  3. Reference frames extrinsics clarification
9 Posts 4 Posters 1.9k Views 1 Watching
  • A Offline
    afdrus
    Hi everyone,
    I have the following questions regarding the reference frames present in extrinsics.conf file:
    • It is my understanding that the body frame is a NED frame located in the geometric center (or center of gravity?) of the drone, but where is the origin along the z axis? Is it considered to be at the center of gravity of the drone?
    • Is the ground frame still a NED frame? Where it should be located with respect to the body frame?
    Thank you in advance for your response!
    tiralonghipolT 1 Reply Last reply
    • A afdrus
      Hi everyone,
      tiralonghipolT Offline
      tiralonghipol
      I also have the same issue:
      on the Starling V2, without changing any reference frame name (how to do that? is it possible?) I get everything pitched up
      is there any guide one can follow to configure this?
      ModeratorM 1 Reply Last reply
      • tiralonghipolT tiralonghipol
        @tiralonghipol if you viewed the data through voxl-portal, it would already be rotated properly. It's not clear which viewer you are using for the data.
        The Starling's extrinsic parameters can be found here, which should help you configure your tools
        • ModeratorM Moderator
          tiralonghipol
          wrote on last edited by tiralonghipol
          @Moderator I am using ROS and the visualized reference frame is wrt qvio
          the pcl is from the pmd sensor and fixed frame is world
          it seems like the tof is pitched 90 deg wrt to qvio
          I also tried to edit the file you mentioned, reboot (needed? since it is a service running at boot..) but there is not change in the extrinsics
          Any other suggestion?
            tiralonghipol
            @tiralonghipol I confirm that the same is happening in the portal, it is not a matter of visualization I believe
            the platform is flat on the desk, pointing forward, the visualized pointcloud is relatively pointing up
            default starling2_voxl2 parameters
            Chad SweetC 1 Reply Last reply
              @tiralonghipol yes, the ToF is rotated per the extrinsics. You will need to modify your urdf to match
              • Chad SweetC Chad Sweet
                tiralonghipol
                @Chad-Sweet thank you for the reply
                The this that I am struggling to understand is how to be sure that this parameters are actually applied after the .conf file is modified
                I tried to apply modification to any parent-child relation (putting absurd values to make it obvious) and there is no change is any of the frames.
                Is there any way to rotate the tof sensor?
                Where is the urdf you metioned located?
                Thank you again
                  Thank you again
                  @tiralonghipol Sorry for the confusion. The portal's web view for raw point clouds won't use the extrinsics. The voxl-mapper uses the extrinsics when building a map. You should use the extrinsics though for your URDF if you want to rotate the point cloud for your ROS application
                    tiralonghipol
                    @Moderator That makes way more sense, thank you for the clarification
                    As far as I could understand, there is no text saying that the .conf for the extrinsics is only used for the voxl-mapper on the modalai.docs, I think that is where my confusion came from
