  2. VOXL Compute & Autopilot
  3. Flight Core v2
  4. ArduPilot on Voxl2
ArduPilot on Voxl2
Scheduled Pinned Locked Moved Flight Core v2
45 Posts 6 Posters 24.7k Views 3 Watching
  • T TomP
    There is another problem. The PWM board does not output PWMs. I have also measured this with an oscilloscope. According to SERVO_OUTPUT_RAW, however, the FC should output PWM values.
    Do I have to set another parameter in Arduplane so that the VOXL 2 I/O Expander Board is controlled correctly?
    I use the VOXL2-Mini J19 connector: GND, pin 7, pin 8 and VREG_3P3V_RC for the power supply.
    Here is my setup:
    @TomP Okay, yes, sorry, you need to set BATT_MONITOR to 21 for INA2xx and need to set BATT_I2C_BUS to 1 for that power monitor to come up. I'll investigate the PWM issue.
    T 1 Reply Last reply
      T Offline
      T Offline
      TomP
      @Eric-Katzfey The battery monitor works. Thank you very much! I'm sure the PWM will also work and then it's off to the test flight. 🙂
      • T TomP
        @TomP What are the settings of all the SERVO(x)_ params?
        • T TomP
          @TomP If you set the SERVO(x)_FUNCTION parameters according to this: https://ardupilot.org/plane/docs/servo-functions.html#overview do you get any PWM output?
            T Offline
            T Offline
            TomP
            wrote on last edited by TomP
            #25
            @Eric-Katzfey Here are my settings (no PWM output):
            SERVO1_FUNCTION,4
            SERVO1_MAX,1900
            SERVO1_MIN,1100
            SERVO1_REVERSED,0
            SERVO1_TRIM,1500
            SERVO2_FUNCTION,19
            SERVO2_MAX,1900
            SERVO2_MIN,1100
            SERVO2_REVERSED,0
            SERVO2_TRIM,1500
            SERVO3_FUNCTION,70
            SERVO3_MAX,1900
            SERVO3_MIN,1100
            SERVO3_REVERSED,0
            SERVO3_TRIM,1100
            SERVO4_FUNCTION,21
            SERVO4_MAX,1900
            SERVO4_MIN,1100
            SERVO4_REVERSED,0
            SERVO4_TRIM,1500
            SERVO5_FUNCTION,0
            SERVO5_MAX,1900
            SERVO5_MIN,1100
            SERVO5_REVERSED,0
            SERVO5_TRIM,1500
            SERVO6_FUNCTION,0
            SERVO6_MAX,1900
            SERVO6_MIN,1100
            SERVO6_REVERSED,0
            SERVO6_TRIM,1500
            SERVO7_FUNCTION,0
            SERVO7_MAX,1900
            SERVO7_MIN,1100
            SERVO7_REVERSED,0
            SERVO7_TRIM,1500
            SERVO8_FUNCTION,0
            SERVO8_MAX,1900
            SERVO8_MIN,1100
            SERVO8_REVERSED,0
            SERVO8_TRIM,1500
            • T TomP
              SERVO1_FUNCTION,4
              SERVO1_MAX,1900
              SERVO1_MIN,1100
              SERVO1_REVERSED,0
              SERVO1_TRIM,1500
              SERVO2_FUNCTION,19
              SERVO2_MAX,1900
              SERVO2_MIN,1100
              SERVO2_REVERSED,0
              SERVO2_TRIM,1500
              SERVO3_FUNCTION,70
              SERVO3_MAX,1900
              SERVO3_MIN,1100
              SERVO3_REVERSED,0
              SERVO3_TRIM,1100
              SERVO4_FUNCTION,21
              SERVO4_MAX,1900
              SERVO4_MIN,1100
              SERVO4_REVERSED,0
              SERVO4_TRIM,1500
              SERVO5_FUNCTION,0
              SERVO5_MAX,1900
              SERVO5_MIN,1100
              SERVO5_REVERSED,0
              SERVO5_TRIM,1500
              SERVO6_FUNCTION,0
              SERVO6_MAX,1900
              SERVO6_MIN,1100
              SERVO6_REVERSED,0
              SERVO6_TRIM,1500
              SERVO7_FUNCTION,0
              SERVO7_MAX,1900
              SERVO7_MIN,1100
              SERVO7_REVERSED,0
              SERVO7_TRIM,1500
              SERVO8_FUNCTION,0
              SERVO8_MAX,1900
              SERVO8_MIN,1100
              SERVO8_REVERSED,0
              SERVO8_TRIM,1500
              @TomP Hmm, that looks correct. On my test setup running ArduPlane with those values I see output values being sent to the M0065 board. I'm wondering if there is a connectivity issue between the VOXL 2 mini and the IO board.
              • T TomP
                SERVO1_FUNCTION,4
                SERVO1_MAX,1900
                SERVO1_MIN,1100
                SERVO1_REVERSED,0
                SERVO1_TRIM,1500
                SERVO2_FUNCTION,19
                SERVO2_MAX,1900
                SERVO2_MIN,1100
                SERVO2_REVERSED,0
                SERVO2_TRIM,1500
                SERVO3_FUNCTION,70
                SERVO3_MAX,1900
                SERVO3_MIN,1100
                SERVO3_REVERSED,0
                SERVO3_TRIM,1100
                SERVO4_FUNCTION,21
                SERVO4_MAX,1900
                SERVO4_MIN,1100
                SERVO4_REVERSED,0
                SERVO4_TRIM,1500
                SERVO5_FUNCTION,0
                SERVO5_MAX,1900
                SERVO5_MIN,1100
                SERVO5_REVERSED,0
                SERVO5_TRIM,1500
                SERVO6_FUNCTION,0
                SERVO6_MAX,1900
                SERVO6_MIN,1100
                SERVO6_REVERSED,0
                SERVO6_TRIM,1500
                SERVO7_FUNCTION,0
                SERVO7_MAX,1900
                SERVO7_MIN,1100
                SERVO7_REVERSED,0
                SERVO7_TRIM,1500
                SERVO8_FUNCTION,0
                SERVO8_MAX,1900
                SERVO8_MIN,1100
                SERVO8_REVERSED,0
                SERVO8_TRIM,1500
                @TomP Can you tell me how you have connected the UART pins on M0065 to the UART pins on VOXL 2 mini? Like the actual pin numbers that are connected?
                  T Offline
                  T Offline
                  TomP
                  @Eric-Katzfey I can rule out connection problems. I checked the contacts on the VOXL2-Mini and the IO board with a continuity tester. Everything is well connected.
                  I know that with ardupilot you can at least control the servos without arming. Is this perhaps implemented differently here? Then I would have to calibrate the sensors etc. to test this.
                    T Offline
                    T Offline
                    TomP
                    #29
                    @Eric-Katzfey Here is the pin configuration (J19 on VOXL2-Mini to J4 on IO Board):
                    VOXL2-Mini-----IO Board
                    9-----------------1
                    8-----------------3
                    7-----------------2
                    6-----------------4
                    (I mistyped the table at the beginning. I have corrected the typo.)
                    • T TomP
                      9-----------------1
                      8-----------------3
                      7-----------------2
                      6-----------------4
                      @TomP Yep, that all looks fine. Shoot. I may need to send you a new package with extra debug information to help debug this since by default there really isn't much we can see.
                      • T TomP
                        9-----------------1
                        8-----------------3
                        7-----------------2
                        6-----------------4
                        @TomP Can you stop ardupilot and then run this command on VOXL 2 mini? voxl-2-io detect
                          T Offline
                          T Offline
                          TomP
                          @Eric-Katzfey said in ArduPilot on Voxl2:
                          What do you mean by that?
                          "a new package with extra debug information"
                          • T TomP
                            @TomP A new voxl-ardupilot package with debug information added. But we may not need that. Try voxl-2-io detect and then if that is successful then try voxl-2-io scan
                              T Offline
                              T Offline
                              TomP
                              #34
                              voxl2-mini:~$ voxl-2-io detect
                              enabling bridge
                              bridge enabled
                              [INFO] Detected VOXL2 IO on default port (2).
                              ESC detected: ModalAi I/O Expander (M0065)
                              disabling bridge
                              bridge disabled
                              voxl2-mini:~$ voxl-2-io scan
                              enabling bridge
                              bridge enabled
                              Successfully pinged VOXL2 IO on default port (2).
                              INFO: VOXL2 IO Information:
                                  Board      : version 35 : ModalAi I/O Expander (M0065)
                                  UID        : 0x8108322152518882066BFF54
                                  Firmware   : version 1, hash 6b5ec459
                                  Bootloader : version 0, hash 5ba5857f
                              disabling bridge
                              bridge disabled
                              • T TomP
                                enabling bridge
                                bridge enabled
                                disabling bridge
                                bridge disabled
                                enabling bridge
                                bridge enabled
                                disabling bridge
                                bridge disabled
                                @TomP Okay, I think that firmware needs to be upgraded. Can you try voxl-2-io and choose upgrade_firmware?
                                Eric KatzfeyE T 2 Replies Last reply
                                  @Eric-Katzfey Or just voxl-2-io upgrade_firmware?
                                    T Offline
                                    T Offline
                                    TomP
                                    voxl-2-io
                                    It works! Many thanks for the great support! 🙂
                                    The firmware upgrade was the solution.
                                    • T TomP
                                      voxl-2-io
                                      #38
                                      @TomP Wonderful! So glad to hear. And I would really love to hear how the flight testing goes. We've never tried a VOXL 2 (or VOXL 2 mini) on a fixed wing (with ArduPilot) so be careful and triple check to make sure everything looks setup correctly before launching.
                                      T Sam KileyS 2 Replies Last reply
                                        T Offline
                                        T Offline
                                        TomP
                                        It is an honor for me to report. We will be careful. Of course, a crash can also occur independently of the VOXL2. This is a new drone that we are building.
                                        What might be relevant for you is that we have found a gimbal that will fit one of your cameras with a bit of hardware hacking. The gimbal can also be controlled via serial interface using Ardupilot. We have already successfully tested this with the VOXL2-Mini.
                                        • T TomP
                                          @TomP Oh, yes, this is all great news! Very exciting to hear! I will send an email to your account with some follow up questions.
