  3. Having issues Configuring ROS on VOXL CAM
voxl-cam
21 Posts 5 Posters 8.4k Views 3 Watching
    Assuming you are trying to run ROS master on your VOXL, first find out what is your VOXL's IP? Let's call that <VOXL IP>
    Then, can you ping that IP from the computer you are trying to run Rviz?
    $ ping <VOXL IP>
    If so, on VOXL edit your ROS environment
    export ROS_IP="<VOXL IP>"
    Then start ROS on the VOXL. Monitor the output of the ROS master when it launches, you should see the "roscore" IP the same as what you just configured.
    If so, configure the ROS environment on your PC
    What is the IP of your PC on the same network as the VOXL? We'll call that <PC IP>
    Configure the PC's ROS environment as such:
    export ROS_MASTER_URI="http://<VOXL IP>:11311"
    export ROS_IP="<PC IP>"
    Then launch RViz
    Note: The instructions above are configuring the master to be the VOXL by pointing both VOXL and the PC to the VOXL's IP address as master. Checkout slides 7,8,9 in the presentation here
    Bright NnadiB KrisK 3 Replies Last reply
    • Chad SweetC Chad Sweet
      $ ping <VOXL IP>
      Then launch RViz
      Bright NnadiB Offline
      Bright Nnadi
      @Chad-Sweet thanks Chad, so I got Rviz working now !![0_1660157598192_05B72248-F814-4C2F-947E-4443E4FB94F3.jpeg](Uploading 45%)
      • Bright NnadiB Offline
        Bright Nnadi
        Is the IP address of my VOXL CAM 192.168.8.1
          $ ping <VOXL IP>
          Then launch RViz
          Bright Nnadi
          @Chad-Sweet I’m connected to the VOXL using Adb not wifi
          • ? Offline
            ROS uses wifi to communicate, not ADB. You'll need to connect the drone and you computer to the same network in order to use ros. This can either be done by connecting the drone to your home/work network or by setting the drone to serve as an AP. Instructions for either can be found here
            KrisK 2 Replies Last reply
              $ ping <VOXL IP>
              Then launch RViz
              KrisK Offline
              KrisK Offline
              Kris
              wrote on last edited by Kris
              #16
              @Chad-Sweet I am also having the same issue. I am not sure what im doing wrong.
              This is my PC (my_ros_env.sh)
              This is my VOXL (my_ros_env.sh)
              This is what I get when I try to show my voxl-env
              Setting up environment variables for ROS is a little confusing for me.
              I am using wifi to communicate with VOXL.
              My VOXL IP is the usual 192.168.8.1
              My PC IP is 192.168.8.78
              I am stuck here.
              Could someone please point me in the right direction?
              KrisK 1 Reply Last reply
              • KrisK Kris
                I am stuck here.
                KrisK Offline
                KrisK Offline
                Kris
                Just wondering why my voxl environments are all blank everytime I try to view them. Should I " export " the values manually?
                • ? A Former User
                  KrisK Offline
                  KrisK Offline
                  Kris
                  My Voxl System Image-
                  • ? A Former User
                    KrisK Offline
                    KrisK Offline
                    Kris
                    My current voxl services-
                    • ? Offline
                      It looks like you're on a pretty old release of our software stack (3.3.0-0.5), you should download the latest release (3.8.0-0.7) from our downloads page and we'll be better able to support issues that you're having since there's a good chance we've fixed them in the 10 months since the 0.5 release.
                      • ? A Former User
                        KrisK Offline
                        KrisK Offline
                        Kris
                        @Alex-Gardner Thank you for your help 🙂
