  3. VOXL Flight Deck Kit Power Supply...
6 Posts 3 Posters 715 Views 3 Watching
  • Ed SutterE Offline
    Ed SutterE Offline
    Ed Sutter
    I am brand new to VOXL, just unpacking my VOXL Flight Deck Kit.
    Some of the startup pages point to a 12v supply, others point to a 5v supply to the Power Module. The silkscreen on my power module says: MODALAI APM LITE, M0041 REV B, 5V/12V. That implies (to me) that either will work, but I wanna be sure. Is 5V-8A supply compatible with that power module?
      Please see the datasheet for APMv3 here
      The APM supports 2S to 6S inputs
      The 5V/12V silkscreen is referring to the output. We have a 12V output version in that same footprint, but we don't generally sell it. VOXL requires 5V input, so the APM you have is 5V output.
        Ed SutterE Offline
        Ed Sutter
        Great, thanks!
          Ed SutterE Offline
          Ed Sutter
          @Chad-Sweet Sorry but I gotta make sure we're on the same page here (really don't wanna see any smoke!). I just need to make sure I supply the right voltage into the power module...
          I'm following the page for the flight deck. It just says the power module accepts a battery input. So I go to the VOXL Flight Quickstart page but it doesn't talk about the power module at all. That leads me to the VOXL Quickstart page which points to a 5V power supply and has a warning here not to use a 12V power supply.
          Hopefully you can see my reason for hesitation. Anyway, I see the APMv3 specs, but just want to confirm with you that my Power Module (with the markings I mention above) is definitely the APMv3 (which clearly requires a 12V supply).
          • tomT Offline
            @Ed-Sutter older versions of the APM had a barrel jack as well as an XT60 connector. On the older versions you can only put 5V into the barrel jack. You can give the XT60 12V just fine.
              Ed SutterE Offline
              Ed Sutter
              Got it, thanks to both.
              Sorry for the paranoia!
