  3. Should I upgrade?
Should I upgrade?
33 Posts 4 Posters 8.9k Views 3 Watching
    @Ed-Sutter Excellent, thanks!
    Ed SutterE Offline
    Ed SutterE Offline
    Ed Sutter
    @Eric-Katzfey FYI... Using a Logitech BRIO camera seems to work fine... the frame size always returns the same value (614400 in my case). Still, I wanna spend some time attempting to figure out why the Microsoft HD camera doesn't work as well...
    • Ed SutterE Ed Sutter
      @Ed-Sutter We have tested with these cameras:
      • Logitech C270
      • Logitech C930e
      • Logitech Brio (USB 2.0 and USB 3.0 on VOXL 2)
      • Videology 5MP Micro USB 2.0 Board Camera
      • PureThermal Mini with Flir Lepton
      • Flir Boson 640
      • Blue Robotics h264 camera
        Ed SutterE Offline
        Ed SutterE Offline
        Ed Sutter
        @Eric-Katzfey By the way, regarding "upgrading"... All I did was opkg update; opkg upgrade. I really don't know what all that updated (aside from /etc/modalai/voxl-streamer.conf); but the output of "voxl-version" didn't change at all.
        Based on that it appears I'm running with a system-image that was built on 2021-06-06 (about 15 months ago). Is that the most recent?
          @Ed-Sutter We are preparing a new VOXL platform release but are still completing an update of our ToF camera support. Once that is complete the release will go out.
          Ed SutterE 1 Reply Last reply
            Ed SutterE Offline
            Ed SutterE Offline
            Ed Sutter
            @Eric-Katzfey Ok, no rush (just curious)... Is that updated by the same procedure (opkg update; opkg upgrade)?
              @Ed-Sutter No, there is a bash script to handle it. The opkg method is good for SDK and package updates but the full platform release also contains a new system image that needs to be flashed via fastboot.
                Ed SutterE Offline
                Ed SutterE Offline
                Ed Sutter
                @Eric-Katzfey Update regarding the intermittent frame size when using the MS-1080P-HD camera... I pulled down the latest libuvc code from github and built it on my Ubuntu 18.04 machine. I was then able to run uvc_test on that camera and it always came back with the same (correct) frame size.
                Is there any chance that the libuvc version you guys have on voxl-public is a bit out-of-date?
                  Ed SutterE Offline
                  Ed SutterE Offline
                  Ed Sutter
                  @Eric-Katzfey Just to gather a little more data, I took the voxl-libuvc code and built it on Ubuntu18.04. Then I ran uvc_test with the MS-1080P-HD camera and it worked fine.
                  To do this I cloned libuvc and voxl-libuvc, then prior to building libuvc, I copied all the source files (*.[ch]) from voxl-libuvc to libuvc. This allowed me to use voxl-libuvc source code, but still build on a native ubuntu host.
                  Anyway, that eliminates voxl-libuvc from the suspect list. Since voxl-uvc-server's callback is fed the frame size, that kinda points to the driver as a possible suspect.
                  Any thoughts?
                  If interested, I can post the script I used to do that build.
                    Any thoughts?
                    @Ed-Sutter What is uvc_test?
                      Ed SutterE Offline
                      Ed SutterE Offline
                      Ed Sutter
                      #25
                      @Eric-Katzfey Its the output of building test.c which is part of the libuvc code. It just uses libuvc to grab frames and they are pushed to the console with OpenCV.
                        @Ed-Sutter It looks like it prints the length each frame. Do you see it show same frame length each time or does it ever change?
                          Ed SutterE Offline
                          Ed SutterE Offline
                          Ed Sutter
                          @Eric-Katzfey Yes, it does print every frame, and it is consistently (i.e. always) 614400 in my case.
                            Ed SutterE Offline
                            Ed SutterE Offline
                            Ed Sutter
                            @Eric-Katzfey I modified the voxl-libuvc/build.sh script so that it would build the uvc_test (from test.c) program I mentioned earlier. Refer to the README.md file in the original libuvc code)...
                            cmake ../libuvc -DBUILD_TEST=ON -DBUILD_EXAMPLE=ON
                            The test.c code uses opencv to display to a monitor, so I also stubbed that code out so that the callback simply prints the received frame size.
                            With those changes I was able to install the uvc_test program on my Voxl Flight Deck and I see the same inconsistent frame size. That eliminates any suspicion of a problem with voxl-uvc-server code; and since this works correctly on a standard x86 linux machine, this points to the driver. Are there any open issues with this that you are aware of?
                              @Ed-Sutter Thanks for the testing! No, I am not aware of any issues.
                                Ed SutterE Offline
                                Ed SutterE Offline
                                Ed Sutter
                                @Eric-Katzfey Just an FYI... I have been experimenting with libuvc on my host machine and I do notice occasional incorrect incoming frame sizes. So my earlier assumption that this only occurs on VOXL is false.
                                  @Ed-Sutter Okay, thanks! That's good to know. And really appreciate the investigation!
                                    @Ed-Sutter It's definitely better to be on the latest release. What specific issue are you having with USB camera streaming?
                                    Anton GerelesA Offline
                                    Anton Gereles
                                    @Eric-Katzfey so why i bought VOXL Flight Deck month ago with 3.3.0-0.5.0 version? it was difficult for your team to upgrade to new version before sending? wonderful service for 1000$. im 2 weeks trying to get video streaming to qgc. Result - 0.
                                      @Anton-Gereles If you have a specific question that we can help you with please open a new forum post and we'd be more that happy to help get you going.
