    Having issues Configuring ROS on VOXL CAM
    VOXL-CAM
    5355
    • Bright NnadiB
      Bright Nnadi
      I am having issues configuring ROS on VOXL. A little bit confused with this.
      • Bright NnadiB
        Bright Nnadi
        I'm connected to the VOXL CAM via adb, however to view the Stereo tracking data I need to configure ROS on the VOXL CAM. when i run this command line vi ~/my_ros_env-sh, do I have to change anything on there?
        • Bright NnadiB
          Bright Nnadi
          When I try to rviz, this what pops up
            Localhost refers to the running machine's ip, if you're trying to connect to the voxl's ros instance you need to configure your computer's ros to look for your drones ip.
            Bright NnadiB 1 Reply Last reply Reply Quote 0
            • Bright NnadiB
              Bright Nnadi @Guest
              @Alex-Gardner What command lines are my using to for this configuration
              • Bright NnadiB
                Bright Nnadi
                @Alex-Gardner When setting up the ROS on voxl I am supposed to make any change to the ROS_MASTER_URI / ROS_IP / ROS_USERNAME. 04e09103-adc1-4ea2-9bff-d72df26fa474-image.png
                • Bright NnadiB
                  Bright Nnadi
                  @Alex-Gardner Please is it possible to have a meeting with you. I have had the VOXL CAM for a while now and I am still encountering issues setting it up. Please it will be well appreciated if someone from your team can start a remote session with me for guidance.
                  • Steve TurnerS
                    Steve Turner
                    @Bright-Nnadi
                    You need to set your Ubuntu development environment with ROS to point to the ROS Master process on the VOXL.
                    Check out: https://answers.ros.org/question/35603/ros_master_uri-change-it-and-save-it/
                    So for example if the IP address of the VOXL is 192.168.1.118 then you need to execute export ROS_MASTER_URI=http://192.168.1.118:11311 on the Ubuntu system and then run rviz from the same terminal.
                    You then also need to run the MAVROS or MPA ROS Bridge on the VOXL along with the ROS master node.
                    Start ros master: roscore
                    mavros: https://docs.modalai.com/mavros/
                    On the voxl you need to edit the ROS_IP to match your voxl's IP address so that other hosts can connect to it.
                    If this doesn't work, consider examining your firewall on your ubuntu system to make sure it isn't block ROS traffic. If it's a vanilla ROS/Ubuntu install you should be fine.
                    • Bright NnadiB
                      Bright Nnadi @Steve Turner
                      @Steve-Turner I updated the ROS_MASTER_URI but its still saying the same thing and saying it cannot contact ROS master 9d7d2f01-d129-4a8b-b506-ff4ef018423a.jpg
                      • Bright NnadiB
                        Bright Nnadi
                        • Chad SweetC
                          Chad Sweet ModalAI Team
                          Assuming you are trying to run ROS master on your VOXL, first find out what is your VOXL's IP? Let's call that <VOXL IP>
                          Then, can you ping that IP from the computer you are trying to run Rviz?
                          $ ping <VOXL IP>
                          If so, on VOXL edit your ROS environment
                          export ROS_IP="<VOXL IP>"
                          Then start ROS on the VOXL. Monitor the output of the ROS master when it launches, you should see the "roscore" IP the same as what you just configured.
                          If so, configure the ROS environment on your PC
                          What is the IP of your PC on the same network as the VOXL? We'll call that <PC IP>
                          Configure the PC's ROS environment as such:
                          export ROS_MASTER_URI="http://<VOXL IP>:11311"
                          export ROS_IP="<PC IP>"
                          Then launch RViz
                          Note: The instructions above are configuring the master to be the VOXL by pointing both VOXL and the PC to the VOXL's IP address as master. Checkout slides 7,8,9 in the presentation here
                          Bright NnadiB KrisK 3 Replies Last reply Reply Quote 0
                          • Bright NnadiB
                            Bright Nnadi @Chad Sweet
                            @Chad-Sweet thanks Chad, so I got Rviz working now !![0_1660157598192_05B72248-F814-4C2F-947E-4443E4FB94F3.jpeg](Uploading 45%)
                            • Bright NnadiB
                              Bright Nnadi
                              Is the IP address of my VOXL CAM 192.168.8.1
                              • Bright NnadiB
                                @Chad-Sweet I’m connected to the VOXL using Adb not wifi
                                  ROS uses wifi to communicate, not ADB. You'll need to connect the drone and you computer to the same network in order to use ros. This can either be done by connecting the drone to your home/work network or by setting the drone to serve as an AP. Instructions for either can be found here
                                  KrisK 2 Replies Last reply Reply Quote 0
                                  • KrisK
                                    Kris @Chad Sweet
                                    @Chad-Sweet I am also having the same issue. I am not sure what im doing wrong.
                                    This is my PC (my_ros_env.sh)
                                    This is my VOXL (my_ros_env.sh)
                                    This is what I get when I try to show my voxl-env
                                    Setting up environment variables for ROS is a little confusing for me.
                                    I am using wifi to communicate with VOXL.
                                    My VOXL IP is the usual 192.168.8.1
                                    My PC IP is 192.168.8.78
                                    I am stuck here.
                                    Could someone please point me in the right direction?
                                    KrisK 1 Reply Last reply Reply Quote 0
                                    • KrisK
                                      Kris @Kris
                                      Just wondering why my voxl environments are all blank everytime I try to view them. Should I " export " the values manually?
                                      • KrisK
                                        Kris @Guest
                                        My Voxl System Image-
                                        • KrisK
                                          Kris @Guest
                                          My current voxl services-
                                            It looks like you're on a pretty old release of our software stack (3.3.0-0.5), you should download the latest release (3.8.0-0.7) from our downloads page and we'll be better able to support issues that you're having since there's a good chance we've fixed them in the 10 months since the 0.5 release.
