Voxl2 analog sensor interface
I do not see an ADC or similar pin on the Voxl2 to read an analog signal coming from a flex sensor
is there any other way to achieve this? maybe the gpio pins on J19 ?thank you!
@tiralonghipol Correct, there is not an ADC input on VOXL 2
@Moderator awesome!
I saw in the px4 drivers that the module i'm trying to read (ADS1115) is already supported
what I plan to do, since I am not using pin 4 and 5 on J19 (sda,scl) is to read the adc instead of the gps.now the problem is that when I plug the ADC breakout board
and i
voxl2:/$ i2cdetect -r -y 0 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- --there is nothing on i2c-0.
actually there is no register detected on 0,1,2 (3 should not be used)what am I doing wrong?
the physical connection is [J19 <-> adc board]:
pin 1 (5V) <-> Vin
pin 4 (SCL) <-> scl
pin 5 (SDA) <-> sda
pin 12 (GND) <-> gnd -
@Moderator awesome!
and i
pin 1 (5V) <-> Vin
pin 4 (SCL) <-> scl
pin 5 (SDA) <-> sda
pin 12 (GND) <-> gnd@Moderator
Solved using the J5 connector instead! -
@Moderator
so I am able to correctly read 2 flex sensors using a python library.But is it possible to achieve the same via the px4 driver itself? if yes, where should I look into?
should I rebuild the voxl-px4 image enabling the ads1115 driver?
I believe it is disabled by default, if I understood correctlyjust to give some context:
let's say the arms of my quad are able to passively flex and I read the 4 deflection angles via this ADC.
the ultimate goal I am trying to achieve is to send this analog information to the control actuator matrix and adapt it real time, taking into account the deflectionAny help is highly appreciated thanks
@Moderator
@tiralonghipol That driver is not built or included in the px4 dsp build. So you would need to add that and then add it's start command to the /usr/bin/voxl-px4-start script file. You would need to specify
-b 4as an option to that start command to choose the proper bus. -
-b 4as an option to that start command to choose the proper bus.@Eric-Katzfey thank you Eric!
I figured out during our time-zone difference!
I was actually able to use the pins reserved for the mag
so I built the docker, added the driver, modified the start on the correct bus but now I am unsure: where are these values published? lol========== Starting ads1115 ADC =========== INFO [qshell] Send cmd: 'ads1115 start -X -b 1' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: ads1115 start -X -b 1 INFO [muorb] SLPI: arg0 = 'ads1115' INFO [muorb] SLPI: arg1 = 'start' INFO [muorb] SLPI: arg2 = '-X' INFO [muorb] SLPI: arg3 = '-b' INFO [muorb] SLPI: arg4 = '1' INFO [muorb] SLPI: *** I2C Device ID 0x904809 9455625 INFO [muorb] SLPI: ads1115 #0 on I2C bus 1 INFO [muorb] SLPI: (external) INFO [muorb] SLPI: address 0x48 INFO [muorb] SLPI: INFO [muorb] SLPI: Ok executing command: ads1115 start -X -b 1 INFO [qshell] qshell return value timestamp: 791748467, local time: 791750038 INFO [uORB] Advertising remote topic sensor_baro INFO [qshell] Send cmd: 'sensors start' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: sensors start INFO [muorb] SLPI: arg0 = 'sensors' INFO [muorb] SLPI: arg1 = 'start'could be this one?
INFO [uORB] Advertising remote topic adc_report -
INFO [uORB] Advertising remote topic adc_report@tiralonghipol I have never used that sensor but from the code it looks like adc_report is indeed the data it is publishing.
