  3. PX4 disconnected from UART & QGC cannot connected to modalAI
m500
15 Posts 5 Posters 3.5k Views 1 Watching
  • D Offline
    D Offline
    DarkKnightCH
    As you can see from the first figure, when I run:voxl_vision_px4 status, it shows that WARNING PX4 DISCONNECTED FROM UART, do you know how to address this issue? The firmware version is 1.11.3.
    I have noticed that this post have the same issue with mine. However, my ModalAI's MAV_1_MODE is already set to Onboard. https://forum.modalai.com/topic/70/warning-px4-disconnected-error-message-from-voxl-vision-px4?_=1657322074175
    Meanwhile, right now the QGC cannot connect to ModalAI.
    Any suggestion? Thanks in advance!
    H 1 Reply Last reply
    • D DarkKnightCH
      H Offline
      H Offline
      howard
      @DarkKnightCH
      Hi, Please try restarting the voxl-vision-px4 by running systemctl restart voxl-vision-px4.
      Try enabling voxl-mavlink-server
      Also ensure you have right qgc ip address in /etc/modalai/voxl-vision-px4.
      D 1 Reply Last reply
      • D Offline
        D Offline
        DarkKnightCH
        HI,
        I also found this post which has the same issue with me. I tried to follow the suggestion in this post:I open a MAVLink connection over USB to the flight core, and run mavlink status from the nutshell
        NuttShell (NSH)
        nsh> mavlink status
        instance #0:
            GCS heartbeat:    267144 us ago
            mavlink chan: #0
            type:        USB CDC
            flow control: OFF
            rates:
              tx: 15.682 kB/s
              txerr: 0.000 kB/s
              tx rate mult: 1.000
              tx rate max: 800000 B/s
              rx: 0.046 kB/s
            FTP enabled: YES, TX enabled: YES
            mode: Config
            MAVLink version: 2
            transport protocol: serial (/dev/ttyACM0 @2000000)
            ping statistics:
              last: 1.72 ms
              mean: 2.18 ms
              max: 6541.72 ms
              min: 0.19 ms
              dropped packets: 5
        instance #1:
            mavlink chan: #1
            type:        GENERIC LINK OR RADIO
            flow control: ON
            rates:
              tx: 1.564 kB/s
              txerr: 0.000 kB/s
              tx rate mult: 1.000
              tx rate max: 2880 B/s
              rx: 0.000 kB/s
            mode: Normal
            MAVLink version: 1
            transport protocol: serial (/dev/ttyS6 @57600)
        instance #2:
            mavlink chan: #2
            flow control: OFF
            rates:
              tx: 14.672 kB/s
              txerr: 0.000 kB/s
              tx rate mult: 1.000
              tx rate max: 46080 B/s
              rx: 0.000 kB/s
            mode: Onboard
            MAVLink version: 2
            transport protocol: serial (/dev/ttyS4 @921600)
        instance #3:
            mavlink chan: #3
            flow control: ON
            rates:
              tx: 1.564 kB/s
              txerr: 0.000 kB/s
              tx rate mult: 1.000
              rx: 0.000 kB/s
            mode: Normal
            MAVLink version: 1
            transport protocol: serial (/dev/ttyS1 @57600)
        From above information, I cannot track where the issue is, any suggestion?
        • H howard
          @DarkKnightCH
          D Offline
          D Offline
          DarkKnightCH
          @keil
          Hi, keil, Thanks for help.
          I tried to run the systemctl restart voxl-vision-px4, but it doesn't help.
          What do you mean enabling voxl-mavlink-server?
          QGC ip address is correct.
          • D DarkKnightCH
            HI,
            NuttShell (NSH)
            nsh> mavlink status
            instance #0:
                mavlink chan: #0
                type:        USB CDC
                flow control: OFF
                rates:
                  tx: 15.682 kB/s
                  txerr: 0.000 kB/s
                  tx rate mult: 1.000
                  rx: 0.046 kB/s
                mode: Config
                MAVLink version: 2
                ping statistics:
                  last: 1.72 ms
                  mean: 2.18 ms
                  max: 6541.72 ms
                  min: 0.19 ms
                  dropped packets: 5
            instance #1:
                mavlink chan: #1
                flow control: ON
                rates:
                  tx: 1.564 kB/s
                  txerr: 0.000 kB/s
                  tx rate mult: 1.000
                  rx: 0.000 kB/s
                mode: Normal
                MAVLink version: 1
            instance #2:
                mavlink chan: #2
                flow control: OFF
                rates:
                  tx: 14.672 kB/s
                  txerr: 0.000 kB/s
                  tx rate mult: 1.000
                  rx: 0.000 kB/s
                mode: Onboard
                MAVLink version: 2
            instance #3:
                mavlink chan: #3
                flow control: ON
                rates:
                  tx: 1.564 kB/s
                  txerr: 0.000 kB/s
                  tx rate mult: 1.000
                  rx: 0.000 kB/s
                mode: Normal
                MAVLink version: 1
            D Offline
            D Offline
            DarkKnightCH
            • D Offline
              D Offline
              DarkKnightCH
              wrote on last edited by DarkKnightCH
              More tests have done:
              (1) First, I can ssh into voxl through my laptop. And this means the wifi in VOXL is working.
              (2) I can adb into voxl board, which means that my voxl board is not bricked?
              (3)I can connect my flight core with my QGC via USB.
              (4)I tried to run voxl-inspect-services, and it shows
              (5)I also tried to run voxl-inspect-qvio, and it shows that
              (6)I also tried to reset the voxl-vision-px4 by running voxl-configure-vision-px4 as follows
              But there still is a WARNING show PX4 disconnected from UART.
              Any suggestion😧 ?
                That warning implies there is an issue in the comms between the Snapdragon and the STM32F7. Maybe try to reload the STM32F7 (Flight Core) firmware and see if that helps?
                • D Offline
                  D Offline
                  DarkKnightCH
                  @Chad-Sweet Yeah. I already reload a flight core firmware and it doesn't help. Is it possible that voxl-vision-px4 server is broken? The UART wire physical connection looks pretty valid. it is hard for me to find out where the issue is from.
                  • D Offline
                    D Offline
                    DarkKnightCH
                    @Chad-Sweet I would like to update my voxl-suite-ipk meta package since I doubt maybe something is wrong about the voxl-vision-px4? is there a simple way to do it except flashing a new system image of voxl? should I use the following command to do it?
                    opkg update && opkg upgrade
                      That warning implies a hardware issue more than a software issue. What if you try the nuttx shell to test connectivity between the Snapdragon and Flight Core?
                      • Chad SweetC Chad Sweet
                        D Offline
                        D Offline
                        DarkKnightCH
                        @Chad-Sweet I tried to follow your advice and it shows
                        voxl:~$ voxl-px4-shell
                        ERROR opening /run/mpa/vvpx4_shell/
                        most likely the voxl-vision-px4 service is not running
                        I also tried to run
                        and
                        voxl-vision-px4 status
                        and it shows
                        voxl:~$ voxl-vision-px4 status
                        loading our own config file
                        qgc_ip:                     192.168.0.121
                        en_localhost_mavlink_udp    1
                        en_secondary_qgc:           0
                        secondary_qgc_ip:           192.168.1.214
                        qgc_udp_port_number:        14550
                        localhost_udp_port_number:  14551
                        udp_mtu:                    512
                        en_vio:                     1
                        en_voa:                     1
                        en_send_vio_to_qgc:         0
                        en_send_voa_to_qgc:         0
                        en_set_clock_from_gps:      1
                        en_force_onboard_mav1_mode: 1
                        en_reset_px4_on_error:      1
                        qvio_auto_reset_quality:    0.000500
                        horizon_cal_tolerance:      0.300000
                        voa_upper_bound_m:          1.250000
                        voa_lower_bound_m:          1.250000
                        en_adsb:                    0
                        adsb_uart_bus:              7
                        adsb_uart_baudrate:         57600
                        px4_uart_bus:               5
                        px4_uart_baudrate:          921600
                        offboard_mode:              off
                        follow_tag_id:              0
                        en_tag_fixed_frame:         0
                        fixed_frame_filter_len:     5
                        loading extrinsics config file
                        starting geometry module
                        starting px4 monitor
                        starting uart mavlink
                        Successfully opened mavparser
                        starting udp mavlink
                        Adding manual QGC IP address to udp connection list: 192.168.0.121
                        Added new UDP connection to 192.168.0.121
                        starting px4 shell
                        starting fixed pose input
                        starting vio manager
                        starting tag manager
                        starting voa manager
                        starting control input pipe
                        Connected to voxl-qvio-server
                        updating to use imu: imu0
                        done updating transforms to use imu: imu0
                        Connected to voxl-tag-detector
                        Connected to voxl-dfs-server
                        any suggestion?
                          You could try a fresh install by following the instructions here: https://docs.modalai.com/voxl-suite/ . There does seem to be a chance your hardware is damaged though.
                            D Offline
                            D Offline
                            DarkKnightCH
                            @Chad-Sweet Yeah. I tried the following command
                            voxl-configure-opkg
                            and
                            opkg update
                            and then try to restart the voxl-vision-px4 and it seems nothing helps.
                            Since I can connect to voxl through wifi and adb, I have no idea why voxl will broken since I treat it very carefully. Indeed sometimes this QGC disconnection issue happens randomly. Could I mail back the Flight Core and VOXL to you and would you mind helping me check what is the issue?
                            • A Offline
                              Anubhav
                              @DarkKnightCH
                              Are you able to connect to QGC now. if yes, what was the issue and how you rectified it?
                              T 1 Reply Last reply
                              • A Anubhav
                                @DarkKnightCH
                                T Offline
                                T Offline
                                tpavlic
                                @Anubhav and @DarkKnightCH: Was there any movement on this?
                                We have 7 drones with FCv2 (all of our other m500 drones have different FC's) that were also sent to us with the wrong radios. We were able to reconfigure the PX4 for the desired radios (and confirm RC connection to QGC), but running voxl-mavlink-server manually shows a UART error on the console. We are RMA'ing the 7 units with the bad mavlink back to ModalAI for a fix, but it would be great to save the shipping if a fix was found here.
