  3. Factory reset Seeker
18 Posts 3 Posters 3.8k Views 2 Watching
    @utari_ais What file are you talking about? What is the file name and path?
    U Offline
    U Offline
    utari_ais
    @tom /etc/modalai/voxl-vision-px4.conf
    I'm following this guide: https://docs.modalai.com/seeker-user-guide-network/
    • U utari_ais
      wrote on last edited by tom
      @utari_ais The gcs IP setting was moved a while back into /etc/modalai/voxl-mavlink-server.conf, look for the primary_static_gcs_ip field.
      voxl-vision-px4 was also renamed to voxl-vision-hub
      U 1 Reply Last reply
        U Offline
        U Offline
        utari_ais
        @tom is there somewhere I can find the changes, the main documentation isn't updated so it is rather confusing
        tomT 2 Replies Last reply
        • U utari_ais
          @utari_ais What page are you referencing?
          • U utari_ais
            @utari_ais
            https://docs.modalai.com/voxl-developer-bootcamp/
            https://docs.modalai.com/qgc-wifi/
              @utari_ais
              U Offline
              U Offline
              utari_ais
              @tom I have run into the same problem again. I am using this guide https://docs.modalai.com/qgc-wifi/
              I am unable to connect the seeker to QGC. It worked last week, but now its not. I have correctly put the gcp IP setting in voxl-mavlink-server.conf and followed all the steps.
              I am also unable to connect the spektrum transmitter to the drone, I always get a bind failed error whenever I try with QGC connected.
              Any help is appreciated.
              • U utari_ais
                @utari_ais , are you able to establish the connection from GCS (instead of voxl2 trying to connect to GCS)? As described here : https://docs.modalai.com/qgc-wifi/#initiating-connection-to-voxl-from-qgroundcontrol
                  U Offline
                  U Offline
                  utari_ais
                  @Alex-Kushleyev Nope. I have followed all the steps but nothing happens. QGC still says "Disconnected".
                  • U utari_ais
                    @utari_ais can you please make sure that both voxl-px4 and voxl-mavlink-server are running?
                    voxl2:/$ voxl-inspect-services | grep mavlink
                     voxl-mavlink-server      |  Enabled  |   Running   |     0.6%
                    voxl2:/$ voxl-inspect-services | grep voxl-px4
                     voxl-px4                 | Enabled  |   Running   |    25.1%
                      U Offline
                      U Offline
                      utari_ais
                      @Alex-Kushleyev Here's what I see. I don't know why its not showing voxl-px4 as a service at all. image.png
                      Alex KushleyevA U 2 Replies Last reply
                      • U utari_ais
                        #15
                        @utari_ais , you may need to run voxl-configure-mpa to set up the board parameters (including px4) according to your device / drone. did you do that after SDK install?
                        • U utari_ais
                          U Offline
                          U Offline
                          utari_ais
                          @utari_ais I remember doing this. Let me try again.
                          • U utari_ais
                            U Offline
                            U Offline
                            utari_ais
                            @Alex-Kushleyev is there anyway I can hard reset the drone? I think clearing it out and reinstalling might just do the trick
                            • U utari_ais
                              @utari_ais Since you're using a voxl1 px4 is running on the flight core not on the voxl itself like voxl2. Therefore there is no voxl-px4 service on voxl1
