  3. Broken Parts
Broken Parts
52 Posts 4 Posters 29.6k Views 1 Watching
    @Bright-Nnadi the photos you sent me were of a VOXL CAM not a VOXL2, is that what you are referencing? Or is this different hardware that you’re talking about now
    Bright NnadiB Offline
    Bright Nnadi
    @tom Do y'all have sell the VOXL ESC USB interface
    • tomT Offline
      @Bright-Nnadi Is this what you're referencing? https://www.modalai.com/products/voxl-esc
      Bright NnadiB 2 Replies Last reply
        Bright Nnadi
        @tom I am talking about this https://docs.modalai.com/modal-esc-v2-manual/
        • tomT Offline
          @Bright-Nnadi Yes, that is the same as what I linked above.
            Bright Nnadi
            @tom Okay thanks Tom
            • Bright NnadiB Offline
              Bright Nnadi
              Hey Tom , So i am trying to set up the VOXL CAM now. I have turned it on using the power module and the USB and the LED is solid green but I am not seeing the VOXL wifi.
              • tomT Offline
                @Bright-Nnadi When you say you aren't seeing the VOXL WiFi, are you saying you want VOXL to be in SoftAP and are trying to connect to it with a computer? Or are you trying to put it in station mode and have it connect to an external network?
                Bright NnadiB 1 Reply Last reply
                  Bright Nnadi
                  @tom I am following the VOXL CAM Start guide and it says to connect to the VOXL wifi after powering it on. I am trying to connect it to my computer
                  • tomT Offline
                    @Bright-Nnadi Are you using ADB in order to access the VOXL's shell? If so, what is the output of ifconfig ?
                      Bright Nnadi
                      @tom 0e324744-66bb-42f8-b599-e4df4cb37dec-image.png output
                        Bright Nnadi
                        Tom right now I'm using the ADB and I want to enable the station mode. what SSID and password Im using for the command line adb shell voxl-wifi station <SSID> <Passowrd>
                        • tomT Offline
                          @Bright-Nnadi Apologies I mean running ifconfig in adb shell
                          You will do the following:
                          adb shell
                          voxl-wifi station SSID PASS
                          where SSID is the name of the WiFi network you want to connect to and PASS is the password of that network.
                          You'll want to connect to whatever network your ground station is also connected to.
                            adb shell
                            Bright Nnadi
                            @tom For some reason i am not able to get into the adb shell. And I am also using my organization's network which is private.
                              Bright Nnadi
                              @tom I'm trying to set up ADB now but this is happening 06b7a42f-fb9e-4a6c-86bd-279132cd724c-image.png
                                Bright Nnadi
                                @tom @Alex-Gardner I successfully installed adb but i am not still able to detect my VOXL CAM 419a6c4d-3e16-4010-8f1d-ed346e5db1cf-image.png
                                  Bright Nnadi
                                  • tomT Offline
                                    @Bright-Nnadi Are you using a Virtual Machine or are you running Ubuntu natively?
                                      Bright Nnadi
                                      @tom I am running ubuntu on my windows
                                        Bright Nnadi
                                        @tom is it possible we have a remote meeting?
                                        • tomT Offline
                                          @Bright-Nnadi I would recommend running Ubuntu natively on your ground station, this has worked for others who have issues when using a Virtual Machine. USB pass-through is often iffy.
