  3. Voxl2 analog sensor interface
8 Posts 3 Posters 1.5k Views 1 Watching
  • tiralonghipolT Offline
    tiralonghipol
    I do not see an ADC or similar pin on the Voxl2 to read an analog signal coming from a flex sensor
    is there any other way to achieve this? maybe the gpio pins on J19 ?
    thank you!
    ModeratorM 1 Reply Last reply
    • tiralonghipolT tiralonghipol
      thank you!
      @tiralonghipol Correct, there is not an ADC input on VOXL 2
      tiralonghipolT 2 Replies Last reply
      • ModeratorM Moderator
        tiralonghipol
        wrote on last edited by tiralonghipol
        @Moderator awesome!
        I saw in the px4 drivers that the module i'm trying to read (ADS1115) is already supported
        what I plan to do, since I am not using pin 4 and 5 on J19 (sda,scl) is to read the adc instead of the gps.
        now the problem is that when I plug the ADC breakout board
        and i
        voxl2:/$ i2cdetect -r -y 0
             0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
        00:          -- -- -- -- -- -- -- -- -- -- -- -- --
        10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
        20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
        30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
        40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
        50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
        60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
        70: -- -- -- -- -- -- -- --
        there is nothing on i2c-0.
        actually there is no register detected on 0,1,2 (3 should not be used)
        what am I doing wrong?
        the physical connection is [J19 <-> adc board]:
        pin 1 (5V) <-> Vin
        pin 4 (SCL) <-> scl
        pin 5 (SDA) <-> sda
        pin 12 (GND) <-> gnd
        tiralonghipolT 1 Reply Last reply
          @Moderator awesome!
          and i
          pin 1 (5V) <-> Vin
          pin 4 (SCL) <-> scl
          pin 5 (SDA) <-> sda
          tiralonghipol
          @Moderator
          Solved using the J5 connector instead!
            tiralonghipol
            @Moderator
            so I am able to correctly read 2 flex sensors using a python library.
            But is it possible to achieve the same via the px4 driver itself? if yes, where should I look into?
            should I rebuild the voxl-px4 image enabling the ads1115 driver?
            I believe it is disabled by default, if I understood correctly
            just to give some context:
            let's say the arms of my quad are able to passively flex and I read the 4 deflection angles via this ADC.
            the ultimate goal I am trying to achieve is to send this analog information to the control actuator matrix and adapt it real time, taking into account the deflection
            Any help is highly appreciated thanks
              @Moderator
              @tiralonghipol That driver is not built or included in the px4 dsp build. So you would need to add that and then add it's start command to the /usr/bin/voxl-px4-start script file. You would need to specify -b 4 as an option to that start command to choose the proper bus.
                tiralonghipol
                @Eric-Katzfey thank you Eric!
                I figured out during our time-zone difference!
                I was actually able to use the pins reserved for the mag
                so I built the docker, added the driver, modified the start on the correct bus but now I am unsure: where are these values published? lol
                ========== Starting ads1115 ADC ===========
                INFO  [qshell] Send cmd: 'ads1115 start -X -b 1'
                INFO  [muorb] SLPI: qshell gotten: ads1115 start -X -b 1
                INFO  [muorb] SLPI:   arg0 = 'ads1115'
                INFO  [muorb] SLPI:   arg1 = 'start'
                INFO  [muorb] SLPI:   arg2 = '-X'
                INFO  [muorb] SLPI:   arg3 = '-b'
                INFO  [muorb] SLPI:   arg4 = '1'
                INFO  [muorb] SLPI: *** I2C Device ID 0x904809 9455625
                INFO  [muorb] SLPI: ads1115 #0 on I2C bus 1
                INFO  [muorb] SLPI:  (external)
                INFO  [muorb] SLPI:  address 0x48
                INFO  [muorb] SLPI:
                INFO  [muorb] SLPI: Ok executing command: ads1115 start -X -b 1
                INFO  [qshell] qshell return value timestamp: 791748467, local time: 791750038
                INFO  [uORB] Advertising remote topic sensor_baro
                INFO  [qshell] Send cmd: 'sensors start'
                INFO  [muorb] SLPI: qshell gotten: sensors start
                INFO  [muorb] SLPI:   arg0 = 'sensors'
                could be this one?
                INFO  [uORB] Advertising remote topic adc_report
                  INFO  [muorb] SLPI:
                  could be this one?
                  @tiralonghipol I have never used that sensor but from the code it looks like adc_report is indeed the data it is publishing.
