  3. Having issues Configuring ROS on VOXL CAM
voxl-cam
21 Posts 5 Posters 7.3k Views 3 Watching
  • Bright NnadiB Offline
    Bright Nnadi
    I am having issues configuring ROS on VOXL. A little bit confused with this.
      Bright Nnadi
      I'm connected to the VOXL CAM via adb, however to view the Stereo tracking data I need to configure ROS on the VOXL CAM. when i run this command line vi ~/my_ros_env-sh, do I have to change anything on there?
        Bright Nnadi
        When I try to rviz, this what pops up
        • ? Offline
          Localhost refers to the running machine's ip, if you're trying to connect to the voxl's ros instance you need to configure your computer's ros to look for your drones ip.
          • ? A Former User
            Bright Nnadi
            @Alex-Gardner What command lines are my using to for this configuration
              Bright Nnadi
              @Alex-Gardner When setting up the ROS on voxl I am supposed to make any change to the ROS_MASTER_URI / ROS_IP / ROS_USERNAME. 04e09103-adc1-4ea2-9bff-d72df26fa474-image.png
                Bright Nnadi
                @Alex-Gardner Please is it possible to have a meeting with you. I have had the VOXL CAM for a while now and I am still encountering issues setting it up. Please it will be well appreciated if someone from your team can start a remote session with me for guidance.
                • Steve TurnerS Offline
                  Steve Turner
                  @Bright-Nnadi
                  You need to set your Ubuntu development environment with ROS to point to the ROS Master process on the VOXL.
                  Check out: https://answers.ros.org/question/35603/ros_master_uri-change-it-and-save-it/
                  So for example if the IP address of the VOXL is 192.168.1.118 then you need to execute export ROS_MASTER_URI=http://192.168.1.118:11311 on the Ubuntu system and then run rviz from the same terminal.
                  You then also need to run the MAVROS or MPA ROS Bridge on the VOXL along with the ROS master node.
                  Start ros master: roscore
                  mavros: https://docs.modalai.com/mavros/
                  On the voxl you need to edit the ROS_IP to match your voxl's IP address so that other hosts can connect to it.
                  If this doesn't work, consider examining your firewall on your ubuntu system to make sure it isn't block ROS traffic. If it's a vanilla ROS/Ubuntu install you should be fine.
                  • Steve TurnerS Steve Turner
                    @Bright-Nnadi
                    Bright Nnadi
                    @Steve-Turner I updated the ROS_MASTER_URI but its still saying the same thing and saying it cannot contact ROS master 9d7d2f01-d129-4a8b-b506-ff4ef018423a.jpg
                      Bright Nnadi
                        Assuming you are trying to run ROS master on your VOXL, first find out what is your VOXL's IP? Let's call that <VOXL IP>
                        Then, can you ping that IP from the computer you are trying to run Rviz?
                        $ ping <VOXL IP>
                        If so, on VOXL edit your ROS environment
                        export ROS_IP="<VOXL IP>"
                        Then start ROS on the VOXL. Monitor the output of the ROS master when it launches, you should see the "roscore" IP the same as what you just configured.
                        If so, configure the ROS environment on your PC
                        What is the IP of your PC on the same network as the VOXL? We'll call that <PC IP>
                        Configure the PC's ROS environment as such:
                        export ROS_MASTER_URI="http://<VOXL IP>:11311"
                        export ROS_IP="<PC IP>"
                        Then launch RViz
                        Note: The instructions above are configuring the master to be the VOXL by pointing both VOXL and the PC to the VOXL's IP address as master. Checkout slides 7,8,9 in the presentation here
                        Bright NnadiB KrisK 3 Replies Last reply
                        • Chad SweetC Chad Sweet
                          $ ping <VOXL IP>
                          Then launch RViz
                          Bright Nnadi
                          @Chad-Sweet thanks Chad, so I got Rviz working now !![0_1660157598192_05B72248-F814-4C2F-947E-4443E4FB94F3.jpeg](Uploading 45%)
                            Bright Nnadi
                            Is the IP address of my VOXL CAM 192.168.8.1
                              $ ping <VOXL IP>
                              Then launch RViz
                              Bright Nnadi
                              @Chad-Sweet I’m connected to the VOXL using Adb not wifi
                              • ? Offline
                                ROS uses wifi to communicate, not ADB. You'll need to connect the drone and you computer to the same network in order to use ros. This can either be done by connecting the drone to your home/work network or by setting the drone to serve as an AP. Instructions for either can be found here
                                KrisK 2 Replies Last reply
                                  $ ping <VOXL IP>
                                  Then launch RViz
                                  KrisK Offline
                                  KrisK Offline
                                  Kris
                                  wrote on last edited by Kris
                                  #16
                                  @Chad-Sweet I am also having the same issue. I am not sure what im doing wrong.
                                  This is my PC (my_ros_env.sh)
                                  This is my VOXL (my_ros_env.sh)
                                  This is what I get when I try to show my voxl-env
                                  Setting up environment variables for ROS is a little confusing for me.
                                  I am using wifi to communicate with VOXL.
                                  My VOXL IP is the usual 192.168.8.1
                                  My PC IP is 192.168.8.78
                                  I am stuck here.
                                  Could someone please point me in the right direction?
                                  KrisK 1 Reply Last reply
                                  • KrisK Kris
                                    I am stuck here.
                                    KrisK Offline
                                    KrisK Offline
                                    Kris
                                    Just wondering why my voxl environments are all blank everytime I try to view them. Should I " export " the values manually?
                                    • ? A Former User
                                      KrisK Offline
                                      KrisK Offline
                                      Kris
                                      My Voxl System Image-
                                      • ? A Former User
                                        KrisK Offline
                                        KrisK Offline
                                        Kris
                                        My current voxl services-
                                        • ? Offline
                                          It looks like you're on a pretty old release of our software stack (3.3.0-0.5), you should download the latest release (3.8.0-0.7) from our downloads page and we'll be better able to support issues that you're having since there's a good chance we've fixed them in the 10 months since the 0.5 release.
