    Voxl2 analog sensor interface
    484
    • T
      tiralonghipol
      I do not see an ADC or similar pin on the Voxl2 to read an analog signal coming from a flex sensor
      is there any other way to achieve this? maybe the gpio pins on J19 ?
      thank you!
      M 1 Reply Last reply 19 Oct 2023, 14:20 Reply Quote 0
      • M
        Moderator ModalAI Team @tiralonghipol
        @tiralonghipol Correct, there is not an ADC input on VOXL 2
        T 2 Replies Last reply 23 Oct 2023, 10:19 Reply Quote 0
        • T
          tiralonghipol @Moderator
          @Moderator awesome!
          I saw in the px4 drivers that the module i'm trying to read (ADS1115) is already supported
          what I plan to do, since I am not using pin 4 and 5 on J19 (sda,scl) is to read the adc instead of the gps.
          now the problem is that when I plug the ADC breakout board
          and i
          voxl2:/$ i2cdetect -r -y 0
               0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
          00:          -- -- -- -- -- -- -- -- -- -- -- -- --
          10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
          20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
          30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
          40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
          50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
          60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
          70: -- -- -- -- -- -- -- --
          there is nothing on i2c-0.
          actually there is no register detected on 0,1,2 (3 should not be used)
          what am I doing wrong?
          the physical connection is [J19 <-> adc board]:
          pin 1 (5V) <-> Vin
          pin 4 (SCL) <-> scl
          pin 5 (SDA) <-> sda
          pin 12 (GND) <-> gnd
          T 1 Reply Last reply 24 Oct 2023, 07:01 Reply Quote 0
          • T
            tiralonghipol @tiralonghipol
            @Moderator
            Solved using the J5 connector instead!
            • T
              @Moderator
              so I am able to correctly read 2 flex sensors using a python library.
              But is it possible to achieve the same via the px4 driver itself? if yes, where should I look into?
              should I rebuild the voxl-px4 image enabling the ads1115 driver?
              I believe it is disabled by default, if I understood correctly
              just to give some context:
              let's say the arms of my quad are able to passively flex and I read the 4 deflection angles via this ADC.
              the ultimate goal I am trying to achieve is to send this analog information to the control actuator matrix and adapt it real time, taking into account the deflection
              Any help is highly appreciated thanks
              E 1 Reply Last reply 24 Oct 2023, 15:54 Reply Quote 0
              • E
                Eric Katzfey ModalAI Team @tiralonghipol
                @tiralonghipol That driver is not built or included in the px4 dsp build. So you would need to add that and then add it's start command to the /usr/bin/voxl-px4-start script file. You would need to specify -b 4 as an option to that start command to choose the proper bus.
                T 1 Reply Last reply 24 Oct 2023, 19:55 Reply Quote 0
                • T
                  tiralonghipol @Eric Katzfey
                  @Eric-Katzfey thank you Eric!
                  I figured out during our time-zone difference!
                  I was actually able to use the pins reserved for the mag
                  so I built the docker, added the driver, modified the start on the correct bus but now I am unsure: where are these values published? lol
                  ========== Starting ads1115 ADC ===========
                  INFO  [qshell] Send cmd: 'ads1115 start -X -b 1'
                  INFO  [muorb] SLPI: qshell gotten: ads1115 start -X -b 1
                  INFO  [muorb] SLPI:   arg0 = 'ads1115'
                  INFO  [muorb] SLPI: *** I2C Device ID 0x904809 9455625
                  INFO  [muorb] SLPI: ads1115 #0 on I2C bus 1
                  INFO  [muorb] SLPI:  address 0x48
                  INFO  [muorb] SLPI:
                  INFO  [muorb] SLPI: Ok executing command: ads1115 start -X -b 1
                  INFO  [qshell] qshell return value timestamp: 791748467, local time: 791750038
                  could be this one?
                  INFO  [uORB] Advertising remote topic adc_report
                  E 1 Reply Last reply 25 Oct 2023, 15:55 Reply Quote 0
                  • E
                    @tiralonghipol I have never used that sensor but from the code it looks like adc_report is indeed the data it is publishing.
                    1 out of 8
