  3. Having issues Configuring ROS on VOXL CAM
voxl-cam
21 Posts 5 Posters 8.4k Views 3 Watching
  • Bright NnadiB Offline
    Bright Nnadi
    @Alex-Gardner When setting up the ROS on voxl I am supposed to make any change to the ROS_MASTER_URI / ROS_IP / ROS_USERNAME. 04e09103-adc1-4ea2-9bff-d72df26fa474-image.png
      Bright Nnadi
      @Alex-Gardner Please is it possible to have a meeting with you. I have had the VOXL CAM for a while now and I am still encountering issues setting it up. Please it will be well appreciated if someone from your team can start a remote session with me for guidance.
      • Steve TurnerS Offline
        Steve Turner
        @Bright-Nnadi
        You need to set your Ubuntu development environment with ROS to point to the ROS Master process on the VOXL.
        Check out: https://answers.ros.org/question/35603/ros_master_uri-change-it-and-save-it/
        So for example if the IP address of the VOXL is 192.168.1.118 then you need to execute export ROS_MASTER_URI=http://192.168.1.118:11311 on the Ubuntu system and then run rviz from the same terminal.
        You then also need to run the MAVROS or MPA ROS Bridge on the VOXL along with the ROS master node.
        Start ros master: roscore
        mavros: https://docs.modalai.com/mavros/
        On the voxl you need to edit the ROS_IP to match your voxl's IP address so that other hosts can connect to it.
        If this doesn't work, consider examining your firewall on your ubuntu system to make sure it isn't block ROS traffic. If it's a vanilla ROS/Ubuntu install you should be fine.
        • Steve TurnerS Steve Turner
          @Bright-Nnadi
          Bright Nnadi
          @Steve-Turner I updated the ROS_MASTER_URI but its still saying the same thing and saying it cannot contact ROS master 9d7d2f01-d129-4a8b-b506-ff4ef018423a.jpg
            Bright Nnadi
              Assuming you are trying to run ROS master on your VOXL, first find out what is your VOXL's IP? Let's call that <VOXL IP>
              Then, can you ping that IP from the computer you are trying to run Rviz?
              $ ping <VOXL IP>
              If so, on VOXL edit your ROS environment
              export ROS_IP="<VOXL IP>"
              Then start ROS on the VOXL. Monitor the output of the ROS master when it launches, you should see the "roscore" IP the same as what you just configured.
              If so, configure the ROS environment on your PC
              What is the IP of your PC on the same network as the VOXL? We'll call that <PC IP>
              Configure the PC's ROS environment as such:
              export ROS_MASTER_URI="http://<VOXL IP>:11311"
              export ROS_IP="<PC IP>"
              Then launch RViz
              Note: The instructions above are configuring the master to be the VOXL by pointing both VOXL and the PC to the VOXL's IP address as master. Checkout slides 7,8,9 in the presentation here
              Bright NnadiB KrisK 3 Replies Last reply
              • Chad SweetC Chad Sweet
                $ ping <VOXL IP>
                Then launch RViz
                Bright Nnadi
                @Chad-Sweet thanks Chad, so I got Rviz working now !![0_1660157598192_05B72248-F814-4C2F-947E-4443E4FB94F3.jpeg](Uploading 45%)
                  Bright Nnadi
                  Is the IP address of my VOXL CAM 192.168.8.1
                    $ ping <VOXL IP>
                    Then launch RViz
                    Bright Nnadi
                    @Chad-Sweet I’m connected to the VOXL using Adb not wifi
                    • ? Offline
                      ROS uses wifi to communicate, not ADB. You'll need to connect the drone and you computer to the same network in order to use ros. This can either be done by connecting the drone to your home/work network or by setting the drone to serve as an AP. Instructions for either can be found here
                      KrisK 2 Replies Last reply
                        $ ping <VOXL IP>
                        Then launch RViz
                        KrisK Offline
                        KrisK Offline
                        Kris
                        wrote on last edited by Kris
                        #16
                        @Chad-Sweet I am also having the same issue. I am not sure what im doing wrong.
                        This is my PC (my_ros_env.sh)
                        This is my VOXL (my_ros_env.sh)
                        This is what I get when I try to show my voxl-env
                        Setting up environment variables for ROS is a little confusing for me.
                        I am using wifi to communicate with VOXL.
                        My VOXL IP is the usual 192.168.8.1
                        My PC IP is 192.168.8.78
                        I am stuck here.
                        Could someone please point me in the right direction?
                        KrisK 1 Reply Last reply
                        • KrisK Kris
                          I am stuck here.
                          KrisK Offline
                          KrisK Offline
                          Kris
                          Just wondering why my voxl environments are all blank everytime I try to view them. Should I " export " the values manually?
                          • ? A Former User
                            KrisK Offline
                            KrisK Offline
                            Kris
                            My Voxl System Image-
                            • ? A Former User
                              KrisK Offline
                              KrisK Offline
                              Kris
                              My current voxl services-
                              • ? Offline
                                It looks like you're on a pretty old release of our software stack (3.3.0-0.5), you should download the latest release (3.8.0-0.7) from our downloads page and we'll be better able to support issues that you're having since there's a good chance we've fixed them in the 10 months since the 0.5 release.
                                • ? A Former User
                                  KrisK Offline
                                  KrisK Offline
                                  Kris
                                  @Alex-Gardner Thank you for your help 🙂
