  3. Broken Parts
Broken Parts
voxl-2
52 Posts 4 Posters 27.5k Views 1 Watching
    @Bright-Nnadi When you say you aren't seeing the VOXL WiFi, are you saying you want VOXL to be in SoftAP and are trying to connect to it with a computer? Or are you trying to put it in station mode and have it connect to an external network?
      Bright NnadiB Offline
      Bright Nnadi
      @tom I am following the VOXL CAM Start guide and it says to connect to the VOXL wifi after powering it on. I am trying to connect it to my computer
        @Bright-Nnadi Are you using ADB in order to access the VOXL's shell? If so, what is the output of ifconfig ?
          Bright Nnadi
          @tom 0e324744-66bb-42f8-b599-e4df4cb37dec-image.png output
          • Bright NnadiB Offline
            Bright Nnadi
            Tom right now I'm using the ADB and I want to enable the station mode. what SSID and password Im using for the command line adb shell voxl-wifi station <SSID> <Passowrd>
              @Bright-Nnadi Apologies I mean running ifconfig in adb shell
              You will do the following:
              adb shell
              voxl-wifi station SSID PASS
              where SSID is the name of the WiFi network you want to connect to and PASS is the password of that network.
              You'll want to connect to whatever network your ground station is also connected to.
                adb shell
                Bright Nnadi
                @tom For some reason i am not able to get into the adb shell. And I am also using my organization's network which is private.
                  Bright Nnadi
                  @tom I'm trying to set up ADB now but this is happening 06b7a42f-fb9e-4a6c-86bd-279132cd724c-image.png
                    Bright Nnadi
                    @tom @Alex-Gardner I successfully installed adb but i am not still able to detect my VOXL CAM 419a6c4d-3e16-4010-8f1d-ed346e5db1cf-image.png
                      Bright Nnadi
                        @Bright-Nnadi Are you using a Virtual Machine or are you running Ubuntu natively?
                          Bright Nnadi
                          @tom I am running ubuntu on my windows
                            Bright Nnadi
                            @tom is it possible we have a remote meeting?
                              @Bright-Nnadi I would recommend running Ubuntu natively on your ground station, this has worked for others who have issues when using a Virtual Machine. USB pass-through is often iffy.
                                Bright Nnadi
                                @tom but I don’t have a gcs step up yet. I just want to turn out the camera.
                                  @Bright-Nnadi I'm confused what you're asking. If you want to do any sort of configuration/setup you'll have to get ADB working, which I would use Ubuntu natively on your machine in order to do that
                                    Bright Nnadi
                                    @tom I’m getting confused too. So I’m following y’all’s documentation. I have Ubuntu installed on my laptop natively and I have tried all the AdB commands y’all provided to active ADB but it did not work. If you can please give me a detail ordered steps to follow to have ADB activated then use the station mode to access the VOXL CAM.
                                      @Bright-Nnadi In a terminal, run dmesg -wH, then power your VOXL CAM and plug in USB to your machine, do you see any output in dmesg showing that the hardware is detected at all? If so, post it here and I can see what's going on.
                                        Bright Nnadi
                                          @Bright-Nnadi I can provide support in this case if you're running Ubuntu natively. Looks like you are using WSL on Windows.
                                          If you have a spare computer that you can actually load Ubuntu on by following something like this: https://ubuntu.com/tutorials/install-ubuntu-desktop#1-overview then I can help you out once you've done that but we don't use ADB over WSL.
                                          It's possible someone else on the forum has done it but we do not.
                                          Are you attempting to use the same VOXL CAM that we have already issued you an RMA for? If so I wouldn't keep trying to get it to work and I would send it in so we can fix it for you.
