  4. Factory reset Seeker
18 Posts 3 Posters 3.4k Views 2 Watching
  • U utari_ais
    @tom is there somewhere I can find the changes, the main documentation isn't updated so it is rather confusing
    tomT Online
    tomT Online
    @utari_ais
    Link Preview Image
    VOXL Developer Bootcamp
    favicon
    Link Preview Image
    Connect to QGC
    favicon
    U 1 Reply Last reply
      @utari_ais
      Link Preview Image
      favicon
      Link Preview Image
      Connect to QGC
      favicon
      U Offline
      U Offline
      utari_ais
      @tom I have run into the same problem again. I am using this guide https://docs.modalai.com/qgc-wifi/
      I am unable to connect the seeker to QGC. It worked last week, but now its not. I have correctly put the gcp IP setting in voxl-mavlink-server.conf and followed all the steps.
      I am also unable to connect the spektrum transmitter to the drone, I always get a bind failed error whenever I try with QGC connected.
      Any help is appreciated.
      • U utari_ais
        @utari_ais , are you able to establish the connection from GCS (instead of voxl2 trying to connect to GCS)? As described here : https://docs.modalai.com/qgc-wifi/#initiating-connection-to-voxl-from-qgroundcontrol
          U Offline
          U Offline
          utari_ais
          @Alex-Kushleyev Nope. I have followed all the steps but nothing happens. QGC still says "Disconnected".
          • U utari_ais
            @utari_ais can you please make sure that both voxl-px4 and voxl-mavlink-server are running?
            voxl2:/$ voxl-inspect-services | grep mavlink
             voxl-mavlink-server      |  Enabled  |   Running   |     0.6%
            voxl2:/$ voxl-inspect-services | grep voxl-px4
             voxl-px4                 | Enabled  |   Running   |    25.1%
              U Offline
              U Offline
              utari_ais
              @Alex-Kushleyev Here's what I see. I don't know why its not showing voxl-px4 as a service at all. image.png
              Alex KushleyevA U 2 Replies Last reply
              • U utari_ais
                #15
                @utari_ais , you may need to run voxl-configure-mpa to set up the board parameters (including px4) according to your device / drone. did you do that after SDK install?
                • U utari_ais
                  U Offline
                  U Offline
                  utari_ais
                  @utari_ais I remember doing this. Let me try again.
                  • U utari_ais
                    U Offline
                    U Offline
                    utari_ais
                    @Alex-Kushleyev is there anyway I can hard reset the drone? I think clearing it out and reinstalling might just do the trick
                    • U utari_ais
                      tomT Online
                      tomT Online
                      @utari_ais Since you're using a voxl1 px4 is running on the flight core not on the voxl itself like voxl2. Therefore there is no voxl-px4 service on voxl1
