    Factory reset Seeker
    2588
    • U
      utari_ais
      I was wondering how I can factory reset the seeker. I have had numerous problems trying to set it up so I just want to start afresh.
      Thanks in advance!
        Alex Kushleyev ModalAI Team @utari_ais
        @utari_ais ,
        Have you tried installing the latest SDK and going through the configuration steps during the SDK installation?
        U 1 Reply Last reply Reply Quote 0
        • U
          utari_ais @Alex Kushleyev
          @Alex-Kushleyev Yes I have. For some reason, the px4-config file is always empty (the file that I have to edit the ground station's IP into), this keeps happening with multiple SDKs that I have tried installing
          • tomT
            tom admin @utari_ais
            @utari_ais What file are you talking about? What is the file name and path?
            • U
              utari_ais @tom
              @tom /etc/modalai/voxl-vision-px4.conf
              I'm following this guide: https://docs.modalai.com/seeker-user-guide-network/
              • tomT
                @utari_ais The gcs IP setting was moved a while back into /etc/modalai/voxl-mavlink-server.conf, look for the primary_static_gcs_ip field.
                voxl-vision-px4 was also renamed to voxl-vision-hub
                • U
                  utari_ais @tom
                  @tom is there somewhere I can find the changes, the main documentation isn't updated so it is rather confusing
                  tomT 2 Replies Last reply Reply Quote 0
                  • tomT
                    @utari_ais What page are you referencing?
                    • tomT
                      @utari_ais
                      https://docs.modalai.com/voxl-developer-bootcamp/
                      https://docs.modalai.com/qgc-wifi/
                      • U
                        utari_ais @tom
                        @tom I have run into the same problem again. I am using this guide https://docs.modalai.com/qgc-wifi/
                        I am unable to connect the seeker to QGC. It worked last week, but now its not. I have correctly put the gcp IP setting in voxl-mavlink-server.conf and followed all the steps.
                        I am also unable to connect the spektrum transmitter to the drone, I always get a bind failed error whenever I try with QGC connected.
                        Any help is appreciated.
                          @utari_ais , are you able to establish the connection from GCS (instead of voxl2 trying to connect to GCS)? As described here : https://docs.modalai.com/qgc-wifi/#initiating-connection-to-voxl-from-qgroundcontrol
                          • U
                            @Alex-Kushleyev Nope. I have followed all the steps but nothing happens. QGC still says "Disconnected".
                              @utari_ais can you please make sure that both voxl-px4 and voxl-mavlink-server are running?
                              voxl2:/$ voxl-inspect-services | grep mavlink
                               voxl-mavlink-server      |  Enabled  |   Running   |     0.6%
                              voxl2:/$ voxl-inspect-services | grep voxl-px4
                               voxl-px4                 | Enabled  |   Running   |    25.1%
                              • U
                                @Alex-Kushleyev Here's what I see. I don't know why its not showing voxl-px4 as a service at all. image.png
                                Alex KushleyevA U 2 Replies Last reply Reply Quote 0
                                  @utari_ais , you may need to run voxl-configure-mpa to set up the board parameters (including px4) according to your device / drone. did you do that after SDK install?
                                  • U
                                    utari_ais @utari_ais
                                    @utari_ais I remember doing this. Let me try again.
                                    • U
                                      @Alex-Kushleyev is there anyway I can hard reset the drone? I think clearing it out and reinstalling might just do the trick
                                      • tomT
                                        @utari_ais Since you're using a voxl1 px4 is running on the flight core not on the voxl itself like voxl2. Therefore there is no voxl-px4 service on voxl1
