  3. Broken Parts
Broken Parts
voxl-2
52 Posts 4 Posters 29.6k Views 1 Watching
    @Bright-Nnadi Is this what you're referencing? https://www.modalai.com/products/voxl-esc
    Bright NnadiB Offline
    Bright Nnadi
    @tom I am talking about this https://docs.modalai.com/modal-esc-v2-manual/
      @Bright-Nnadi Yes, that is the same as what I linked above.
        Bright Nnadi
        @tom Okay thanks Tom
        • Bright NnadiB Offline
          Bright Nnadi
          Hey Tom , So i am trying to set up the VOXL CAM now. I have turned it on using the power module and the USB and the LED is solid green but I am not seeing the VOXL wifi.
            @Bright-Nnadi When you say you aren't seeing the VOXL WiFi, are you saying you want VOXL to be in SoftAP and are trying to connect to it with a computer? Or are you trying to put it in station mode and have it connect to an external network?
              Bright Nnadi
              @tom I am following the VOXL CAM Start guide and it says to connect to the VOXL wifi after powering it on. I am trying to connect it to my computer
                @Bright-Nnadi Are you using ADB in order to access the VOXL's shell? If so, what is the output of ifconfig ?
                  Bright Nnadi
                  @tom 0e324744-66bb-42f8-b599-e4df4cb37dec-image.png output
                    Bright Nnadi
                    Tom right now I'm using the ADB and I want to enable the station mode. what SSID and password Im using for the command line adb shell voxl-wifi station <SSID> <Passowrd>
                      @Bright-Nnadi Apologies I mean running ifconfig in adb shell
                      You will do the following:
                      adb shell
                      voxl-wifi station SSID PASS
                      where SSID is the name of the WiFi network you want to connect to and PASS is the password of that network.
                      You'll want to connect to whatever network your ground station is also connected to.
                        adb shell
                        Bright Nnadi
                        @tom For some reason i am not able to get into the adb shell. And I am also using my organization's network which is private.
                          Bright Nnadi
                          @tom I'm trying to set up ADB now but this is happening 06b7a42f-fb9e-4a6c-86bd-279132cd724c-image.png
                            Bright Nnadi
                            @tom @Alex-Gardner I successfully installed adb but i am not still able to detect my VOXL CAM 419a6c4d-3e16-4010-8f1d-ed346e5db1cf-image.png
                              Bright Nnadi
                                @Bright-Nnadi Are you using a Virtual Machine or are you running Ubuntu natively?
                                  Bright Nnadi
                                  @tom I am running ubuntu on my windows
                                    Bright Nnadi
                                    @tom is it possible we have a remote meeting?
                                      @Bright-Nnadi I would recommend running Ubuntu natively on your ground station, this has worked for others who have issues when using a Virtual Machine. USB pass-through is often iffy.
                                        Bright Nnadi
                                        @tom but I don’t have a gcs step up yet. I just want to turn out the camera.
                                          @Bright-Nnadi I'm confused what you're asking. If you want to do any sort of configuration/setup you'll have to get ADB working, which I would use Ubuntu natively on your machine in order to do that
