  3. How to do SLAM and VOXL-Mapper flying with Starling Drone ?
starling
13 Posts 3 Posters 3.2k Views 3 Watching
  • david devassyD Offline
    david devassy
    We have recently purchased Starling Autonomy Drone. We are Facing following Issue:
    1. No Proper Guide on How to fly the drone Using VOXL Mapper(in Modal AI VOXL Web Portal)
    2. How to do Slamming and Obstacle avoidance Flying?
    Please Guide us on How to use your Web portal to Fly it inside a room using Mapper.
      david devassy
      We have installed voxl-Mapper and started the services, changed offboard mode to trajectory also. When we tell it to go to one location its moving also. But no point cloud map is been generated inside Mapper at Voxl Web portal. Please assist.!Screenshot (1).png
      • david devassyD david devassy
        @david-devassy Have you been following the documentation here: https://docs.modalai.com/voxl-mapper/#voxl-mapper?
        david devassyD 1 Reply Last reply
          david devassy
          @Eric-Katzfey . Yes, we have followed the same only. i think my TOF sensor is not activated. we are not getting any data of TOF sensors on the VOXL Webportal. Can you Guide me on How to activate it.
          following attached images are the data regarding drone.Screenshot (2).png Screenshot (3).png Screenshot (4).png Screenshot (5).png
            @david-devassy Did you run through voxl-configure-sku -w and voxl-configure-mpa in order to enable / run all of the relevant services?
            david devassyD 2 Replies Last reply
              david devassy
              @tom ------------------------------------------------------------------
              Welcome to the voxl-configure-sku Wizard!
              VOXL currently thinks it is in the following hardware:
              family code: MRB-D0005 (starling)
              compute board: 4 (voxl2)
              hw version: 3
              cam config: 6
              SKU: MRB-D0005-4-V3-C6
              If this is what you want, select 1 (accept and continue) to
              leave it as-is. Otherwise, select the desired product family:
              1. accept and continue 10) seeker
              2. starling 11) rb5-flight
              3. sentinel 12) flight-deck
              4. fpv 13) voxl-deck
              5. D0010 14) voxl2-flight-deck
              6. px4-autonomy-dev-kit 15) voxl2-test-fixture
              7. stinger 16) voxl2-mini-test-fixture
              8. m500 17) voxl2-board-only
              9. voxlcam 18) voxl2-mini-board-only
                #? 2
                selected starling
              MRB-D0005 Starling currently has two versions in circulation.
              Version 2 with silver motors (pre December 2023)
              Version 3 with black motors (December 2023 onward)
              Please select the appropriate one.
              1. quit
              2. 2
              3. 3
                #? 3
              If you would like to select a special camera config that differs
              from the default for your product family, please select an option.
              Simply hit ENTER to use the default
              01 - ov7251 tracking ov7251 stereo
              02 - ov7251 tracking
              03 - ov7251 tracking ov7251 stereo imx214 hires
              04 - ov7251 tracking imx214 hires
              05 - pmd-tof ov7251 tracking
              06 - D0005 Starling pmd-tof imx214 hires ov7251 tracking
              08 - imx214
              09 - pmd-tof
              10 - ov7251 stereo
              11 - D0006 Sentinel
              12 - ov9782 stereo
              13 - ov9782 stereo imx214 hires
              14 - ov9782 stereo pmd-tof ov7251 tracking (copy)
              15 - D0008 dual 9782 tracking
              16 - pmd-tof ov7251 dual tracking imx214 hires
              17 - D0010 pmd-tof imx412 hires ov7251 tracking ov9782 stereo
              18 - D0008 triple ov9782
              19 - D0005 without tof imx214 hires ov7251 tracking
              20 - D0011 imx412 hires ar0144 tracking
              21 - old C6
              22 - D0013 imx412 flipped ov7251
              23 - D0010 without stereo
              C - use user-defined custom camera config in
              (/data/modalai/custom_camera_config.txt)
              q - Quit The Wizard
              The default camera config for Starling is
              6 (hires+TOF+tracking)
              selection:
              Selecting default camera config
              Your answers would construct the following SKU:
              hw version: 3
              cam config: 6
              This sku will be saved to persistent memory so VOXL
              will remember what it is installed in, even between
              system image flashes.
              Press enter to accept and continue.
              If something is wrong press ctrl-C to quit and try again.
              DONE, MRB-D0005-4-V3-C6 has been written to /data/modalai/sku.txt
              Next you will likely want to run voxl-configure-mpa
              voxl2:/$ voxl-configure-mpa
                         Welcome to voxl-configure-mpa!
              VOXL is currently thinks it is in the following hardware:
              hw version: 3
              cam config: 6
              If this doesn't look right, quit and run voxl-configure-sku to
              set it correctly. Then run voxl-configure-mpa again.
              Continue? y/n: y
              Continuing
              About to Execute:
              voxl-configure-extrinsics starling_v2_voxl2
              voxl-configure-cameras 6
              voxl-configure-cpu-monitor factory_enable
              voxl-configure-qvio factory_enable_imu_apps
              voxl-configure-open-vins disable
              voxl-configure-dfs factory_disable
              voxl-configure-tag-detector factory_disable
              voxl-configure-tflite factory_disable
              voxl-configure-vision-hub factory_enable
              voxl-configure-mavlink-server factory_enable
              voxl-configure-portal enable
              voxl-configure-lepton disable
              voxl-configure-uvc disable
              voxl-configure-streamer factory_enable
              voxl-configure-modem disable
              voxl-configure-mavcam factory_enable
              voxl-configure-rangefinders disable
              voxl-configure-px4-imu-server factory_disable
              voxl-configure-imu factory_enable
              voxl-configure-flow-server disable
              voxl-configure-feature-tracker disable
              systemctl stop voxl-px4
              systemctl disable voxl-px4
              sleep 3
              voxl-esc setup_starling_black_motors
              voxl-elrs --scan
              rm -f /data/px4/param/parameters
              voxl-configure-px4 starling_v2
              systemctl stop voxl-mavlink-server
              sleep 1
              voxl-configure-px4-params --non-interactive --platform MRB-D0005-V2
              enabling voxl-wait-for-fs service
              executing: voxl-configure-extrinsics starling_v2_voxl2
              wiping old extrinsics config file
              copying /usr/share/modalai/extrinsic_configs/starling_v2_voxl2.conf to /etc/modalai/extrinsics.conf
              loading and updating file with voxl-inspect-extrinsics -q
              done configuring extrinsics
              Success!
              executing: voxl-configure-cameras 6
              Camera Configuration: 6
              camera server config helper list:
              tof:pmd-tof:0:
              hires:imx214:1:
              tracking:ov7251:2:
              driver binary list:
              /usr/share/modalai/chi-cdk/irs1645/com.qti.sensormodule.irs1645_0.bin
              /usr/share/modalai/chi-cdk/imx214/com.qti.sensormodule.imx214_2.bin
              /usr/share/modalai/chi-cdk/ov7251/com.qti.sensormodule.ov7251_3.bin
              calling camera-server-config-helper tof:pmd-tof:0: hires:imx214:1: tracking:ov7251:2:
              detected system image 1.7.4
              using new imx214 defaults
              successfully wrote this camera config to disk:
              configuration for 3 cameras:
              cam #0
              sensor type: pmd-tof
              isEnabled: 1
              camId: 0
              camId2: -1
              fps: 5
              en_rotate: 0
              en_rotate2: 0
              en_preview:          1
              pre_width:           224
              pre_height:          1557
              en_raw_preview:      1
              en_small_video:      0
              small_video_width:   -1
              small_video_height:  -1
              en_large_video:      0
              large_video_width:   -1
              large_video_height:  -1
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             off
              standby_enabled:     0
              decimator:           5
              independent_exposure:0
              cam #1
              sensor type: imx214
              isEnabled: 1
              camId: 1
              camId2: -1
              fps: 30
              en_rotate: 0
              en_rotate2: 0
              en_preview:          0
              pre_width:           640
              pre_height:          480
              en_raw_preview:      0
              en_small_video:      1
              small_video_width:   1024
              small_video_height:  768
              en_large_video:      1
              large_video_width:   4208
              large_video_height:  3120
              en_snapshot:         1
              snap_width:          4208
              snap_height:         3120
              ae_mode:             isp
              standby_enabled:     0
              decimator:           1
              cam #2
              sensor type: ov7251
              isEnabled: 1
              camId: 2
              camId2: -1
              fps: 30
              en_rotate: 0
              en_rotate2: 0
              en_preview:          1
              pre_width:           640
              pre_height:          480
              en_raw_preview:      1
              en_small_video:      0
              en_large_video:      0
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             lme_msv
              standby_enabled:     0
              decimator:           1
              camera_server_config_helper is done
              copying required camera drivers in place
              enabling voxl-camera-server
              Done Configuring Cameras
              Please power cycle VOXL to load new drivers
              camera server will start on next reboot
              Success!
              executing: voxl-configure-cpu-monitor factory_enable
              wiping old config file
              Creating new config file: /etc/modalai/voxl-cpu-monitor.conf
              enabling voxl-cpu-monitor systemd service
              Done configuring voxl-cpu-monitor
              Success!
              executing: voxl-configure-qvio factory_enable_imu_apps
              loading config file
              Creating new config file: /etc/modalai/voxl-qvio-server.conf
              enabling voxl-qvio-server systemd service
              Done configuring voxl-qvio-server
              Success!
              executing: voxl-configure-open-vins disable
              disabling voxl-open-vins-server systemd service
              stopping voxl-open-vins-server systemd service
              Done configuring voxl-open-vins-server
              Success!
              executing: voxl-configure-dfs factory_disable
              Creating new config file: /etc/modalai/voxl-dfs-server.conf
              disabling voxl-dfs-server systemd service
              Removed /etc/systemd/system/multi-user.target.wants/voxl-dfs-server.service.
              stopping voxl-dfs-server systemd service
              Done configuring voxl-dfs-server
              Success!
              executing: voxl-configure-tag-detector factory_disable
              Creating new config file: /etc/modalai/voxl-tag-detector.conf
              disabling voxl-tag-detector systemd service
              stopping voxl-tag-detector systemd service
              Done configuring voxl-tag-detector
              Success!
              executing: voxl-configure-tflite factory_disable
              Creating new config file: /etc/modalai/voxl-tflite-server.conf
              The config file was modified during parsing, saving the changes to disk
              disabling voxl-tflite-server systemd service
              Removed /etc/systemd/system/multi-user.target.wants/voxl-tflite-server.service.
              stopping voxl-tflite-server systemd service
              Done configuring voxl-tflite-server
              Success!
              executing: voxl-configure-vision-hub factory_enable
              Created new json file: /etc/modalai/voxl-vision-hub.conf
              The JSON config file data was modified during parsing, saving the changes to disk
              enabling voxl-vision-hub systemd service
              Done configuring voxl-vision-hub
              service will start on next reboot
              Success!
              executing: voxl-configure-mavlink-server factory_enable
              Created new json file: /etc/modalai/voxl-mavlink-server.conf
              enabling voxl-mavlink-server systemd service
              Done configuring voxl-mavlink-server
              Success!
              executing: voxl-configure-portal enable
              enabling voxl-portal systemd service
              Done configuring voxl-portal
              Success!
              executing: voxl-configure-lepton disable
              disabling voxl-lepton-server systemd service
              stopping voxl-lepton-server systemd service
              Done configuring voxl-lepton-server
              Success!
              executing: voxl-configure-uvc disable
              disabling voxl-uvc-server systemd service
              stopping voxl-uvc-server systemd service
              Done configuring voxl-uvc-server
              Success!
              executing: voxl-configure-streamer factory_enable
              Creating new config file: /etc/modalai/voxl-streamer.conf
              writing /etc/modalai/voxl-streamer.conf to disk
              parsed config file
              enabling voxl-streamer systemd service
              Done configuring voxl-streamer, it will start on next reboot
              Success!
              executing: voxl-configure-modem disable
              disabling voxl-modem systemd service
              stopping voxl-modem systemd service
              Done configuring voxl-modem
              Success!
              executing: voxl-configure-mavcam factory_enable
              Creating new config file: /etc/modalai/voxl-mavcam-manager.conf
              writing /etc/modalai/voxl-mavcam-manager.conf to disk
              enabling voxl-mavcam-manager systemd service
              Done configuring voxl-mavcam-manager
              It will start automatically on the next reboot
              Success!
              executing: voxl-configure-rangefinders disable
              disabling voxl-rangefinder-server systemd service
              Removed /etc/systemd/system/multi-user.target.wants/voxl-rangefinder-server.service.
              stopping voxl-rangefinder-server systemd service
              Done configuring voxl-rangefinder-server
              Success!
              executing: voxl-configure-px4-imu-server factory_disable
              disabling voxl-px4-imu-server systemd service
              stopping voxl-px4-imu-server systemd service
              Done configuring voxl-px4-imu-server
              Success!
              executing: voxl-configure-imu factory_enable
              Creating new config file: /etc/modalai/voxl-imu-server.conf
              enabling voxl-imu-server systemd service
              Done configuring voxl-imu-server
              Success!
              executing: voxl-configure-flow-server disable
              disabling voxl-flow-server systemd service
              stopping voxl-flow-server systemd service
              Done configuring voxl-flow-server
              Success!
              executing: voxl-configure-feature-tracker disable
              disabling voxl-feature-tracker systemd service
              stopping voxl-feature-tracker systemd service
              Done configuring voxl-feature-tracker
              Success!
              executing: systemctl stop voxl-px4
              Success!
              executing: systemctl disable voxl-px4
              Removed /etc/systemd/system/multi-user.target.wants/voxl-px4.service.
              Success!
              executing: sleep 3
              Success!
              executing: voxl-esc setup_starling_black_motors
              enabling bridge
              bridge enabled
              [INFO] Setting CPU to performance mode
              [INFO] Scanning for ESC...
              dpkg-query: no packages found matching voxl-esc-board-detect.py
              dpkg-query: no packages found matching voxl-esc-calibrate.py
              dpkg-query: no packages found matching voxl-esc-led.py
              dpkg-query: no packages found matching voxl-esc-neopixel-test.py
              dpkg-query: no packages found matching voxl-esc-scan.py
              dpkg-query: no packages found matching voxl-esc-spin-helper.sh
              dpkg-query: no packages found matching voxl-esc-spin-sine.py
              dpkg-query: no packages found matching voxl-esc-spin-step.py
              dpkg-query: no packages found matching voxl-esc-spin.py
              dpkg-query: no packages found matching voxl-esc-tools-bin
              dpkg-query: no packages found matching voxl-esc-upload-firmware-all.sh
              dpkg-query: no packages found matching voxl-esc-upload-firmware.py
              dpkg-query: no packages found matching voxl-esc-upload-params.py
              dpkg-query: no packages found matching voxl-esc-verify-params.py
              dpkg-query: no packages found matching voxl_esc_setup_paths.py
              dpkg-query: no packages found matching voxl_serial.py
              [INFO] M0134-1 detected
              [INFO] has for most recent firmware: eb6fb500
              [INFO] Expected ESC firmware info:
              Firmware: modalai_esc_firmware_m0134_1_v0_39_RC10_eb6fb500.bin
              Firmware hash: eb6fb500
              [INFO] Number of ESCs with correct FW: 4
              [INFO] All of the ESCs have the correct firmware loaded
              uploading params file ../voxl-esc-params/starling_1504_3000kv/starling_1504_3000kv.xml
              [GCC 8.4.0]
              Found voxl-esc tools bin version: 1.6
              VOXL Platform: M0054
              INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000, protocol: firmware
              INFO: ESC Information:
              INFO: ---------------------
              Board : version 37: ModalAi 4-in-1 ESC (M0134-1)
              UID : 0x2033303852465719003E0056
              Firmware : version 39, hash eb6fb500
              Bootloader : version 183, hash b4fa2cf8
              UID        : 0x20333038524657190026004F
              UID        : 0x203330385246571900260049
              UID        : 0x2033303852465718001C002B
              successfully pinged ESCs
              [GCC 8.4.0]
              INFO: Params file name : ../voxl-esc-params/starling_1504_3000kv/starling_1504_3000kv.xml
              INFO: Params file size : 7602 bytes
              STILL SAME. WE THINK OUR TOF UNIT IS NOT WORKING. ITS DEAD ON ARRIVAL.
                david devassy
                @tom
                INFO: ESCs detected:
                ID: 0, SW: 39, HW: 37: ModalAi 4-in-1 ESC (M0134-1)
                ID: 1, SW: 39, HW: 37: ModalAi 4-in-1 ESC (M0134-1)
                ID: 2, SW: 39, HW: 37: ModalAi 4-in-1 ESC (M0134-1)
                ID: 3, SW: 39, HW: 37: ModalAi 4-in-1 ESC (M0134-1)
                INFO: Loading XML config file...
                INFO: Uploading params for ESC ID 255...
                -- board config
                -- id config
                -- uart config
                -- tune config
                DONE
                INFO: Resetting ESCs...
                DONE
                WARNING: Received 12 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
                disabling bridge
                bridge disabled
                Success!
                executing: voxl-elrs --scan
                [ERROR] Error reading device information.
                [ERROR] Ensure that transmitter is turned off and receiver is not in bootloader mode.
                first try failed, executing a second time: voxl-elrs --scan
                FAILED TO EXECUTE: voxl-elrs --scan
                Success!
                executing: rm -f /data/px4/param/parameters
                Success!
                executing: voxl-configure-px4 starling_v2
                enabling voxl-px4 systemd service
                Created symlink /etc/systemd/system/multi-user.target.wants/voxl-px4.service → /etc/systemd/system/voxl-px4.service.
                Success!
                executing: systemctl stop voxl-mavlink-server
                Success!
                executing: sleep 1
                Success!
                executing: voxl-configure-px4-params --non-interactive --platform MRB-D0005-V2
                [INFO] Voxl-px4 not currently running.
                [INFO] Starting voxl-px4 service...
                [INFO] Voxl-px4 started successfully!
                [INFO] Loading the following param files: platforms/Starling_V2.params, EKF2_helpers/indoor_vio.params, radio_helpers/Commando_8.params.
                [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/platforms/Starling_V2.params
                [INFO] Scanning currently loaded parameters...
                The following parameters about to be loaded differ from those currently loaded:
                NAME CURRENT NEW
                [1] CBRK_IO_SAFETY N/A 22027
                [2] COM_CPU_MAX 0.0 -1.0
                [3] COM_OF_LOSS_T N/A 3.0
                [4] NAV_ACC_RAD N/A 2.0
                [5] GPS_UBX_DYNMODEL N/A 6
                [6] RTL_RETURN_ALT N/A 30
                [7] RTL_DESCEND_ALT N/A 10
                [8] SENS_BOARD_ROT N/A 0
                [9] BAT1_N_CELLS N/A 2
                [10] BAT1_R_INTERNAL N/A 0.025
                [11] BAT1_CAPACITY N/A 2900
                [12] BAT1_V_CHARGED N/A 4.1
                [13] BAT1_V_EMPTY N/A 3.2
                [14] BAT_LOW_THR N/A 0.15
                [15] BAT_CRIT_THR N/A 0.10
                [16] BAT_EMERGEN_THR N/A 0.05
                [17] MPC_THR_HOVER 0.42 0.34
                [18] THR_MDL_FAC N/A 0.9
                [19] VOXL_ESC_RPM_MAX 10500.0 15000.0
                [20] VOXL_ESC_RPM_MIN 1000.0 3000.0
                [21] VOXL_ESC_FUNC2 103.0 104.0
                [22] VOXL_ESC_FUNC3 104.0 102.0
                [23] VOXL_ESC_FUNC4 102.0 103.0
                [24] VOXL_ESC_T_COSP N/A 0.990000009536743164
                [25] VOXL_ESC_T_DEAD N/A 20
                [26] VOXL_ESC_T_EXPO N/A 35
                [27] VOXL_ESC_T_MINF N/A 0.150000005960464478
                [28] VOXL_ESC_T_PERC N/A 90
                [29] VOXL_ESC_VLOG N/A 1
                [30] MC_BAT_SCALE_EN N/A 0
                [31] EKF2_IMU_POS_X 0.027 0.0157
                [32] EKF2_IMU_POS_Y 0.009 0.0078
                [33] EKF2_IMU_POS_Z -0.019 -0.018
                [34] EKF2_EV_POS_X N/A 0.0
                [35] EKF2_EV_POS_Y N/A 0.0
                [36] EKF2_EV_POS_Z N/A 0.0
                [37] CA_ROTOR0_PX 0.15 0.085
                [38] CA_ROTOR0_PY 0.15 0.0625
                [39] CA_ROTOR1_PX -0.15 -0.085
                [40] CA_ROTOR1_PY -0.15 -0.0625
                [41] CA_ROTOR2_PX 0.15 0.085
                [42] CA_ROTOR2_PY -0.15 -0.0625
                [43] CA_ROTOR3_PX -0.15 -0.085
                [44] CA_ROTOR3_PY 0.15 0.0625
                [45] CA_ROTOR0_AX N/A 0.0
                [46] CA_ROTOR0_AY N/A 0.0
                [47] CA_ROTOR1_AX N/A 0.0
                [48] CA_ROTOR1_AY N/A 0.0
                [49] CA_ROTOR2_AX N/A 0.0
                [50] CA_ROTOR2_AY N/A 0.0
                [51] CA_ROTOR3_AX N/A 0.0
                [52] CA_ROTOR3_AY N/A 0.0
                [53] CA_ROTOR0_KM N/A 0.05
                [54] CA_ROTOR1_KM N/A 0.05
                [55] MOT_SLEW_MAX N/A 0.0
                [56] IMU_DGYRO_CUTOFF N/A 60.0
                [57] IMU_ACCEL_CUTOFF N/A 80.0
                [58] IMU_GYRO_CUTOFF N/A 80.0
                [59] IMU_GYRO_DNF_EN N/A 1
                [60] IMU_GYRO_DNF_HMC N/A 3
                [61] IMU_GYRO_DNF_BW N/A 15
                [62] MC_PITCH_P 5.5 16.0
                [63] MC_PITCHRATE_P 0.08 0.12
                [64] MC_PITCHRATE_I 0.2 0.05
                [65] MC_PITCHRATE_D 0.0013 0.0015
                [66] MC_PITCH_CUTOFF N/A 150.0
                [67] MC_ROLL_P 5.5 16.0
                [68] MC_ROLLRATE_P 0.08 0.09
                [69] MC_ROLLRATE_I 0.2 0.05
                [70] MC_ROLLRATE_D 0.0013 0.0015
                [71] MC_ROLL_CUTOFF N/A 150.0
                [72] MC_YAW_P 2.0 2.8
                [73] MC_YAWRATE_I 0.1 0.5
                [74] MC_YAW_CUTOFF N/A 150.0
                [75] MC_ROLLRATE_MAX N/A 130.0
                [76] MC_PITCHRATE_MAX N/A 130.0
                [77] MC_YAWRATE_MAX N/A 150.0
                [78] MPC_POS_MODE 0.0 4.0
                [79] MPC_YAW_EXPO 0.2 0.3
                [80] MPC_XY_MAN_EXPO 0.2 0.45
                [81] MPC_Z_MAN_EXPO 0.2 0.1
                [82] MPC_ACC_HOR N/A 3.0
                [83] MPC_JERK_MAX N/A 40.0
                [84] MPC_TILTMAX_AIR N/A 30.0
                [85] MPC_ACC_HOR_MAX N/A 1000.0
                [86] MPC_ACC_UP_MAX N/A 3.0
                [87] MPC_ACC_DOWN_MAX N/A 3.0
                [88] MPC_VEL_MANUAL 5.0 3.0
                [89] MPC_XY_VEL_MAX 5.0 3.0
                [90] MPC_XY_CRUISE 5.0 3.0
                [91] MPC_Z_VEL_MAX_DN 1.5 1.0
                [92] MPC_Z_VEL_MAX_UP 4.0 1.0
                [93] MPC_HOLD_MAX_XY N/A 0.0
                [94] MPC_HOLD_MAX_Z N/A 0.0
                [95] MPC_THR_MAX 0.75 0.7
                [96] MPC_MANTHR_MIN 0.05 0.08
                [97] MPC_XY_P 0.95 3.5
                [98] MPC_Z_P 1.0 5.0
                [99] MPC_TKO_RAMP_T 1.5 1.0
                [100] COM_SPOOLUP_TIME N/A 2.0
                [101] LNDMC_ROT_MAX N/A 30.0
                [102] LNDMC_TRIG_TIME N/A 0.5
                [103] COM_DISARM_LAND N/A 0.1
                [104] COM_DISARM_PRFLT -1.0 20.0
                [INFO] Setting params...
                [ERROR] Failed to set PX4 parameters. Check voxl-px4 status for details.
                first try failed, executing a second time: voxl-configure-px4-params --non-interactive --platform MRB-D0005-V2
                [INFO] Voxl-px4 service found and active.
                NAME CURRENT NEW
                [2] CBRK_SUPPLY_CHK N/A 894281
                [3] COM_CPU_MAX N/A -1
                [4] COM_OF_LOSS_T N/A 3.0
                [5] NAV_ACC_RAD N/A 2.0
                [6] GPS_UBX_DYNMODEL N/A 6
                [7] RTL_RETURN_ALT N/A 30
                [8] RTL_DESCEND_ALT N/A 10
                [9] IMU_GYRO_RATEMAX N/A 800
                [10] SYS_AUTOSTART N/A 4001
                [11] MAV_TYPE N/A 2
                [12] SENS_BOARD_ROT N/A 0
                [13] BAT1_N_CELLS N/A 2
                [14] BAT1_R_INTERNAL N/A 0.025
                [15] BAT1_CAPACITY N/A 2900
                [16] BAT1_V_CHARGED N/A 4.1
                [17] BAT1_V_EMPTY N/A 3.2
                [18] BAT_LOW_THR N/A 0.15
                [19] BAT_CRIT_THR N/A 0.10
                [20] BAT_EMERGEN_THR N/A 0.05
                [21] MPC_THR_HOVER N/A 0.34
                [22] THR_MDL_FAC N/A 0.9
                [23] VOXL_ESC_FUNC1 N/A 101
                [24] VOXL_ESC_FUNC2 103.0 104.0
                [25] VOXL_ESC_FUNC3 104.0 102.0
                [26] VOXL_ESC_FUNC4 102.0 103.0
                [27] VOXL_ESC_SDIR1 N/A 0
                [28] VOXL_ESC_SDIR2 N/A 0
                [29] VOXL_ESC_SDIR3 N/A 0
                [30] VOXL_ESC_SDIR4 N/A 0
                [31] VOXL_ESC_BAUD N/A 2000000
                [32] VOXL_ESC_CONFIG N/A 1
                [33] VOXL_ESC_MODE N/A 0
                [34] VOXL_ESC_REV N/A 0
                [35] CA_AIRFRAME N/A 0
                [36] CA_ROTOR_COUNT N/A 4
                [37] CA_ROTOR2_KM N/A -0.05
                [38] CA_ROTOR3_KM N/A -0.05
                [39] MC_AIRMODE N/A 0
                [40] MC_PITCHRATE_K N/A 1.0
                [41] MC_ROLLRATE_K N/A 1.0
                [42] MC_YAWRATE_P N/A 0.15
                [43] MC_YAWRATE_D N/A 0.0
                [44] MC_YAWRATE_K N/A 1.0
                [45] MPC_LAND_SPEED N/A 1.0
                [46] MPC_THR_MIN N/A 0.08
                [47] MPC_XY_VEL_P_ACC N/A 3.00
                [48] MPC_XY_VEL_I_ACC N/A 0.10
                [49] MPC_XY_VEL_D_ACC N/A 0.00
                [50] MPC_Z_VEL_P_ACC N/A 8.0
                [51] MPC_Z_VEL_I_ACC N/A 2.0
                [52] MPC_Z_VEL_D_ACC N/A 0.0
                [53] MPC_TKO_SPEED N/A 1.50
                [INFO] PX4 parameter configuration successful!
                [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/EKF2_helpers/indoor_vio.params
                NAME CURRENT NEW
                [1] SYS_HAS_MAG N/A 1
                [2] SYS_HAS_GPS N/A 1
                [3] COM_ARM_WO_GPS N/A 1
                [4] EKF2_GPS_CTRL N/A 0
                [5] EKF2_MAG_TYPE N/A 5
                [6] EKF2_BARO_CTRL N/A 1
                [7] EKF2_EV_CTRL N/A 15
                [8] EKF2_OF_CTRL N/A 0
                [9] EKF2_RNG_CTRL N/A 0
                [10] EKF2_HGT_REF N/A 3
                [11] EKF2_EV_QMIN N/A 1
                [12] EKF2_EV_NOISE_MD N/A 0
                [13] EKF2_EVA_NOISE N/A 0.1
                [14] EKF2_EVP_GATE N/A 5.0
                [15] EKF2_EVP_NOISE N/A 0.1
                [16] EKF2_EVV_GATE N/A 3.0
                [17] EKF2_EVV_NOISE N/A 0.1
                [18] EKF2_EV_DELAY N/A 0.00
                [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/radio_helpers/Commando_8.params
                NAME CURRENT NEW
                [1] RC_CHAN_CNT N/A 16
                [2] RC_MAP_KILL_SW N/A 5
                [3] RC_MAP_FLTMODE N/A 6
                [4] COM_FLTMODE1 N/A 0
                [5] COM_FLTMODE2 N/A -1
                [6] COM_FLTMODE3 N/A -1
                [7] COM_FLTMODE4 N/A 2
                [8] COM_FLTMODE5 N/A -1
                [9] COM_FLTMODE6 N/A 7
                [10] RC1_DZ N/A 10.000000000000000000
                [11] RC1_MAX N/A 2000.000000000000000000
                [12] RC1_MIN N/A 1000.000000000000000000
                [13] RC1_REV N/A 1.000000000000000000
                [14] RC1_TRIM N/A 1500.000000000000000000
                [15] RC2_DZ N/A 10.000000000000000000
                [16] RC2_MAX N/A 2000.000000000000000000
                [17] RC2_MIN N/A 1000.000000000000000000
                [18] RC2_REV N/A 1.000000000000000000
                [19] RC2_TRIM N/A 1500.000000000000000000
                [20] RC3_DZ N/A 10.000000000000000000
                [21] RC3_MAX N/A 2000.000000000000000000
                [22] RC3_MIN N/A 1000.000000000000000000
                [23] RC3_REV N/A 1.000000000000000000
                [24] RC3_TRIM N/A 1500.000000000000000000
                [25] RC4_DZ N/A 10.000000000000000000
                [26] RC4_MAX N/A 2000.000000000000000000
                [27] RC4_MIN N/A 1000.000000000000000000
                [28] RC4_REV N/A 1.000000000000000000
                [29] RC4_TRIM N/A 1500.000000000000000000
                [30] RC5_DZ N/A 10.000000000000000000
                [31] RC5_MAX N/A 1988.000000000000000000
                [32] RC5_MIN N/A 1011.000000000000000000
                [33] RC5_REV N/A 1.000000000000000000
                [34] RC5_TRIM N/A 1500.000000000000000000
                [35] RC6_DZ N/A 10.000000000000000000
                [36] RC6_MAX N/A 1988.000000000000000000
                [37] RC6_MIN N/A 1011.000000000000000000
                [38] RC6_REV N/A 1.000000000000000000
                [39] RC6_TRIM N/A 1500.000000000000000000
                [40] RC7_DZ N/A 10.000000000000000000
                [41] RC7_MAX N/A 1988.000000000000000000
                [42] RC7_MIN N/A 1011.000000000000000000
                [43] RC7_REV N/A 1.000000000000000000
                [44] RC7_TRIM N/A 1500.000000000000000000
                [45] RC8_DZ N/A 10.000000000000000000
                [46] RC8_MAX N/A 1988.000000000000000000
                [47] RC8_MIN N/A 1011.000000000000000000
                [48] RC8_REV N/A 1.000000000000000000
                [49] RC8_TRIM N/A 1500.000000000000000000
                [50] RC9_DZ N/A 0.000000000000000000
                [51] RC9_MAX N/A 2000.000000000000000000
                [52] RC9_MIN N/A 1000.000000000000000000
                [53] RC9_REV N/A 1.000000000000000000
                [54] RC9_TRIM N/A 1500.000000000000000000
                [55] RC10_DZ N/A 0.000000000000000000
                [56] RC10_MAX N/A 2000.000000000000000000
                [57] RC10_MIN N/A 1000.000000000000000000
                [58] RC10_REV N/A 1.000000000000000000
                [59] RC10_TRIM N/A 1500.000000000000000000
                [60] RC11_DZ N/A 0.000000000000000000
                [61] RC11_MAX N/A 2000.000000000000000000
                [62] RC11_MIN N/A 1000.000000000000000000
                [63] RC11_REV N/A 1.000000000000000000
                [64] RC11_TRIM N/A 1500.000000000000000000
                [65] RC12_DZ N/A 0.000000000000000000
                [66] RC12_MAX N/A 1988.000000000000000000
                [67] RC12_MIN N/A 1011.000000000000000000
                [68] RC12_REV N/A 1.000000000000000000
                [69] RC12_TRIM N/A 1499.000000000000000000
                [70] RC13_DZ N/A 0.000000000000000000
                [71] RC13_MAX N/A 2000.000000000000000000
                [72] RC13_MIN N/A 1000.000000000000000000
                [73] RC13_REV N/A 1.000000000000000000
                [74] RC13_TRIM N/A 1500.000000000000000000
                [75] RC14_DZ N/A 0.000000000000000000
                [76] RC14_MAX N/A 2000.000000000000000000
                [77] RC14_MIN N/A 1000.000000000000000000
                [78] RC14_REV N/A 1.000000000000000000
                [79] RC14_TRIM N/A 1500.000000000000000000
                [80] RC15_DZ N/A 0.000000000000000000
                [81] RC15_MAX N/A 2000.000000000000000000
                [82] RC15_MIN N/A 1000.000000000000000000
                [83] RC15_REV N/A 1.000000000000000000
                [84] RC15_TRIM N/A 1500.000000000000000000
                [85] RC16_DZ N/A 0.000000000000000000
                [86] RC16_MAX N/A 2000.000000000000000000
                [87] RC16_MIN N/A 1000.000000000000000000
                [88] RC16_REV N/A 1.000000000000000000
                [89] RC16_TRIM N/A 1500.000000000000000000
                [90] RC17_DZ N/A 0.000000000000000000
                [91] RC17_MAX N/A 2000.000000000000000000
                [92] RC17_MIN N/A 1000.000000000000000000
                [93] RC17_REV N/A 1.000000000000000000
                [94] RC17_TRIM N/A 1500.000000000000000000
                [95] RC18_DZ N/A 0.000000000000000000
                [96] RC18_MAX N/A 2000.000000000000000000
                [97] RC18_MIN N/A 1000.000000000000000000
                [98] RC18_REV N/A 1.000000000000000000
                [99] RC18_TRIM N/A 1500.000000000000000000
                [100] RC_MAP_ACRO_SW N/A 0
                [101] RC_MAP_ARM_SW N/A 0
                [102] RC_MAP_AUX1 N/A 0
                [103] RC_MAP_AUX2 N/A 0
                [104] RC_MAP_AUX3 N/A 0
                [105] RC_MAP_AUX4 N/A 0
                [106] RC_MAP_AUX5 N/A 0
                [107] RC_MAP_AUX6 N/A 0
                [108] RC_MAP_FAILSAFE N/A 0
                [109] RC_MAP_FLAPS N/A 0
                [110] RC_MAP_GEAR_SW N/A 0
                [111] RC_MAP_LOITER_SW N/A 0
                [112] RC_MAP_MAN_SW N/A 0
                [113] RC_MAP_MODE_SW N/A 0
                [114] RC_MAP_OFFB_SW N/A 0
                [115] RC_MAP_PARAM1 N/A 0
                [116] RC_MAP_PARAM2 N/A 0
                [117] RC_MAP_PARAM3 N/A 0
                [118] RC_MAP_PITCH N/A 2
                [119] RC_MAP_POSCTL_SW N/A 0
                [120] RC_MAP_RATT_SW N/A 0
                [121] RC_MAP_RETURN_SW N/A 0
                [122] RC_MAP_ROLL N/A 1
                [123] RC_MAP_STAB_SW N/A 0
                [124] RC_MAP_THROTTLE N/A 3
                [125] RC_MAP_TRANS_SW N/A 0
                [126] RC_MAP_YAW N/A 4
                [INFO] Loading file: /data/px4/param/parameters_gyro.cal
                NAME CURRENT NEW
                [1] CAL_GYRO0_ID N/A 2490378
                [2] CAL_GYRO0_PRIO N/A 50
                [3] CAL_GYRO0_XOFF N/A 0.0134728
                [4] CAL_GYRO0_YOFF N/A -0.00290391
                [5] CAL_GYRO0_ZOFF N/A -0.000202846
                [6] CAL_GYRO0_ROT N/A -1
                [INFO] Trimming duplicate parameters...
                [INFO] Loading file: /data/px4/param/parameters_acc.cal
                NAME CURRENT NEW
                [1] CAL_ACC0_ID N/A 2490378
                [2] CAL_ACC0_PRIO N/A 50
                [3] CAL_ACC0_XOFF N/A 0.016479
                [4] CAL_ACC0_YOFF N/A 0.0495152
                [5] CAL_ACC0_ZOFF N/A -0.00822353
                [6] CAL_ACC0_XSCALE N/A 1
                [7] CAL_ACC0_YSCALE N/A 1
                [8] CAL_ACC0_ZSCALE N/A 1
                [9] CAL_ACC0_ROT N/A -1
                [INFO] Loading file: /data/px4/param/parameters_level.cal
                NAME CURRENT NEW
                [1] SENS_BOARD_X_OFF N/A 0.0105941
                [2] SENS_BOARD_Y_OFF N/A 0.00175017
                [INFO] Loading file: /data/px4/param/parameters_mag.cal
                NAME CURRENT NEW
                [1] CAL_MAG0_ID N/A 527625
                [2] CAL_MAG0_PRIO N/A 75
                [3] CAL_MAG0_XOFF N/A -0.284582
                [4] CAL_MAG0_YOFF N/A -0.281098
                [5] CAL_MAG0_ZOFF N/A 0.219934
                [6] CAL_MAG0_XSCALE N/A 1.00463
                [7] CAL_MAG0_YSCALE N/A 1.01471
                [8] CAL_MAG0_ZSCALE N/A 0.979607
                [9] CAL_MAG0_XODIAG N/A -0.0119525
                [10] CAL_MAG0_YODIAG N/A 0.0184261
                [11] CAL_MAG0_ZODIAG N/A -0.00372516
                [12] CAL_MAG0_XCOMP N/A 0
                [13] CAL_MAG0_YCOMP N/A 0
                [14] CAL_MAG0_ZCOMP N/A 0
                [15] CAL_MAG0_ROT N/A 0
                [INFO] Loading file: /data/px4/param/parameters_rc.cal
                [INFO] No difference in parameters was detected.
                [INFO] Done configuring for platform MRB-D0005-V2
                Success running a second time
                     The following steps worked on the second try:
                     FAILED TO EXECUTE the following steps:
                voxl-elrs --scan
                  Encountered Problems Configuring MPA Services :-/
                    Some Services may not start up on next reboot
                Calibration File Status:
                Present /data/modalai/voxl-imu-server.cal
                Present /data/modalai/opencv_tracking_intrinsics.yml
                Present /data/px4/param/parameters_gyro.cal
                Present /data/px4/param/parameters_acc.cal
                Present /data/px4/param/parameters_level.cal
                Present /data/px4/param/parameters_mag.cal
                            PLEASE POWER CYCLE YOUR VOXL
                  @tom
                  -- board config
                  -- id config
                  -- uart config
                  -- tune config
                  DONE
                  DONE
                  disabling bridge
                  bridge disabled
                  Success!
                  Success!
                  Success!
                  Success!
                  Success!
                  executing: sleep 1
                  Success!
                  NAME CURRENT NEW
                  NAME CURRENT NEW
                  [11] MAV_TYPE N/A 2
                  NAME CURRENT NEW
                  NAME CURRENT NEW
                  NAME CURRENT NEW
                  NAME CURRENT NEW
                  NAME CURRENT NEW
                  NAME CURRENT NEW
                  voxl-elrs --scan
                  @david-devassy What do you see with voxl-list-pipes and systemctl status voxl-camera-server
                    david devassy
                    @tom voxl2:/$ voxl-list-pipes
                    cpu_monitor
                    gcs_ip_list
                    hires_large_color
                    hires_large_encoded
                    hires_large_grey
                    hires_small_color
                    hires_small_encoded
                    hires_small_grey
                    hires_snapshot
                    horizon_cal_io
                    imu_apps
                    imu_apps_fft
                    mavlink_ap_heartbeat
                    mavlink_attitude
                    mavlink_from_gcs
                    mavlink_gps_raw_int
                    mavlink_local_position_ned
                    mavlink_onboard
                    mavlink_sys_status
                    mavlink_to_gcs
                    modal_io_bridge
                    plan_msgs
                    qvio
                    qvio_extended
                    qvio_overlay
                    tracking
                    voa_pc_out
                    voxl_mapper_aligned_ptcloud
                    voxl_mapper_costmap
                    voxl_mesh
                    voxl_mesh_endpoint
                    voxl_planner_render
                    vvhub_body_wrt_fixed
                    vvhub_body_wrt_local
                    vvhub_fixed_pose_input
                    voxl2:/$ systemctl status voxl-camera-server
                    ● voxl-camera-server.service - voxl-camera-server
                    Loaded: loaded (/usr/bin/voxl-camera-server; enabled; vendor preset: enabled)
                    Active: active (running) since Fri 2024-04-12 09:02:25 UTC; 3min 59s ago
                    Main PID: 1404 (voxl-camera-ser)
                    Tasks: 68 (limit: 4915)
                    CGroup: /system.slice/voxl-camera-server.service
                    └─1404 /usr/bin/voxl-camera-server
                    Apr 12 09:02:25 m0054 voxl-camera-server[1404]: gbm_create_device(156): Info: backend name is: msm_drm
                    Apr 12 09:02:25 m0054 voxl-camera-server[1404]: Starting Camera: tracking (originally id #2) with id offset: 1
                    Apr 12 09:02:25 m0054 voxl-camera-server[1404]: Using gain limits min: 54 max: 3451
                    Apr 12 09:02:25 m0054 voxl-camera-server[1404]: setting ov7251 BLC register for cam id 1
                    Apr 12 09:02:25 m0054 voxl-camera-server[1404]: ------ voxl-camera-server: Started 2 of 3 cameras
                    Apr 12 09:02:25 m0054 voxl-camera-server[1404]: ------ voxl-camera-server: Camera server is now running
                    voxl2:/$
                      cpu_monitor
                      gcs_ip_list
                      hires_large_color
                      hires_large_encoded
                      hires_large_grey
                      hires_small_color
                      hires_small_encoded
                      hires_small_grey
                      hires_snapshot
                      horizon_cal_io
                      imu_apps
                      imu_apps_fft
                      mavlink_attitude
                      mavlink_from_gcs
                      mavlink_gps_raw_int
                      mavlink_onboard
                      mavlink_sys_status
                      mavlink_to_gcs
                      modal_io_bridge
                      plan_msgs
                      qvio
                      qvio_extended
                      qvio_overlay
                      tracking
                      voa_pc_out
                      voxl_mapper_costmap
                      voxl_mesh
                      voxl_mesh_endpoint
                      voxl_planner_render
                      voxl2:/$
                      @david-devassy Okay so it does seem like the voxl2 is having an issue communicating with the TOF sensor. Is this a stock, unmodified starling?
                        david devassy
                        @tom yes its a new one. stock unmodified. i think TOF module is not working properly. Do you provide any warranty for these.?
                          wrote on last edited by tom
                          #12
                          @david-devassy That's not something I'm in control of but you can look into https://www.modalai.com/pages/rma
                          We do test all sensors and flight test each drone before shipping so the failure would've occurred sometime after
                            david devassy
                            @tom
                            I have a new issue
                            Since yesterday, when I turned on the Starling drone, it just sits there. It's not getting armed. When I checked for ADB shell, it's not getting connected, and an error comes up saying no devices found. When I checked the forum, it said it might be bricked due to some file loss. We followed the unbrick tutorial, and after successful flashing of the latest QDL M0054.14.1a-flat-v3, the device is showing up as Qualcomm bulk something. However, ADB still isn't getting connected.
                            Please note that I am unable to enter adb shell and fast boot mode .
                            For unbrick I followed this
                            https://docs.modalai.com/voxl2-unbricking
