    Gimbal camera streaming not starting
    2008
    • Daniel RyuD
      Daniel Ryu
      I bought a m500 with gimbal attached, and I can't seem to start the gimbal camera streaming. I ssh-ed into the drone over microhard radio (root@ip-address, password oelinux123). The drone cannot recognize ffmpeg for some reason. The drone appears to be up to date software-wise as well
      • tomT
        tom admin
        @Daniel-Ryu I believe ffmpeg was removed from voxl-suite a while back. It can be built and installed by following the instructions here: https://gitlab.com/voxl-public/other/voxl-ffmpeg
        Daniel RyuD 1 Reply Last reply Reply Quote 0
        • Daniel RyuD
          Daniel Ryu @tom
          @tom Could the voxl gimbal user guide be updated with that information? It would help a lot of users like myself. https://docs.modalai.com/voxl-m500-gimbal-user-guide/#streaming-to-qgroundcontrol
          • tomT
            tom admin
            @Daniel-Ryu Yes absolutely, thank you for the feedback.
            • Daniel RyuD
              Daniel Ryu
              When trying to run "voxl-docker -i voxl-emulator" as part of setting up voxl-ffmpeg, I get this error below:
              Error while pulling image: Get https://index.docker.io/v1/repositories/library/voxl-emulator/images: x509: certificate has expired or is not yet valid
              How do I fix this?
              • tomT
                tom admin
                @Daniel-Ryu Have you downloaded and loaded the voxl-emulator image from https://developer.modalai.com/asset/download/75 ?
                • Daniel RyuD
                  Daniel Ryu @tom
                  @tom Sorry, to clarify: I want to be able to run ffmpeg and stream from the gimbal from my m500, not from a voxl-emulator. Am I misunderstanding and instead must install the voxl-emulator to run ffmpeg?
                  • tomT
                    tom admin
                    @Daniel-Ryu voxl-emulator can be used to build packages for VOXL on your Linux PC. You can read about it here: https://docs.modalai.com/install-voxl-docker/
                    • Daniel RyuD
                      Daniel Ryu @tom
                      @tom That was it, thank you. I have just one suggestion: please include in the voxl-ffmpeg instructions to run ./install_on_voxl.sh at the end to deploy the ipk
                      • Daniel RyuD
                        Daniel Ryu
                        ffmpegs is working but I am still unable to stream to QGC. I'm using the same ip of QGC that is in voxl-vision-px4.conf that allows the drone to even connect to QGC in the first place. Here are all my settings.
                        • Eric KatzfeyE
                          Eric Katzfey ModalAI Team @Daniel Ryu
                          @Daniel-Ryu Are you able to see the video in another viewer, like VLC?
                          • Daniel RyuD
                            Daniel Ryu @Eric Katzfey
                            @Eric-Katzfey Yes, I can get the video to stream following the instructions here https://docs.modalai.com/uvc-streaming/
                            • Daniel RyuD
                              Daniel Ryu @Daniel Ryu
                              Also, could https://docs.modalai.com/voxl-m500-gimbal-user-guide/#streaming-to-qgroundcontrol this guide have a link to this guide here https://docs.modalai.com/uvc-streaming? I came across the second one quite by accident, despite them accomplishing similar purposes
                              • Daniel RyuD
                                Daniel Ryu
                                One more question: there's a config file referred to in this guide which is supposed to demonstrate how the gimbal can be controlled from the RC. Which one is it? https://docs.modalai.com/voxl-m500-gimbal-user-guide/#streaming-to-qgroundcontrol
                                • modaltbM
                                  modaltb ModalAI Team
                                  Here's a video that can help: https://youtu.be/eYr8nyFid0E?t=26
                                  PX4 params here: https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/helpers/gimbal_dx8_config.params
                                  • Daniel RyuD
                                    Daniel Ryu
                                    My DX8 looks and behaves differently from the one in the video. Is there a way to confirm that the knob and the switch right next to it are indeed channels 8 and 7, respectively?
                                    • modaltbM
                                      You can get a good feel from the radio configuration setup in QGC, where you can see the channel assignments -> roughly here https://docs.modalai.com/configure-rc-radio/
                                      • Daniel RyuD
                                        Daniel Ryu
                                        I'm still having trouble working out the controller and the gimbal. Here's a video of what I did. The channel monitor acknowledges one switch as channel 6 (which I set to RC_MAP_AUX1) but doesn't seem to respond to the dial. https://we.tl/t-HWHzLeJ46h
                                        • Daniel RyuD
                                          Daniel Ryu
                                          Solution: sometimes when just binding the RC controller, the inputs aren't shown. Make sure to restart drone after rebinding. Additionally, I've found different controllers have different lever/switch inputs, so its good to use QGC to look for the responsive switches and assign the ones you want accordingly
