    VOXL Flight Deck Kit Power Supply...
    • Ed SutterE
      Ed Sutter
      I am brand new to VOXL, just unpacking my VOXL Flight Deck Kit.
      Some of the startup pages point to a 12v supply, others point to a 5v supply to the Power Module. The silkscreen on my power module says: MODALAI APM LITE, M0041 REV B, 5V/12V. That implies (to me) that either will work, but I wanna be sure. Is 5V-8A supply compatible with that power module?
      • Chad SweetC
        Chad Sweet ModalAI Team
        Please see the datasheet for APMv3 here
        The APM supports 2S to 6S inputs
        The 5V/12V silkscreen is referring to the output. We have a 12V output version in that same footprint, but we don't generally sell it. VOXL requires 5V input, so the APM you have is 5V output.
        • Ed SutterE
          Ed Sutter
          Great, thanks!
          • Ed SutterE
            Ed Sutter
            @Chad-Sweet Sorry but I gotta make sure we're on the same page here (really don't wanna see any smoke!). I just need to make sure I supply the right voltage into the power module...
            I'm following the page for the flight deck. It just says the power module accepts a battery input. So I go to the VOXL Flight Quickstart page but it doesn't talk about the power module at all. That leads me to the VOXL Quickstart page which points to a 5V power supply and has a warning here not to use a 12V power supply.
            Hopefully you can see my reason for hesitation. Anyway, I see the APMv3 specs, but just want to confirm with you that my Power Module (with the markings I mention above) is definitely the APMv3 (which clearly requires a 12V supply).
              tom admin
              @Ed-Sutter older versions of the APM had a barrel jack as well as an XT60 connector. On the older versions you can only put 5V into the barrel jack. You can give the XT60 12V just fine.
              • Ed SutterE
                Ed Sutter
                Got it, thanks to both.
                Sorry for the paranoia!
