not paired. But drone light turns green as soon as I turn on the transmitter so what can be issue here?
              • tomT
                @Jainik-Mehta What does your /etc/modalai/voxl-px4.conf file look like?
                Jainik MehtaJ 1 Reply Last reply Reply Quote 0
                • Jainik MehtaJ
                  Jainik Mehta @tom
                  @tom said in Drone not flying manually with ORQA FPV.Ctrl controller:
                  This is my /etc/modalai/voxl-px4.conf file:
                  • tomT
                    @Jainik-Mehta RC needs to be set to GHST
                    • Jainik MehtaJ
                      Jainik Mehta @tom
                      @tom Thank you! This solution worked. I changed this value and reboot the drone and it now connects and fly well with the RC controller.
