  3. Should I upgrade?
Should I upgrade?
33 Posts 4 Posters 9.8k Views 3 Watching
  • Ed SutterE Ed Sutter
    @Eric-Katzfey Sure... I just ran it again, and didn't even get to run VLC on my host and the server crashed. Here are the outputs...
    voxl-uvc_server:
    / # voxl-uvc-server -v045e -p0772 -r640x480 -d
    Enabling debug messages
    voxl-uvc-server starting
    Vendor ID 0x045e chosen
    Product ID 0x0772 chosen
    Image resolution 640x480, 30 fps chosen
    UVC initialized
    Device 045e:0772 found
    Device opened
    uvc_get_stream_ctrl_format_size succeeded for format 0
    Streaming starting
    Got frame callback! frame_format = 3, width = 640, height = 480, length = 613388, ptr = (nil)
     * got image 30
     * got image 60
     * got image 90
     * got image 120
     * got image 150
     * got image 180
     * got image 210
     * got image 240
     * got image 270
     * got image 300
     * got image 330
     * got image 360
     * got image 390
     * got image 420
     * got image 450
     * got image 480
     * got image 510
     * got image 540
     * got image 570
     * got image 600
    Segmentation fault
    voxl-streamer:
    / # voxl-streamer -c uvc-generic -d
    Using configuration uvc-generic
    Using configuration file /etc/modalai/voxl-streamer.conf
    MPA interface chosen
    Input pipe name /run/mpa/uvc/
    Output stream width 640
    Output stream height 480
    Output stream bitrate 1000000
    Output stream rotation 0
    Output frame decimator 1
    No image overlay specified
    Camera server Connected
    First frame timestamp: 5791926161024
    Second frame timestamp: 5791958239848
    Calculated frame delta in ns: 32078824
    Calculated frame delta in 100us: 320
    Calculated input frame rate is: 31
    Output frame rate will be: 31
    Meta data from incoming frame:
            magic_number 0x564F584C
            timestamp_ns: 5791958239848
            frame_id: 519
            width: 640
            height: 480
            size_bytes: 614400
            stride: 1280
            exposure_ns: 100
            gain: 100
            format: 8
    Input parameters initialized
    Made rtsp_server
    Created RTSP server main loop context
    Created RTSP server main loop source for callback
    Got 2 from gst_rtsp_server_attach
    Stream available at rtsp://127.0.0.1:8900/live
    Camera server Disconnected
    ERROR in pipe_client_init_channel opening request pipe: No such device or address
    ^CGot SIGINT, exiting
    Trying to stop loop
    g_main_loop exited
    voxl-streamer ending
    You can see in the voxl-streamer output that it was running till voxl-uvc-server crashed. Eventually, I used Ctrl-C to terminate voxl-streamer.
    If you want me to try anything, just let me know. I've worked with several USB cameras myself but primarily with V4L2/OpenCV/Gstreamer. I haven't used LibUVC, can't find much documentation. Can you point me to the libuvc source?
    @Ed-Sutter We use our own version of libuvc. You can find our project here: https://gitlab.com/voxl-public/voxl-sdk/third-party/voxl-libuvc
      voxl-uvc_server:
      UVC initialized
      Device opened
      Streaming starting
       * got image 30
       * got image 60
       * got image 90
       * got image 120
       * got image 150
       * got image 180
       * got image 210
       * got image 240
       * got image 270
       * got image 300
       * got image 330
       * got image 360
       * got image 390
       * got image 420
       * got image 450
       * got image 480
       * got image 510
       * got image 540
       * got image 570
       * got image 600
      Segmentation fault
      voxl-streamer:
              frame_id: 519
              width: 640
              height: 480
              size_bytes: 614400
              stride: 1280
              exposure_ns: 100
              gain: 100
              format: 8
      Made rtsp_server
      Trying to stop loop
      g_main_loop exited
      @Ed-Sutter I think the problem is the varying frame size. That's probably causing a problem somewhere (either memory leak or overflow).
      Ed SutterE 1 Reply Last reply
        Ed SutterE Offline
        Ed SutterE Offline
        Ed Sutter
        #12
        @Eric-Katzfey I agree, but I don't understand why the frame size varies! Its not compressed, so it should be a fixed size per frame. Know what I mean?
          @Ed-Sutter Yes. But maybe just a quirk of the camera. There are a few ways to go about fixing this. It looks like the frames are either the correct size or smaller. If that's the case, you could always add "fake" data to the end of the received buffer to make it the correct size in voxl-uvc-server and then write it into the pipe. You could try this and see if that makes the stream work.
            Ed SutterE Offline
            Ed SutterE Offline
            Ed Sutter
            @Eric-Katzfey Ok, I'll dig into this more. I need to understand it anyway, so I'll look at libuvc and voxl-uvc-server and let you know what I figure out.
              @Ed-Sutter Excellent, thanks!
                Ed SutterE Offline
                Ed SutterE Offline
                Ed Sutter
                @Eric-Katzfey FYI... Using a Logitech BRIO camera seems to work fine... the frame size always returns the same value (614400 in my case). Still, I wanna spend some time attempting to figure out why the Microsoft HD camera doesn't work as well...
                  @Ed-Sutter We have tested with these cameras:
                  • Logitech C270
                  • Logitech C930e
                  • Logitech Brio (USB 2.0 and USB 3.0 on VOXL 2)
                  • Videology 5MP Micro USB 2.0 Board Camera
                  • PureThermal Mini with Flir Lepton
                  • Flir Boson 640
                  • Blue Robotics h264 camera
                    Ed SutterE Offline
                    Ed SutterE Offline
                    Ed Sutter
                    @Eric-Katzfey By the way, regarding "upgrading"... All I did was opkg update; opkg upgrade. I really don't know what all that updated (aside from /etc/modalai/voxl-streamer.conf); but the output of "voxl-version" didn't change at all.
                    Based on that it appears I'm running with a system-image that was built on 2021-06-06 (about 15 months ago). Is that the most recent?
                      @Ed-Sutter We are preparing a new VOXL platform release but are still completing an update of our ToF camera support. Once that is complete the release will go out.
                        Ed SutterE Offline
                        Ed SutterE Offline
                        Ed Sutter
                        @Eric-Katzfey Ok, no rush (just curious)... Is that updated by the same procedure (opkg update; opkg upgrade)?
                          @Ed-Sutter No, there is a bash script to handle it. The opkg method is good for SDK and package updates but the full platform release also contains a new system image that needs to be flashed via fastboot.
                            Ed SutterE Offline
                            Ed SutterE Offline
                            Ed Sutter
                            @Eric-Katzfey Update regarding the intermittent frame size when using the MS-1080P-HD camera... I pulled down the latest libuvc code from github and built it on my Ubuntu 18.04 machine. I was then able to run uvc_test on that camera and it always came back with the same (correct) frame size.
                            Is there any chance that the libuvc version you guys have on voxl-public is a bit out-of-date?
                              Ed SutterE Offline
                              Ed SutterE Offline
                              Ed Sutter
                              @Eric-Katzfey Just to gather a little more data, I took the voxl-libuvc code and built it on Ubuntu18.04. Then I ran uvc_test with the MS-1080P-HD camera and it worked fine.
                              To do this I cloned libuvc and voxl-libuvc, then prior to building libuvc, I copied all the source files (*.[ch]) from voxl-libuvc to libuvc. This allowed me to use voxl-libuvc source code, but still build on a native ubuntu host.
                              Anyway, that eliminates voxl-libuvc from the suspect list. Since voxl-uvc-server's callback is fed the frame size, that kinda points to the driver as a possible suspect.
                              Any thoughts?
                              If interested, I can post the script I used to do that build.
                                Any thoughts?
                                @Ed-Sutter What is uvc_test?
                                  Ed SutterE Offline
                                  Ed SutterE Offline
                                  Ed Sutter
                                  #25
                                  @Eric-Katzfey Its the output of building test.c which is part of the libuvc code. It just uses libuvc to grab frames and they are pushed to the console with OpenCV.
                                    @Ed-Sutter It looks like it prints the length each frame. Do you see it show same frame length each time or does it ever change?
                                      Ed SutterE Offline
                                      Ed SutterE Offline
                                      Ed Sutter
                                      @Eric-Katzfey Yes, it does print every frame, and it is consistently (i.e. always) 614400 in my case.
                                        Ed SutterE Offline
                                        Ed SutterE Offline
                                        Ed Sutter
                                        @Eric-Katzfey I modified the voxl-libuvc/build.sh script so that it would build the uvc_test (from test.c) program I mentioned earlier. Refer to the README.md file in the original libuvc code)...
                                        cmake ../libuvc -DBUILD_TEST=ON -DBUILD_EXAMPLE=ON
                                        The test.c code uses opencv to display to a monitor, so I also stubbed that code out so that the callback simply prints the received frame size.
                                        With those changes I was able to install the uvc_test program on my Voxl Flight Deck and I see the same inconsistent frame size. That eliminates any suspicion of a problem with voxl-uvc-server code; and since this works correctly on a standard x86 linux machine, this points to the driver. Are there any open issues with this that you are aware of?
                                          @Ed-Sutter Thanks for the testing! No, I am not aware of any issues.
