  3. How to do SLAM and VOXL-Mapper flying with Starling Drone ?
starling
13 Posts 3 Posters 3.2k Views 3 Watching
    @david-devassy Have you been following the documentation here: https://docs.modalai.com/voxl-mapper/#voxl-mapper?
    david devassyD Offline
    david devassy
    @Eric-Katzfey . Yes, we have followed the same only. i think my TOF sensor is not activated. we are not getting any data of TOF sensors on the VOXL Webportal. Can you Guide me on How to activate it.
    following attached images are the data regarding drone.Screenshot (2).png Screenshot (3).png Screenshot (4).png Screenshot (5).png
    • david devassyD david devassy
      tomT Online
      tomT Online
      @david-devassy Did you run through voxl-configure-sku -w and voxl-configure-mpa in order to enable / run all of the relevant services?
      david devassyD 2 Replies Last reply
        david devassy
        @tom ------------------------------------------------------------------
        Welcome to the voxl-configure-sku Wizard!
        VOXL currently thinks it is in the following hardware:
        family code: MRB-D0005 (starling)
        compute board: 4 (voxl2)
        hw version: 3
        cam config: 6
        SKU: MRB-D0005-4-V3-C6
        If this is what you want, select 1 (accept and continue) to
        leave it as-is. Otherwise, select the desired product family:
        1. accept and continue 10) seeker
        2. starling 11) rb5-flight
        3. sentinel 12) flight-deck
        4. fpv 13) voxl-deck
        5. D0010 14) voxl2-flight-deck
        6. px4-autonomy-dev-kit 15) voxl2-test-fixture
        7. stinger 16) voxl2-mini-test-fixture
        8. m500 17) voxl2-board-only
        9. voxlcam 18) voxl2-mini-board-only
          #? 2
          selected starling
        MRB-D0005 Starling currently has two versions in circulation.
        Version 2 with silver motors (pre December 2023)
        Version 3 with black motors (December 2023 onward)
        Please select the appropriate one.
        1. quit
        2. 2
        3. 3
          #? 3
        If you would like to select a special camera config that differs
        from the default for your product family, please select an option.
        Simply hit ENTER to use the default
        01 - ov7251 tracking ov7251 stereo
        02 - ov7251 tracking
        03 - ov7251 tracking ov7251 stereo imx214 hires
        04 - ov7251 tracking imx214 hires
        05 - pmd-tof ov7251 tracking
        06 - D0005 Starling pmd-tof imx214 hires ov7251 tracking
        08 - imx214
        09 - pmd-tof
        10 - ov7251 stereo
        11 - D0006 Sentinel
        12 - ov9782 stereo
        13 - ov9782 stereo imx214 hires
        14 - ov9782 stereo pmd-tof ov7251 tracking (copy)
        15 - D0008 dual 9782 tracking
        16 - pmd-tof ov7251 dual tracking imx214 hires
        17 - D0010 pmd-tof imx412 hires ov7251 tracking ov9782 stereo
        18 - D0008 triple ov9782
        19 - D0005 without tof imx214 hires ov7251 tracking
        20 - D0011 imx412 hires ar0144 tracking
        21 - old C6
        22 - D0013 imx412 flipped ov7251
        23 - D0010 without stereo
        C - use user-defined custom camera config in
        (/data/modalai/custom_camera_config.txt)
        q - Quit The Wizard
        The default camera config for Starling is
        6 (hires+TOF+tracking)
        selection:
        Selecting default camera config
        Your answers would construct the following SKU:
        hw version: 3
        cam config: 6
        This sku will be saved to persistent memory so VOXL
        will remember what it is installed in, even between
        system image flashes.
        Press enter to accept and continue.
        If something is wrong press ctrl-C to quit and try again.
        DONE, MRB-D0005-4-V3-C6 has been written to /data/modalai/sku.txt
        Next you will likely want to run voxl-configure-mpa
        voxl2:/$ voxl-configure-mpa
                   Welcome to voxl-configure-mpa!
        VOXL is currently thinks it is in the following hardware:
        hw version: 3
        cam config: 6
        If this doesn't look right, quit and run voxl-configure-sku to
        set it correctly. Then run voxl-configure-mpa again.
        Continue? y/n: y
        Continuing
        About to Execute:
        voxl-configure-extrinsics starling_v2_voxl2
        voxl-configure-cameras 6
        voxl-configure-cpu-monitor factory_enable
        voxl-configure-qvio factory_enable_imu_apps
        voxl-configure-open-vins disable
        voxl-configure-dfs factory_disable
        voxl-configure-tag-detector factory_disable
        voxl-configure-tflite factory_disable
        voxl-configure-vision-hub factory_enable
        voxl-configure-mavlink-server factory_enable
        voxl-configure-portal enable
        voxl-configure-lepton disable
        voxl-configure-uvc disable
        voxl-configure-streamer factory_enable
        voxl-configure-modem disable
        voxl-configure-mavcam factory_enable
        voxl-configure-rangefinders disable
        voxl-configure-px4-imu-server factory_disable
        voxl-configure-imu factory_enable
        voxl-configure-flow-server disable
        voxl-configure-feature-tracker disable
        systemctl stop voxl-px4
        systemctl disable voxl-px4
        sleep 3
        voxl-esc setup_starling_black_motors
        voxl-elrs --scan
        rm -f /data/px4/param/parameters
        voxl-configure-px4 starling_v2
        systemctl stop voxl-mavlink-server
        sleep 1
        voxl-configure-px4-params --non-interactive --platform MRB-D0005-V2
        enabling voxl-wait-for-fs service
        executing: voxl-configure-extrinsics starling_v2_voxl2
        wiping old extrinsics config file
        copying /usr/share/modalai/extrinsic_configs/starling_v2_voxl2.conf to /etc/modalai/extrinsics.conf
        loading and updating file with voxl-inspect-extrinsics -q
        done configuring extrinsics
        Success!
        executing: voxl-configure-cameras 6
        Camera Configuration: 6
        camera server config helper list:
        tof:pmd-tof:0:
        hires:imx214:1:
        tracking:ov7251:2:
        driver binary list:
        /usr/share/modalai/chi-cdk/irs1645/com.qti.sensormodule.irs1645_0.bin
        /usr/share/modalai/chi-cdk/imx214/com.qti.sensormodule.imx214_2.bin
        /usr/share/modalai/chi-cdk/ov7251/com.qti.sensormodule.ov7251_3.bin
        calling camera-server-config-helper tof:pmd-tof:0: hires:imx214:1: tracking:ov7251:2:
        detected system image 1.7.4
        using new imx214 defaults
        successfully wrote this camera config to disk:
        configuration for 3 cameras:
        cam #0
        sensor type: pmd-tof
        isEnabled: 1
        camId: 0
        camId2: -1
        fps: 5
        en_rotate: 0
        en_rotate2: 0
        en_preview:          1
        pre_width:           224
        pre_height:          1557
        en_raw_preview:      1
        en_small_video:      0
        small_video_width:   -1
        small_video_height:  -1
        en_large_video:      0
        large_video_width:   -1
        large_video_height:  -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             off
        standby_enabled:     0
        decimator:           5
        independent_exposure:0
        cam #1
        sensor type: imx214
        isEnabled: 1
        camId: 1
        camId2: -1
        fps: 30
        en_rotate: 0
        en_rotate2: 0
        en_preview:          0
        pre_width:           640
        pre_height:          480
        en_raw_preview:      0
        en_small_video:      1
        small_video_width:   1024
        small_video_height:  768
        en_large_video:      1
        large_video_width:   4208
        large_video_height:  3120
        en_snapshot:         1
        snap_width:          4208
        snap_height:         3120
        ae_mode:             isp
        standby_enabled:     0
        decimator:           1
        cam #2
        sensor type: ov7251
        isEnabled: 1
        camId: 2
        camId2: -1
        fps: 30
        en_rotate: 0
        en_rotate2: 0
        en_preview:          1
        pre_width:           640
        pre_height:          480
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        standby_enabled:     0
        decimator:           1
        camera_server_config_helper is done
        copying required camera drivers in place
        enabling voxl-camera-server
        Done Configuring Cameras
        Please power cycle VOXL to load new drivers
        camera server will start on next reboot
        Success!
        executing: voxl-configure-cpu-monitor factory_enable
        wiping old config file
        Creating new config file: /etc/modalai/voxl-cpu-monitor.conf
        enabling voxl-cpu-monitor systemd service
        Done configuring voxl-cpu-monitor
        Success!
        executing: voxl-configure-qvio factory_enable_imu_apps
        loading config file
        Creating new config file: /etc/modalai/voxl-qvio-server.conf
        enabling voxl-qvio-server systemd service
        Done configuring voxl-qvio-server
        Success!
        executing: voxl-configure-open-vins disable
        disabling voxl-open-vins-server systemd service
        stopping voxl-open-vins-server systemd service
        Done configuring voxl-open-vins-server
        Success!
        executing: voxl-configure-dfs factory_disable
        Creating new config file: /etc/modalai/voxl-dfs-server.conf
        disabling voxl-dfs-server systemd service
        Removed /etc/systemd/system/multi-user.target.wants/voxl-dfs-server.service.
        stopping voxl-dfs-server systemd service
        Done configuring voxl-dfs-server
        Success!
        executing: voxl-configure-tag-detector factory_disable
        Creating new config file: /etc/modalai/voxl-tag-detector.conf
        disabling voxl-tag-detector systemd service
        stopping voxl-tag-detector systemd service
        Done configuring voxl-tag-detector
        Success!
        executing: voxl-configure-tflite factory_disable
        Creating new config file: /etc/modalai/voxl-tflite-server.conf
        The config file was modified during parsing, saving the changes to disk
        disabling voxl-tflite-server systemd service
        Removed /etc/systemd/system/multi-user.target.wants/voxl-tflite-server.service.
        stopping voxl-tflite-server systemd service
        Done configuring voxl-tflite-server
        Success!
        executing: voxl-configure-vision-hub factory_enable
        Created new json file: /etc/modalai/voxl-vision-hub.conf
        The JSON config file data was modified during parsing, saving the changes to disk
        enabling voxl-vision-hub systemd service
        Done configuring voxl-vision-hub
        service will start on next reboot
        Success!
        executing: voxl-configure-mavlink-server factory_enable
        Created new json file: /etc/modalai/voxl-mavlink-server.conf
        enabling voxl-mavlink-server systemd service
        Done configuring voxl-mavlink-server
        Success!
        executing: voxl-configure-portal enable
        enabling voxl-portal systemd service
        Done configuring voxl-portal
        Success!
        executing: voxl-configure-lepton disable
        disabling voxl-lepton-server systemd service
        stopping voxl-lepton-server systemd service
        Done configuring voxl-lepton-server
        Success!
        executing: voxl-configure-uvc disable
        disabling voxl-uvc-server systemd service
        stopping voxl-uvc-server systemd service
        Done configuring voxl-uvc-server
        Success!
        executing: voxl-configure-streamer factory_enable
        Creating new config file: /etc/modalai/voxl-streamer.conf
        writing /etc/modalai/voxl-streamer.conf to disk
        parsed config file
        enabling voxl-streamer systemd service
        Done configuring voxl-streamer, it will start on next reboot
        Success!
        executing: voxl-configure-modem disable
        disabling voxl-modem systemd service
        stopping voxl-modem systemd service
        Done configuring voxl-modem
        Success!
        executing: voxl-configure-mavcam factory_enable
        Creating new config file: /etc/modalai/voxl-mavcam-manager.conf
        writing /etc/modalai/voxl-mavcam-manager.conf to disk
        enabling voxl-mavcam-manager systemd service
        Done configuring voxl-mavcam-manager
        It will start automatically on the next reboot
        Success!
        executing: voxl-configure-rangefinders disable
        disabling voxl-rangefinder-server systemd service
        Removed /etc/systemd/system/multi-user.target.wants/voxl-rangefinder-server.service.
        stopping voxl-rangefinder-server systemd service
        Done configuring voxl-rangefinder-server
        Success!
        executing: voxl-configure-px4-imu-server factory_disable
        disabling voxl-px4-imu-server systemd service
        stopping voxl-px4-imu-server systemd service
        Done configuring voxl-px4-imu-server
        Success!
        executing: voxl-configure-imu factory_enable
        Creating new config file: /etc/modalai/voxl-imu-server.conf
        enabling voxl-imu-server systemd service
        Done configuring voxl-imu-server
        Success!
        executing: voxl-configure-flow-server disable
        disabling voxl-flow-server systemd service
        stopping voxl-flow-server systemd service
        Done configuring voxl-flow-server
        Success!
        executing: voxl-configure-feature-tracker disable
        disabling voxl-feature-tracker systemd service
        stopping voxl-feature-tracker systemd service
        Done configuring voxl-feature-tracker
        Success!
        executing: systemctl stop voxl-px4
        Success!
        executing: systemctl disable voxl-px4
        Removed /etc/systemd/system/multi-user.target.wants/voxl-px4.service.
        Success!
        executing: sleep 3
        Success!
        executing: voxl-esc setup_starling_black_motors
        enabling bridge
        bridge enabled
        [INFO] Setting CPU to performance mode
        [INFO] Scanning for ESC...
        dpkg-query: no packages found matching voxl-esc-board-detect.py
        dpkg-query: no packages found matching voxl-esc-calibrate.py
        dpkg-query: no packages found matching voxl-esc-led.py
        dpkg-query: no packages found matching voxl-esc-neopixel-test.py
        dpkg-query: no packages found matching voxl-esc-scan.py
        dpkg-query: no packages found matching voxl-esc-spin-helper.sh
        dpkg-query: no packages found matching voxl-esc-spin-sine.py
        dpkg-query: no packages found matching voxl-esc-spin-step.py
        dpkg-query: no packages found matching voxl-esc-spin.py
        dpkg-query: no packages found matching voxl-esc-tools-bin
        dpkg-query: no packages found matching voxl-esc-upload-firmware-all.sh
        dpkg-query: no packages found matching voxl-esc-upload-firmware.py
        dpkg-query: no packages found matching voxl-esc-upload-params.py
        dpkg-query: no packages found matching voxl-esc-verify-params.py
        dpkg-query: no packages found matching voxl_esc_setup_paths.py
        dpkg-query: no packages found matching voxl_serial.py
        [INFO] M0134-1 detected
        [INFO] has for most recent firmware: eb6fb500
        [INFO] Expected ESC firmware info:
        Firmware: modalai_esc_firmware_m0134_1_v0_39_RC10_eb6fb500.bin
        Firmware hash: eb6fb500
        [INFO] Number of ESCs with correct FW: 4
        [INFO] All of the ESCs have the correct firmware loaded
        uploading params file ../voxl-esc-params/starling_1504_3000kv/starling_1504_3000kv.xml
        [GCC 8.4.0]
        Found voxl-esc tools bin version: 1.6
        VOXL Platform: M0054
        INFO: ESC Information:
        INFO: ---------------------
        Board : version 37: ModalAi 4-in-1 ESC (M0134-1)
        UID : 0x2033303852465719003E0056
        Firmware : version 39, hash eb6fb500
        Bootloader : version 183, hash b4fa2cf8
        UID        : 0x20333038524657190026004F
        UID        : 0x203330385246571900260049
        UID        : 0x2033303852465718001C002B
        successfully pinged ESCs
        [GCC 8.4.0]
        INFO: Params file name : ../voxl-esc-params/starling_1504_3000kv/starling_1504_3000kv.xml
        INFO: Params file size : 7602 bytes
        STILL SAME. WE THINK OUR TOF UNIT IS NOT WORKING. ITS DEAD ON ARRIVAL.
          david devassy
          INFO: ESCs detected:
          ID: 0, SW: 39, HW: 37: ModalAi 4-in-1 ESC (M0134-1)
          ID: 1, SW: 39, HW: 37: ModalAi 4-in-1 ESC (M0134-1)
          ID: 2, SW: 39, HW: 37: ModalAi 4-in-1 ESC (M0134-1)
          ID: 3, SW: 39, HW: 37: ModalAi 4-in-1 ESC (M0134-1)
          INFO: Loading XML config file...
          INFO: Uploading params for ESC ID 255...
          -- board config
          -- id config
          -- uart config
          -- tune config
          DONE
          INFO: Resetting ESCs...
          DONE
          WARNING: Received 12 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
          disabling bridge
          bridge disabled
          Success!
          executing: voxl-elrs --scan
          [ERROR] Error reading device information.
          [ERROR] Ensure that transmitter is turned off and receiver is not in bootloader mode.
          first try failed, executing a second time: voxl-elrs --scan
          FAILED TO EXECUTE: voxl-elrs --scan
          Success!
          executing: rm -f /data/px4/param/parameters
          Success!
          executing: voxl-configure-px4 starling_v2
          enabling voxl-px4 systemd service
          Created symlink /etc/systemd/system/multi-user.target.wants/voxl-px4.service → /etc/systemd/system/voxl-px4.service.
          Success!
          executing: systemctl stop voxl-mavlink-server
          Success!
          executing: sleep 1
          Success!
          executing: voxl-configure-px4-params --non-interactive --platform MRB-D0005-V2
          [INFO] Voxl-px4 not currently running.
          [INFO] Starting voxl-px4 service...
          [INFO] Voxl-px4 started successfully!
          [INFO] Loading the following param files: platforms/Starling_V2.params, EKF2_helpers/indoor_vio.params, radio_helpers/Commando_8.params.
          [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/platforms/Starling_V2.params
          [INFO] Scanning currently loaded parameters...
          The following parameters about to be loaded differ from those currently loaded:
          NAME CURRENT NEW
          [1] CBRK_IO_SAFETY N/A 22027
          [2] COM_CPU_MAX 0.0 -1.0
          [3] COM_OF_LOSS_T N/A 3.0
          [4] NAV_ACC_RAD N/A 2.0
          [5] GPS_UBX_DYNMODEL N/A 6
          [6] RTL_RETURN_ALT N/A 30
          [7] RTL_DESCEND_ALT N/A 10
          [8] SENS_BOARD_ROT N/A 0
          [9] BAT1_N_CELLS N/A 2
          [10] BAT1_R_INTERNAL N/A 0.025
          [11] BAT1_CAPACITY N/A 2900
          [12] BAT1_V_CHARGED N/A 4.1
          [13] BAT1_V_EMPTY N/A 3.2
          [14] BAT_LOW_THR N/A 0.15
          [15] BAT_CRIT_THR N/A 0.10
          [16] BAT_EMERGEN_THR N/A 0.05
          [17] MPC_THR_HOVER 0.42 0.34
          [18] THR_MDL_FAC N/A 0.9
          [19] VOXL_ESC_RPM_MAX 10500.0 15000.0
          [20] VOXL_ESC_RPM_MIN 1000.0 3000.0
          [21] VOXL_ESC_FUNC2 103.0 104.0
          [22] VOXL_ESC_FUNC3 104.0 102.0
          [23] VOXL_ESC_FUNC4 102.0 103.0
          [24] VOXL_ESC_T_COSP N/A 0.990000009536743164
          [25] VOXL_ESC_T_DEAD N/A 20
          [26] VOXL_ESC_T_EXPO N/A 35
          [27] VOXL_ESC_T_MINF N/A 0.150000005960464478
          [28] VOXL_ESC_T_PERC N/A 90
          [29] VOXL_ESC_VLOG N/A 1
          [30] MC_BAT_SCALE_EN N/A 0
          [31] EKF2_IMU_POS_X 0.027 0.0157
          [32] EKF2_IMU_POS_Y 0.009 0.0078
          [33] EKF2_IMU_POS_Z -0.019 -0.018
          [34] EKF2_EV_POS_X N/A 0.0
          [35] EKF2_EV_POS_Y N/A 0.0
          [36] EKF2_EV_POS_Z N/A 0.0
          [37] CA_ROTOR0_PX 0.15 0.085
          [38] CA_ROTOR0_PY 0.15 0.0625
          [39] CA_ROTOR1_PX -0.15 -0.085
          [40] CA_ROTOR1_PY -0.15 -0.0625
          [41] CA_ROTOR2_PX 0.15 0.085
          [42] CA_ROTOR2_PY -0.15 -0.0625
          [43] CA_ROTOR3_PX -0.15 -0.085
          [44] CA_ROTOR3_PY 0.15 0.0625
          [45] CA_ROTOR0_AX N/A 0.0
          [46] CA_ROTOR0_AY N/A 0.0
          [47] CA_ROTOR1_AX N/A 0.0
          [48] CA_ROTOR1_AY N/A 0.0
          [49] CA_ROTOR2_AX N/A 0.0
          [50] CA_ROTOR2_AY N/A 0.0
          [51] CA_ROTOR3_AX N/A 0.0
          [52] CA_ROTOR3_AY N/A 0.0
          [53] CA_ROTOR0_KM N/A 0.05
          [54] CA_ROTOR1_KM N/A 0.05
          [55] MOT_SLEW_MAX N/A 0.0
          [56] IMU_DGYRO_CUTOFF N/A 60.0
          [57] IMU_ACCEL_CUTOFF N/A 80.0
          [58] IMU_GYRO_CUTOFF N/A 80.0
          [59] IMU_GYRO_DNF_EN N/A 1
          [60] IMU_GYRO_DNF_HMC N/A 3
          [61] IMU_GYRO_DNF_BW N/A 15
          [62] MC_PITCH_P 5.5 16.0
          [63] MC_PITCHRATE_P 0.08 0.12
          [64] MC_PITCHRATE_I 0.2 0.05
          [65] MC_PITCHRATE_D 0.0013 0.0015
          [66] MC_PITCH_CUTOFF N/A 150.0
          [67] MC_ROLL_P 5.5 16.0
          [68] MC_ROLLRATE_P 0.08 0.09
          [69] MC_ROLLRATE_I 0.2 0.05
          [70] MC_ROLLRATE_D 0.0013 0.0015
          [71] MC_ROLL_CUTOFF N/A 150.0
          [72] MC_YAW_P 2.0 2.8
          [73] MC_YAWRATE_I 0.1 0.5
          [74] MC_YAW_CUTOFF N/A 150.0
          [75] MC_ROLLRATE_MAX N/A 130.0
          [76] MC_PITCHRATE_MAX N/A 130.0
          [77] MC_YAWRATE_MAX N/A 150.0
          [78] MPC_POS_MODE 0.0 4.0
          [79] MPC_YAW_EXPO 0.2 0.3
          [80] MPC_XY_MAN_EXPO 0.2 0.45
          [81] MPC_Z_MAN_EXPO 0.2 0.1
          [82] MPC_ACC_HOR N/A 3.0
          [83] MPC_JERK_MAX N/A 40.0
          [84] MPC_TILTMAX_AIR N/A 30.0
          [85] MPC_ACC_HOR_MAX N/A 1000.0
          [86] MPC_ACC_UP_MAX N/A 3.0
          [87] MPC_ACC_DOWN_MAX N/A 3.0
          [88] MPC_VEL_MANUAL 5.0 3.0
          [89] MPC_XY_VEL_MAX 5.0 3.0
          [90] MPC_XY_CRUISE 5.0 3.0
          [91] MPC_Z_VEL_MAX_DN 1.5 1.0
          [92] MPC_Z_VEL_MAX_UP 4.0 1.0
          [93] MPC_HOLD_MAX_XY N/A 0.0
          [94] MPC_HOLD_MAX_Z N/A 0.0
          [95] MPC_THR_MAX 0.75 0.7
          [96] MPC_MANTHR_MIN 0.05 0.08
          [97] MPC_XY_P 0.95 3.5
          [98] MPC_Z_P 1.0 5.0
          [99] MPC_TKO_RAMP_T 1.5 1.0
          [100] COM_SPOOLUP_TIME N/A 2.0
          [101] LNDMC_ROT_MAX N/A 30.0
          [102] LNDMC_TRIG_TIME N/A 0.5
          [103] COM_DISARM_LAND N/A 0.1
          [104] COM_DISARM_PRFLT -1.0 20.0
          [INFO] Setting params...
          [ERROR] Failed to set PX4 parameters. Check voxl-px4 status for details.
          first try failed, executing a second time: voxl-configure-px4-params --non-interactive --platform MRB-D0005-V2
          [INFO] Voxl-px4 service found and active.
          NAME CURRENT NEW
          [2] CBRK_SUPPLY_CHK N/A 894281
          [3] COM_CPU_MAX N/A -1
          [4] COM_OF_LOSS_T N/A 3.0
          [5] NAV_ACC_RAD N/A 2.0
          [6] GPS_UBX_DYNMODEL N/A 6
          [7] RTL_RETURN_ALT N/A 30
          [8] RTL_DESCEND_ALT N/A 10
          [9] IMU_GYRO_RATEMAX N/A 800
          [10] SYS_AUTOSTART N/A 4001
          [11] MAV_TYPE N/A 2
          [12] SENS_BOARD_ROT N/A 0
          [13] BAT1_N_CELLS N/A 2
          [14] BAT1_R_INTERNAL N/A 0.025
          [15] BAT1_CAPACITY N/A 2900
          [16] BAT1_V_CHARGED N/A 4.1
          [17] BAT1_V_EMPTY N/A 3.2
          [18] BAT_LOW_THR N/A 0.15
          [19] BAT_CRIT_THR N/A 0.10
          [20] BAT_EMERGEN_THR N/A 0.05
          [21] MPC_THR_HOVER N/A 0.34
          [22] THR_MDL_FAC N/A 0.9
          [23] VOXL_ESC_FUNC1 N/A 101
          [24] VOXL_ESC_FUNC2 103.0 104.0
          [25] VOXL_ESC_FUNC3 104.0 102.0
          [26] VOXL_ESC_FUNC4 102.0 103.0
          [27] VOXL_ESC_SDIR1 N/A 0
          [28] VOXL_ESC_SDIR2 N/A 0
          [29] VOXL_ESC_SDIR3 N/A 0
          [30] VOXL_ESC_SDIR4 N/A 0
          [31] VOXL_ESC_BAUD N/A 2000000
          [32] VOXL_ESC_CONFIG N/A 1
          [33] VOXL_ESC_MODE N/A 0
          [34] VOXL_ESC_REV N/A 0
          [35] CA_AIRFRAME N/A 0
          [36] CA_ROTOR_COUNT N/A 4
          [37] CA_ROTOR2_KM N/A -0.05
          [38] CA_ROTOR3_KM N/A -0.05
          [39] MC_AIRMODE N/A 0
          [40] MC_PITCHRATE_K N/A 1.0
          [41] MC_ROLLRATE_K N/A 1.0
          [42] MC_YAWRATE_P N/A 0.15
          [43] MC_YAWRATE_D N/A 0.0
          [44] MC_YAWRATE_K N/A 1.0
          [45] MPC_LAND_SPEED N/A 1.0
          [46] MPC_THR_MIN N/A 0.08
          [47] MPC_XY_VEL_P_ACC N/A 3.00
          [48] MPC_XY_VEL_I_ACC N/A 0.10
          [49] MPC_XY_VEL_D_ACC N/A 0.00
          [50] MPC_Z_VEL_P_ACC N/A 8.0
          [51] MPC_Z_VEL_I_ACC N/A 2.0
          [52] MPC_Z_VEL_D_ACC N/A 0.0
          [53] MPC_TKO_SPEED N/A 1.50
          [INFO] PX4 parameter configuration successful!
          [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/EKF2_helpers/indoor_vio.params
          NAME CURRENT NEW
          [1] SYS_HAS_MAG N/A 1
          [2] SYS_HAS_GPS N/A 1
          [3] COM_ARM_WO_GPS N/A 1
          [4] EKF2_GPS_CTRL N/A 0
          [5] EKF2_MAG_TYPE N/A 5
          [6] EKF2_BARO_CTRL N/A 1
          [7] EKF2_EV_CTRL N/A 15
          [8] EKF2_OF_CTRL N/A 0
          [9] EKF2_RNG_CTRL N/A 0
          [10] EKF2_HGT_REF N/A 3
          [11] EKF2_EV_QMIN N/A 1
          [12] EKF2_EV_NOISE_MD N/A 0
          [13] EKF2_EVA_NOISE N/A 0.1
          [14] EKF2_EVP_GATE N/A 5.0
          [15] EKF2_EVP_NOISE N/A 0.1
          [16] EKF2_EVV_GATE N/A 3.0
          [17] EKF2_EVV_NOISE N/A 0.1
          [18] EKF2_EV_DELAY N/A 0.00
          [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/radio_helpers/Commando_8.params
          NAME CURRENT NEW
          [1] RC_CHAN_CNT N/A 16
          [2] RC_MAP_KILL_SW N/A 5
          [3] RC_MAP_FLTMODE N/A 6
          [4] COM_FLTMODE1 N/A 0
          [5] COM_FLTMODE2 N/A -1
          [6] COM_FLTMODE3 N/A -1
          [7] COM_FLTMODE4 N/A 2
          [8] COM_FLTMODE5 N/A -1
          [9] COM_FLTMODE6 N/A 7
          [10] RC1_DZ N/A 10.000000000000000000
          [11] RC1_MAX N/A 2000.000000000000000000
          [12] RC1_MIN N/A 1000.000000000000000000
          [13] RC1_REV N/A 1.000000000000000000
          [14] RC1_TRIM N/A 1500.000000000000000000
          [15] RC2_DZ N/A 10.000000000000000000
          [16] RC2_MAX N/A 2000.000000000000000000
          [17] RC2_MIN N/A 1000.000000000000000000
          [18] RC2_REV N/A 1.000000000000000000
          [19] RC2_TRIM N/A 1500.000000000000000000
          [20] RC3_DZ N/A 10.000000000000000000
          [21] RC3_MAX N/A 2000.000000000000000000
          [22] RC3_MIN N/A 1000.000000000000000000
          [23] RC3_REV N/A 1.000000000000000000
          [24] RC3_TRIM N/A 1500.000000000000000000
          [25] RC4_DZ N/A 10.000000000000000000
          [26] RC4_MAX N/A 2000.000000000000000000
          [27] RC4_MIN N/A 1000.000000000000000000
          [28] RC4_REV N/A 1.000000000000000000
          [29] RC4_TRIM N/A 1500.000000000000000000
          [30] RC5_DZ N/A 10.000000000000000000
          [31] RC5_MAX N/A 1988.000000000000000000
          [32] RC5_MIN N/A 1011.000000000000000000
          [33] RC5_REV N/A 1.000000000000000000
          [34] RC5_TRIM N/A 1500.000000000000000000
          [35] RC6_DZ N/A 10.000000000000000000
          [36] RC6_MAX N/A 1988.000000000000000000
          [37] RC6_MIN N/A 1011.000000000000000000
          [38] RC6_REV N/A 1.000000000000000000
          [39] RC6_TRIM N/A 1500.000000000000000000
          [40] RC7_DZ N/A 10.000000000000000000
          [41] RC7_MAX N/A 1988.000000000000000000
          [42] RC7_MIN N/A 1011.000000000000000000
          [43] RC7_REV N/A 1.000000000000000000
          [44] RC7_TRIM N/A 1500.000000000000000000
          [45] RC8_DZ N/A 10.000000000000000000
          [46] RC8_MAX N/A 1988.000000000000000000
          [47] RC8_MIN N/A 1011.000000000000000000
          [48] RC8_REV N/A 1.000000000000000000
          [49] RC8_TRIM N/A 1500.000000000000000000
          [50] RC9_DZ N/A 0.000000000000000000
          [51] RC9_MAX N/A 2000.000000000000000000
          [52] RC9_MIN N/A 1000.000000000000000000
          [53] RC9_REV N/A 1.000000000000000000
          [54] RC9_TRIM N/A 1500.000000000000000000
          [55] RC10_DZ N/A 0.000000000000000000
          [56] RC10_MAX N/A 2000.000000000000000000
          [57] RC10_MIN N/A 1000.000000000000000000
          [58] RC10_REV N/A 1.000000000000000000
          [59] RC10_TRIM N/A 1500.000000000000000000
          [60] RC11_DZ N/A 0.000000000000000000
          [61] RC11_MAX N/A 2000.000000000000000000
          [62] RC11_MIN N/A 1000.000000000000000000
          [63] RC11_REV N/A 1.000000000000000000
          [64] RC11_TRIM N/A 1500.000000000000000000
          [65] RC12_DZ N/A 0.000000000000000000
          [66] RC12_MAX N/A 1988.000000000000000000
          [67] RC12_MIN N/A 1011.000000000000000000
          [68] RC12_REV N/A 1.000000000000000000
          [69] RC12_TRIM N/A 1499.000000000000000000
          [70] RC13_DZ N/A 0.000000000000000000
          [71] RC13_MAX N/A 2000.000000000000000000
          [72] RC13_MIN N/A 1000.000000000000000000
          [73] RC13_REV N/A 1.000000000000000000
          [74] RC13_TRIM N/A 1500.000000000000000000
          [75] RC14_DZ N/A 0.000000000000000000
          [76] RC14_MAX N/A 2000.000000000000000000
          [77] RC14_MIN N/A 1000.000000000000000000
          [78] RC14_REV N/A 1.000000000000000000
          [79] RC14_TRIM N/A 1500.000000000000000000
          [80] RC15_DZ N/A 0.000000000000000000
          [81] RC15_MAX N/A 2000.000000000000000000
          [82] RC15_MIN N/A 1000.000000000000000000
          [83] RC15_REV N/A 1.000000000000000000
          [84] RC15_TRIM N/A 1500.000000000000000000
          [85] RC16_DZ N/A 0.000000000000000000
          [86] RC16_MAX N/A 2000.000000000000000000
          [87] RC16_MIN N/A 1000.000000000000000000
          [88] RC16_REV N/A 1.000000000000000000
          [89] RC16_TRIM N/A 1500.000000000000000000
          [90] RC17_DZ N/A 0.000000000000000000
          [91] RC17_MAX N/A 2000.000000000000000000
          [92] RC17_MIN N/A 1000.000000000000000000
          [93] RC17_REV N/A 1.000000000000000000
          [94] RC17_TRIM N/A 1500.000000000000000000
          [95] RC18_DZ N/A 0.000000000000000000
          [96] RC18_MAX N/A 2000.000000000000000000
          [97] RC18_MIN N/A 1000.000000000000000000
          [98] RC18_REV N/A 1.000000000000000000
          [99] RC18_TRIM N/A 1500.000000000000000000
          [100] RC_MAP_ACRO_SW N/A 0
          [101] RC_MAP_ARM_SW N/A 0
          [102] RC_MAP_AUX1 N/A 0
          [103] RC_MAP_AUX2 N/A 0
          [104] RC_MAP_AUX3 N/A 0
          [105] RC_MAP_AUX4 N/A 0
          [106] RC_MAP_AUX5 N/A 0
          [107] RC_MAP_AUX6 N/A 0
          [108] RC_MAP_FAILSAFE N/A 0
          [109] RC_MAP_FLAPS N/A 0
          [110] RC_MAP_GEAR_SW N/A 0
          [111] RC_MAP_LOITER_SW N/A 0
          [112] RC_MAP_MAN_SW N/A 0
          [113] RC_MAP_MODE_SW N/A 0
          [114] RC_MAP_OFFB_SW N/A 0
          [115] RC_MAP_PARAM1 N/A 0
          [116] RC_MAP_PARAM2 N/A 0
          [117] RC_MAP_PARAM3 N/A 0
          [118] RC_MAP_PITCH N/A 2
          [119] RC_MAP_POSCTL_SW N/A 0
          [120] RC_MAP_RATT_SW N/A 0
          [121] RC_MAP_RETURN_SW N/A 0
          [122] RC_MAP_ROLL N/A 1
          [123] RC_MAP_STAB_SW N/A 0
          [124] RC_MAP_THROTTLE N/A 3
          [125] RC_MAP_TRANS_SW N/A 0
          [126] RC_MAP_YAW N/A 4
          [INFO] Loading file: /data/px4/param/parameters_gyro.cal
          NAME CURRENT NEW
          [1] CAL_GYRO0_ID N/A 2490378
          [2] CAL_GYRO0_PRIO N/A 50
          [3] CAL_GYRO0_XOFF N/A 0.0134728
          [4] CAL_GYRO0_YOFF N/A -0.00290391
          [5] CAL_GYRO0_ZOFF N/A -0.000202846
          [6] CAL_GYRO0_ROT N/A -1
          [INFO] Trimming duplicate parameters...
          [INFO] Loading file: /data/px4/param/parameters_acc.cal
          NAME CURRENT NEW
          [1] CAL_ACC0_ID N/A 2490378
          [2] CAL_ACC0_PRIO N/A 50
          [3] CAL_ACC0_XOFF N/A 0.016479
          [4] CAL_ACC0_YOFF N/A 0.0495152
          [5] CAL_ACC0_ZOFF N/A -0.00822353
          [6] CAL_ACC0_XSCALE N/A 1
          [7] CAL_ACC0_YSCALE N/A 1
          [8] CAL_ACC0_ZSCALE N/A 1
          [9] CAL_ACC0_ROT N/A -1
          [INFO] Loading file: /data/px4/param/parameters_level.cal
          NAME CURRENT NEW
          [1] SENS_BOARD_X_OFF N/A 0.0105941
          [2] SENS_BOARD_Y_OFF N/A 0.00175017
          [INFO] Loading file: /data/px4/param/parameters_mag.cal
          NAME CURRENT NEW
          [1] CAL_MAG0_ID N/A 527625
          [2] CAL_MAG0_PRIO N/A 75
          [3] CAL_MAG0_XOFF N/A -0.284582
          [4] CAL_MAG0_YOFF N/A -0.281098
          [5] CAL_MAG0_ZOFF N/A 0.219934
          [6] CAL_MAG0_XSCALE N/A 1.00463
          [7] CAL_MAG0_YSCALE N/A 1.01471
          [8] CAL_MAG0_ZSCALE N/A 0.979607
          [9] CAL_MAG0_XODIAG N/A -0.0119525
          [10] CAL_MAG0_YODIAG N/A 0.0184261
          [11] CAL_MAG0_ZODIAG N/A -0.00372516
          [12] CAL_MAG0_XCOMP N/A 0
          [13] CAL_MAG0_YCOMP N/A 0
          [14] CAL_MAG0_ZCOMP N/A 0
          [15] CAL_MAG0_ROT N/A 0
          [INFO] Loading file: /data/px4/param/parameters_rc.cal
          [INFO] No difference in parameters was detected.
          [INFO] Done configuring for platform MRB-D0005-V2
          Success running a second time
               The following steps worked on the second try:
               FAILED TO EXECUTE the following steps:
          voxl-elrs --scan
            Encountered Problems Configuring MPA Services :-/
              Some Services may not start up on next reboot
          Calibration File Status:
          Present /data/modalai/voxl-imu-server.cal
          Present /data/modalai/opencv_tracking_intrinsics.yml
          Present /data/px4/param/parameters_gyro.cal
          Present /data/px4/param/parameters_acc.cal
          Present /data/px4/param/parameters_level.cal
          Present /data/px4/param/parameters_mag.cal
                      PLEASE POWER CYCLE YOUR VOXL
            -- board config
            -- id config
            -- uart config
            -- tune config
            DONE
            DONE
            disabling bridge
            bridge disabled
            Success!
            Success!
            Success!
            Success!
            Success!
            executing: sleep 1
            Success!
            NAME CURRENT NEW
            NAME CURRENT NEW
            [11] MAV_TYPE N/A 2
            NAME CURRENT NEW
            NAME CURRENT NEW
            NAME CURRENT NEW
            NAME CURRENT NEW
            NAME CURRENT NEW
            NAME CURRENT NEW
            voxl-elrs --scan
            tomT Online
            tomT Online
            @david-devassy What do you see with voxl-list-pipes and systemctl status voxl-camera-server
            david devassyD 1 Reply Last reply
              david devassy
              @tom voxl2:/$ voxl-list-pipes
              cpu_monitor
              gcs_ip_list
              hires_large_color
              hires_large_encoded
              hires_large_grey
              hires_small_color
              hires_small_encoded
              hires_small_grey
              hires_snapshot
              horizon_cal_io
              imu_apps
              imu_apps_fft
              mavlink_ap_heartbeat
              mavlink_attitude
              mavlink_from_gcs
              mavlink_gps_raw_int
              mavlink_local_position_ned
              mavlink_onboard
              mavlink_sys_status
              mavlink_to_gcs
              modal_io_bridge
              plan_msgs
              qvio
              qvio_extended
              qvio_overlay
              tracking
              voa_pc_out
              voxl_mapper_aligned_ptcloud
              voxl_mapper_costmap
              voxl_mesh
              voxl_mesh_endpoint
              voxl_planner_render
              vvhub_body_wrt_fixed
              vvhub_body_wrt_local
              vvhub_fixed_pose_input
              voxl2:/$ systemctl status voxl-camera-server
              ● voxl-camera-server.service - voxl-camera-server
              Loaded: loaded (/usr/bin/voxl-camera-server; enabled; vendor preset: enabled)
              Active: active (running) since Fri 2024-04-12 09:02:25 UTC; 3min 59s ago
              Main PID: 1404 (voxl-camera-ser)
              Tasks: 68 (limit: 4915)
              CGroup: /system.slice/voxl-camera-server.service
              └─1404 /usr/bin/voxl-camera-server
              Apr 12 09:02:25 m0054 voxl-camera-server[1404]: gbm_create_device(156): Info: backend name is: msm_drm
              Apr 12 09:02:25 m0054 voxl-camera-server[1404]: Starting Camera: tracking (originally id #2) with id offset: 1
              Apr 12 09:02:25 m0054 voxl-camera-server[1404]: Using gain limits min: 54 max: 3451
              Apr 12 09:02:25 m0054 voxl-camera-server[1404]: setting ov7251 BLC register for cam id 1
              Apr 12 09:02:25 m0054 voxl-camera-server[1404]: ------ voxl-camera-server: Started 2 of 3 cameras
              Apr 12 09:02:25 m0054 voxl-camera-server[1404]: ------ voxl-camera-server: Camera server is now running
              voxl2:/$
                cpu_monitor
                gcs_ip_list
                hires_large_color
                hires_large_encoded
                hires_large_grey
                hires_small_color
                hires_small_encoded
                hires_small_grey
                hires_snapshot
                horizon_cal_io
                imu_apps
                imu_apps_fft
                mavlink_attitude
                mavlink_from_gcs
                mavlink_gps_raw_int
                mavlink_onboard
                mavlink_sys_status
                mavlink_to_gcs
                modal_io_bridge
                plan_msgs
                qvio
                qvio_extended
                qvio_overlay
                tracking
                voa_pc_out
                voxl_mapper_costmap
                voxl_mesh
                voxl_mesh_endpoint
                voxl_planner_render
                voxl2:/$
                tomT Online
                tomT Online
                @david-devassy Okay so it does seem like the voxl2 is having an issue communicating with the TOF sensor. Is this a stock, unmodified starling?
                  david devassy
                  @tom yes its a new one. stock unmodified. i think TOF module is not working properly. Do you provide any warranty for these.?
                    tomT Online
                    tomT Online
                    wrote on last edited by tom
                    #12
                    @david-devassy That's not something I'm in control of but you can look into https://www.modalai.com/pages/rma
                    We do test all sensors and flight test each drone before shipping so the failure would've occurred sometime after
                      david devassy
                      I have a new issue
                      Since yesterday, when I turned on the Starling drone, it just sits there. It's not getting armed. When I checked for ADB shell, it's not getting connected, and an error comes up saying no devices found. When I checked the forum, it said it might be bricked due to some file loss. We followed the unbrick tutorial, and after successful flashing of the latest QDL M0054.14.1a-flat-v3, the device is showing up as Qualcomm bulk something. However, ADB still isn't getting connected.
                      Please note that I am unable to enter adb shell and fast boot mode .
                      For unbrick I followed this
                      https://docs.modalai.com/voxl2-unbricking
